Question about HP Pavilion dv6000z Notebook
Initializing error :registry value is not of binary type
Installing agv antivirus there is an error
  • 33 Answers
First of all, its AVG, not AGV. Now the solution.
You may be trying to install AVG when you have already one antivirus program running. OR you had once installed AVG sometimes in the past, but uninstallation was not properly done. Hence it is showing registry key error.
1. If you are running any anitvirus prog now, first uninstall it. Then restart the machine.
2. Now you try install AVG. it should install. if not, try the following
Go to system restore and create restore point for safety.
go to run and type regedit and then enter
Press cntrl + F for finding earlier registry keys of AVG. Try to find out all old registry keys amd delete them all.
Restart the machine. Its DONE.
Posted on Jan 26, 2009
Cant access to hel menu when i m pressing the F1 key
Use the System Configuration utility (Msconfig.exe) to extract the original Helpctr.exe file to the Windows\PCHealth\HelpCtr\Binaries folder on your hard disk. To do this, follow these steps:
  1. Start your computer in Safe mode. To do this, restart your computer, press and hold down the CTRL key after your computer completes the Power On Self Test (POST), and then click Safe Mode on the Startup menu.
  2. Click Start, and then click Run.
  3. In the Open box, type msconfig, and then click OK.
  4. In the System Configuration Utility dialog box, click Extract File.
  5. In the Specify the system file you would like to restore box, type helpctr.exe, and then click Start.
  6. In the Restore from box, click Browse, and then browse to the C:\Windows\Options\Install folder, where C: is the drive on which Windows is installed, and then click OK.
    NOTE: Use C:\Windows\Options\Install if you installed a Windows Me retail product, or C:\Windows\Options\Cabs if your computer manufacturer installed Windows Me.
    Windows Me installs the cabinet files, by default, in the Windows\Options\Install folder. If these files are on your computer, you do not need your Windows Me CD-ROM because you can extract the Helpctr.exe from the appropriate folder on your hard disk.
  7. In the Save file in box, click Browse, and then browse to your C:\ drive (where C is the drive on which Windows is installed), and then click OK.
  8. Click OK to extract the file.
  9. Click Yes to the The destination folder C:\ does not exist. Do you want to create it? message.
  10. Click OK to the The file has been successfully extracted message, and then click OK to close the System Configuration Utility dialog box.
  11. Start Windows Explorer: Click Start, point to Programs, point to Accessories, and then click Windows Explorer. Locate the Helpctr.exe file that you extracted to your drive C.
  12. Move the Helpctr.exe file to the C:\WINDOWS\PCHealth\HelpCtr\Binaries folder by right-clicking the Helpctr.exe file and selecting Cut. Navigate to the Binaries folder, right-click the folder, and then click Paste on the shortcut menu.
  13. Click Start, and then click Run.
  14. In the Open box, type regedit, and then click OK.WARNING: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk.
  15. Locate the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Helpctr.exe In the right pane, verify that the key is set to the following value: C:\Windows\PCHealth\Helpctr\Binaries\Helpctr.exe If this registry entry does not exist, create a new entry. To do this, follow these steps:
    1. Locate the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths
    2. Right-click App Paths, point to New, and then click Key.
    3. Type Helpctr.exe.
    4. In the left pane, click Helpctr.exe.
    5. In the right pane, right-click (Default), and then click Modify.
    6. In the Value data box, type C:\Windows\PCHealth\Helpctr\Binaries\Helpctr.exe, and then click OK.
  16. On the Registry menu, click Exit to quit the Registry Editor.
May 16, 2009 | Microsoft Windows XP Home Edition
Tip
What is the Registry?
The Registry is a database used to store settings and options for the 32 bit versions of Microsoft Windows including Windows 95, 98, ME and NT/2000. It contains information and settings for all the hardware, software, users, and preferences of the PC. Whenever a user makes changes to a Control Panel settings, or File Associations, System Policies, or installed software, the changes are reflected and stored in the Registry.
The physical files that make up the registry are stored differently depending on your version of Windows; under Windows 95 & 98 it is contained in two hidden files in your Windows directory, called USER.DAT and SYSTEM.DAT, for Windows Me there is an additional CLASSES.DAT file, while under Windows NT/2000 the files are contained seperately in the %SystemRoot%\System32\Config directory. You can not edit these files directly, you must use a tool commonly known as a "Registry Editor" to make any changes (using registry editors will be discussed later in the article).
The Structure of The Registry
The Registry has a hierarchal structure, although it looks complicated the structure is similar to the directory structure on your hard disk, with Regedit being similar to Windows Explorer.
Each main branch (denoted by a folder icon in the Registry Editor, see left) is called a Hive, and Hives contains Keys. Each key can contain other keys (sometimes referred to as sub-keys), as well as Values. The values contain the actual information stored in the Registry. There are three types of values; String, Binary, and DWORD - the use of these depends upon the context.
