Question about Sony DVP-NS575P DVD Player
Closed caption on dvds
How do i program my sony NS-575P for "CLOSED CAPTIONS'? not subtitles. I programed subtitles with no problem, but i can't program "CLOSED CAPTIONS"! my email is [email protected]
  • 432 Answers
Your TV will need to have (CC) capability. To view Closed Captioning (CC) information from a DVD using the CC function of the television, turn off the Progressive Scan function of the DVD player. If the DVD player doesn't have progressive scan then follow the instructions from your TV manual to setup closed captioning.
Posted on Jul 14, 2007
6ya staff
SOURCE:
Can I program closed caption ? my t.v. is not high definition, I do have c.c. on it for all stations, but cannot find a way to get c.c. while playing a dvd
if the dvd player doesnt have an option for cc which it should then the tv should may take over UNLESS you are connecting via hdmi
Mar 25, 2011 | Sony DVP-NS55P DVD Player
How do I get closed captioning on a Samsung TV model TXJ2754?
Hello
Your TV displays the closed captions that are broadcast with some
television shows. These captions are usually subtitles for the hearing
impaired or language translations. All VCRs record the closed caption
signal and most pre-recorded commercial video tapes provide closed
captions. Check for the closed caption symbol in your television
schedule and on the tape's packaging: .
1 Press MENU repeatedly until you see the Setup menu. Press CH
to select "Caption."
2 Press VOL+ to open the Closed Caption menu.
3 Press VOL + to turn closed captioning on.
Misspellings and odd characters can occur in captioning. Also, there may be a
captioning delay after changing channels. Neither situation is a TV malfunction.
4 Press CH to highlight "Mode." Press - VOL or VOL + to choose
"Capt." (captions) or "Text." In caption mode, captions appear and
cover a small portion of the picture. In text mode, information unrelated
to the program, such as news reports, are displayed and
often cover a large portion of the screen.
5 If you wish, use CH , CH , or VOL + to change the captioning
channel or field. Then, press DISPLAY to return to normal viewing.
 Different channels and fields display different information, such as additional
languages or supplemental information
Nov 23, 2010 | Samsung TXJ2754 27" TV
How to remove subtitles from sony bravia tv screen
You can download the user manual here.
http://www.retrevo.com/support/Toshiba-57H84-TVs-manual/id/311ag813/t/2/
The closed caption feature has two options:
• Captions—An on-screen display of the dialogue, narration, and sound effects of TV programs and videos that are closed captioned (usually marked as “CC” in TV listings).
• Text—An on-screen display of information not related to the current program, such as weather or stock data (when provided by individual stations).
To view captions or text:
1. Tune the TV to the desired program.
2.Press MENU, and then press x or • to display CUSTOM menu.
3. Press y or z to highlight CC, and then press ENTER.
4. Press y or z to highlight CAPTION or TEXT, and then press Enter.
To turn off the Closed Caption feature:
Highlight OFF in step 4.
Apr 09, 2010 | Toshiba 57H84 57" Rear Projection...
Need to know how to put the tv on close caption
Captioned programs are marked in TV listings by "CC". so press the cc button on the remote and the closed caption option will be applied.press that cc button again to turn off the closed caption option.
1) Check the size and manufactured year of your television. If it was made after 1993 and is larger than 13 inches, it has a closed captioning system built into it. Otherwise, you may need to purchase a separate closed caption system, which are available at a number of online outlets.
  1. 2)Turn on your TV and access the menu for closed captioning. The precise location of the menu varies by television set. Most are accessible by pressing the "Audio" or "Set Up" menu on your remote, then scrolling down to the "CC" or "Closed Captioning" option. Check your owner's manual for precise instructions.
  2. 3)Turn the closed captioning option to the "On" position. It will then run closed captions for every program that broadcasts them. Newer sets may allow you to adjust the size, font and colors of the closed captioning letters to fit your individual tastes.
  3. 4)Tune to a particular program for a few minutes to make sure the closed captions are working. Note that while many broadcasts run closed captioning, not all of them do. If the captions don't appear, check your TV listing to ensure the program includes them.
  4. 5)If you're watching a DVd on your TV, access the DVD's "Set Up" menu. It should have captioned options, which allow you to show captions in English and possibly other languages as well.
  5. thanks.
Nov 11, 2009 | Televison & Video
By the numbers! How do I turn on the closed
there is no closed captions on dvds, you can use subtitles, very similar to closed captions. just load dvd
look into either extra features or subtitles
it would say "english for deaf/hard of hearing." or just plain english subtitle. either way, it works.
Oct 17, 2009 | Emerson EWD2203 DVD Player/VCR
How do i turn off the subtitles on my toshiba 36hf72 tv, without the remote
The subtitles in dubbed videos VCD/DVD the process to follow are :-
2. Press MENU, and then press x or • until the CUSTOM menu
appears.
3. Press z or y to highlight CC.
4. Press x or • to highlight the desired closed caption mode, as
follows:
• To view captions, highlight C1, C2, C3, or C4 (C1 displays
translation of the primary language in your area).
Note: If the program or video you selected is not closed captioned,
no captions will display on the screen.
• To view text, highlight T1, T2, T3, or T4.
Note: If text is not available in your area, a black rectangle may appear on your screen. If this happens, turn the Closed Caption feature OFF.
Note:
A closed caption signal may not display in the
following situations:
• when a videotape has been dubbed
• when the signal reception is weak
• when the signal reception is nonstandard
PS: If you do not want to set these function & their commands can be entered via the buttons on the TV set. Using the remote is much easier to operate............ sodeep
Oct 08, 2009 | Toshiba 36HF72 36" TV
How do i turn on the subtitles on my tv
On your remote control look for a button that says CC for Closed captions. If some screen (CCD) with choices appears, use the [Arrows] to try them one after the other until captions are displayed. Beware that some programs do not show captions. News programs usually do.
Hope it helps
Sep 05, 2009 | Polaroid Televison & Video
I need to activate CC for my Dad, Please help I have to go to work. I have a flat screen SOYO
Determine if closed captioning is available on the program that you've selected. In your program guide, the letters "CC" should appear at the end of the description.
Locate the closed captioning option on your remote. Some remotes have a "CC" button that you simply need to push to activate closed captioning
Locate the closed captioning option in your television's menu if there is no "CC" button on your remote. To do this, push the "menu" button on the remote control. The closed captioning option will probably be in the same section as the language function.
Set the closed captioning option to "on." Within several seconds, you should see the text appear on your screen.
To use closed captioning for DVDs, look for the "CC" label on the lower back section of the DVD case where it lists audio information. Turn on your TV's closed captioning and you should see the captioning like you do on a television program. Alternately, some DVDs include English subtitles that you can turn on in the setup/language menu of the DVD.
Thank you.
Aug 28, 2009 | Televison & Video
Closed caption
Have you verified that the programs you're viewing have closed-captioning service? Some programs and stations do not support CC on programs and commercials. The closed captions are accessed on the HD52W56 by pressing Menu > Preferences > Closed Captions on the remote control and following the onscreen instructions. Select CC1(the first choice for caption); this is the format most stations send in. Good luck!
Jan 25, 2008 | RCA HD52W56 52" Rear Projection HDTV
Sony DVP-NS575P DVD Player Logo
712 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
