Question about Empire Heating & Cooling
Adjust flame on propane heater
How do I adjust the flame to eliminate yellow flame and only have the blue.?
5 Suggested Answers
billyvangogh
  • 108 Answers
SOURCE: how do i adjust the flame on ,my glo-warm propane
if there is any adjustment it will be on the gas valve itself under the front of the unit....should have a little door that pulls down....you should see a knob that says "Higher....Lower" something like that....if the knob only says "ON , Off and Pilot" there is no adjustment
Posted on Nov 01, 2009
keith91gmc
  • 52 Answers
SOURCE: my blue flame heater has yellow tipped flames?
yes air to fuel ratio is off
Posted on Dec 19, 2009
  • 3249 Answers
SOURCE: the pilot flame on my Velor propane heater is too high
Hi follow the pilot tube back to the gas valve there might be a adjustment screw there
Posted on Jan 21, 2010
Therinnaiguy
  • 1420 Answers
SOURCE: My blue flame propane heater has tall, 3-4 inch
Get a can of air used in the computer industry and blow on the pilot assembly and the main burner. You have debris or dust blocking the air horn of the burner. Simple fix!
Posted on Mar 04, 2010
Can you adjust a thermocouple out on a propane wall heater?
Unless you're having a pressure issue(it's cold outside and may be affecting the regulator, which can be adjusted) it may just be a dirty pilot orifice. Turn off the heater and let it cool down. Take a can of compressed air (the can with the straw to clean keyboards) and blow out the dust inside the pilot assembly were the orifice is inside. You'll know if it's dirty, if the pilot flame is a lazy yellow, as it should be a crisp blue flame encompassing the thermocouple. The thermocouple is pretty much set in place in these heaters, unless it's loose and has fallen down, it's most likely the dirty orifice.
Mar 01, 2015 | Heating & Cooling
I have a Dyna-Glo RMC-50LPT propane heater that is about 5 years old and I can't get rid of the yellow flames when it operates. I have tried: - removing the heater and blowing everything out with a...
Dennis easy fix what is your out going gas you will need a manometer to verify it accurately or adjust your gas valve til your blue flames are gone. Let me know what you find!
Dec 16, 2010 | Heating & Cooling
ON MY ATWOOD WATERHEATER IT LIGHTS BUT PRODUCES A LOT OF SOOT AND DOES NOT SEEM TO FIRE UP LIKE IT SHOULD
You need to start by cleaning burner tube and pilot intake , sounds like spiders have probably spun a web in there. If flame is yellowish, it's not getting enough air. You can buy a barbecue burner brush, long and flexible, and run it through burner tube to clean out web, and if pilot is yellow as well, there is a small hole in side of fitting where it attaches up near burner that needs to be cleaned out with paper clip or even better, compressed air. After cleaning burner, adjust air shutter to get nice blue flame, with just a hint of yellow at tip. The idea there is to get blue flame, but not a roaring flame that is jumping off the burner. A spider web in there will usually allow propane through, but restricts air mixture, thus causing yellow flame (rich mixture) and soot to build up.
Nov 11, 2010 | RTO Atwood Water Heater - 6 Gal LP
I turned my propane fireplace on and it set my smoke alarm off. We have lived here for three years and never had this problem before. Please advise.
check to see if the flame is pure blue. if not you have incomplete combustion letting CO or CO2 into the room. The flame will look yellow if this is the case. An orange flame indicates dust and dirt around the burner assembly. If it is yellow, the should be 1-2 set screws on the back of the burner assembly that will let you adjust the primary air being mixed with the propane.Adjust until you get blue flame and tighten set screws.
Dec 05, 2009 | Vanguard International Blue Flame - Large...
Propane stove burns yellow & creates soot
clean the orfices and tubes and then if possible adjust your air mixture setting also
Sep 21, 2009 | Frigidaire FGB24S5A Gas Single Oven
Propane convection heater won't maintain full flame
Seems like the valve is not opening up fully or the adjustment is out of adjustment. Try adjusting the flame.
Feb 15, 2009 | Mr. Heater Mr Heater Portable Buddy...
Propane gas burner now has red flame instead of blue
Hi, If you have the same problem with your stove , furnace and water heater, Then you look for things in common that would cause the problem. Any change in the flames is an indication of a change in the fuel/air mix. The item that would be common to all would be the pressure diaphragm. This is not something a customer should work on without a through knowledge of how they work. I think you would be well advised to have a service call. Good Luck!
Feb 10, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Adjusting goodman propane burners
Yellow flame can also mean inadequate gas pressure. Do you have a manometer? If not, call your gas company for a check.
Oct 09, 2008 | Goodman GMS90703BXA Heater
Burner flame adjustment
there are two considerations for burner height. 1) the gas adjustment screw on the knob and 2) the gas-air mixture to the burner. establish a flame and adjust the screw for a standing flame at the burner. adjust the gas-air ratio orifice so that the flame has no yellow tips.
Aug 30, 2007 | GE Spectra JGBP30 Gas Kitchen Range
Propane Reddy Heater
AIR MIXTURE ADJUSTMENT IS CRITICAL ON ALL GAS BURNING HEATERS. SOUNDS LIKE YOU HAVE INSUFFICIANT CUMBUSTION AIR WHICH WILL CAUSE A WHITE AND LAZY FLAME .... FLAME SHOULD BE BRIGHT BLUE WITH NO WHITE OR YELLOW TIPS ON THE FLAME.
Apr 06, 2007 | Reddy Heater RLP100 Portable Forced Air...
Heating & Cooling Logo
374 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
vance jones
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
