Will a d10 300 receiver work with a slimline dish
Will dish network 510 receiver work in uhf with dish 21.1 remote
No, the 510 receiver does not have a UHF input. http://manuals.solidsignal.com/DVR510.pdf You can upgrade to a 512, 612, 625, but would need your installation upgraded to be compatable (Dish Pro to Dish Pro Plus).
Sep 03, 2012 | DISH Network 322 DTV Receiver
Bought new Vizio 55"
Had same problem - turned off Adaptive Lumina, Backlight control, and Ambient light sensors on the Vizio advanced picture settings and the Dish remote now works. Vizio was emitting an infared signal that interfered with the Dish remote signals with these settings on. TV still works and looks just fine... But best of all Dish remote works too.
Nov 08, 2010 | DISH Network IR Remote Control
My 311 is connected to a dish 100.2. It has worked fine for a while. A few days ago it lost signal. I ran a swith check and it said there was fewer satilites than normal. Well I checked out the dish and it...
firerun1,
When you get the message 836, found fewer satellites than previously detected, it usually indicates a problem with a component between the dish and receiver. Normally a tech needs to be sent out to find the problem and to fix it.
Depending on the number of receivers you have active on your account, you may have a loose cable to that receiver if other receivers are working okay. If you have a switch between the dish and receiver, a port on the switch may be bad. If this is occurring on all your receivers, you'll need to call Customer Service to setup a Tech visit.
I hope this helps.
Ray Calo
DISH Network
Nov 07, 2010 | DISH Network 311 DTV Receiver
Will this receiver work with a dish 500 antenna to receive standard channels only
Hello, this is Matthew Gonzales with DISH Network customer service. To answer your question, yes the ViP211 will work with a dish 500. It will receive the standard channels as you asked, but if you wish to get HD, the dish on your home will need to be upgraded. Hope this helps!
Aug 28, 2010 | DISH Network ViP 211 DTV Receiver
Strange problem with a Dish 2800 receiver: during the daytime, it works fine. Starting about 5:00 or 6:00 PM, it starts responding poorly to the remote. That remote works fine on other receivers in the...
Hey there! This is Becki Barned, with Dish Network customer service! The problem that you may be having is with interference with the remote. Depending on how much light is shining directly on the receiver, such from a lamp in the evening, or the sunset, this can interfere with the remote responding to the receiver. If you have glass in front of your receiver, that can cause it too. Try to remove all objects or lights from the front of the receiver, and it should work fine!
Aug 26, 2010 | DISH Network DISH-2800 DTV Receiver
Will a Dish network 1000 satellite dish work with my VIP 211 reciever?
It should as long as it is pointed to the correct orbital locations,
Jun 26, 2010 | DISH Network ViP 211 DTV Receiver
Even Transponderds Zero
Typically that indicates a bad LNB or connection to the LNB. Try moving the line to one of the other three ports on the LNB and if that doesn't work then you will need to replace it
May 18, 2017 | Directv HR10-250 DTV Receiver
Dish IR Remote 20.0 has problems after sunset.
The problem for me was the TV giving off IR signals that interfered with DISH's poorly designed remote. When the TV's room ambient light sensor was turned on and it became dusk outside the DISH remote would stop working. Moving the receiver away from the TV helps but the problem is not eliminated until the light sensor is turned off.
Until DISH corrects this poor design there may be no other viable solution.
Jul 09, 2009 | DISH Network IR Remote Control
Dimmer switch interference
i have seen this before you have back feed thru your lines somewhere there i no ground and it is reffeding through your equipment. honestly he techs were wright i wouldnt or any of my guys wouldnt touch it because u realy need a certified electrician to come ou and find the problem andfix it before it runs your slimline dish and eciever. The switch u installed u did run all four 4 wires from he dish to the switch didnt you. Check all lines of coax but if u didnt run all four 4 lines then u will have problems. I still think u need an electrician.
Good luck,
Please rate
Jan 06, 2008 | Directv D10 DTV Receiver
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