There are six main branches, each containing a specific portion of the information stored in the Registry. They are as follows:
* HKEY_CLASSES_ROOT - This branch contains all of your file association mappings to support the drag-and-drop feature, OLE information, Windows shortcuts, and core aspects of the Windows user interface.
* HKEY_CURRENT_USER - This branch links to the section of HKEY_USERS appropriate for the user currently logged onto the PC and contains information such as logon names, desktop settings, and Start menu settings.
* HKEY_LOCAL_MACHINE - This branch contains computer specific information about the type of hardware, software, and other preferences on a given PC, this information is used for all users who log onto this computer.
* HKEY_USERS - This branch contains individual preferences for each user of the computer, each user is represented by a SID sub-key located under the main branch.
* HKEY_CURRENT_CONFIG - This branch links to the section of HKEY_LOCAL_MACHINE appropriate for the current hardware configuration.
* HKEY_DYN_DATA - This branch points to the part of HKEY_LOCAL_MACHINE, for use with the Plug-&-Play features of Windows, this section is dymanic and will change as devices are added and removed from the system.
Each registry value is stored as one of five main data types:
* REG_BINARY - This type stores the value as raw binary data. Most hardware component information is stored as binary data, and can be displayed in an editor in hexadecimal format.
* REG_DWORD - This type represents the data by a four byte number and is commonly used for boolean values, such as "0" is disabled and "1" is enabled. Additionally many parameters for device driver and services are this type, and can be displayed in REGEDT32 in binary, hexadecimal and decimal format, or in REGEDIT in hexadecimal and decimal format.
* REG_EXPAND_SZ - This type is an expandable data string that is string containing a variable to be replaced when called by an application. For example, for the following value, the string "%SystemRoot%" will replaced by the actual location of the directory containing the Windows NT system files. (This type is only available using an advanced registry editor such as REGEDT32)
* REG_MULTI_SZ - This type is a multiple string used to represent values that contain lists or multiple values, each entry is separated by a NULL character. (This type is only available using an advanced registry editor such as REGEDT32)
* REG_SZ - This type is a standard string, used to represent human readable text values.
Other data types not available through the standard registry editors include:
* REG_DWORD_LITTLE_ENDIAN - A 32-bit number in little-endian format.
* REG_DWORD_BIG_ENDIAN - A 32-bit number in big-endian format.
* REG_LINK - A Unicode symbolic link. Used internally; applications should not use this type.
* REG_NONE - No defined value type.
* REG_QWORD - A 64-bit number.
* REG_QWORD_LITTLE_ENDIAN - A 64-bit number in little-endian format.
* REG_RESOURCE_LIST - A device-driver resource list.
on Dec 02, 2009 | Computers & Internet
I WANT TO UNINSTALL AVG ANTIVIRUS,BUT WHEN I DO THIS AN ERROR HAS BEEN OCCURED AND THAT IS: LOCAL MACHINE:INSTALLATION FAILED INITIALIZATION: ERROR:REGISTRY VALUE IS NOT OF A BINARY TYPE. PLZ HELP MY...
Install Revo Unistaller (available from: www.revouninstaller.com) and use it to unistall AVG. Also you could try disabling / stopping avg before trying to unistall it.
Mar 21, 2009 | Microsoft Windows XP Professional
Error in registry....
Maybe, you have registry problem.
  • Just restart the system
  • Press F8 while starting the windows
  • Select "Safe Mode" options
  • After restarting, a window will come up on screen
  • select No
  • Just select the past date from the date calender. You must select a past date from which you were not facing problem.
  • A restore process will start automatically.
  • press okey and finish
  • restart the computer.
Dec 10, 2008 | Microsoft Windows XP Professional
Missing dll
When you start the computer, you see an error message similar to " S32evnt1.dll. An installable Virtual Device Driver failed DLL initialization."
Solution:
To fix the problem, edit the registry and restart the computer. Then update the Symevent files and restart the computer again.
Follow the directions for your version of Windows:
To edit the Windows XP registry
  1. On the Windows taskbar, click Start > Run.
  2. In the Run dialog box, type regedit
  3. Click OK.
  4. Go to the following key:
    HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlVirtualDeviceDrivers
  5. In the right pane, delete the VDD value.
  6. In the left pane, right-click the VirtualDeviceDrivers key, and then click New > Multi-String Value.
  7. Type VDD for the name of the new value.
  8. Exit the Registry Editor.
  9. Restart the computer.
To edit the Windows 2000 registry
  2. In the Run dialog box, type regedt32
  3. Click OK.
  6. On the Edit menu, click Add Value.
  7. In the Value Name box, type VDD.
  8. In the Data Type drop-down menu, click REG_MULTI_SZ, and then click OK.
  9. Exit the Registry Editor.
  10. Restart the computer.
To update the Symevent files
  1. Follow the directions in the document Updating the Symevent files.
  2. After you update the Symevent files, restart the computer.
Oct 22, 2008 | Compaq Presario 5000 PC Desktop
Avg8 error uninstalling
this is a common error that appear in windows operating sysetm.
reinstall the avg8 and then uninstalled it. if you cn't get the avg8 install the latest one and then uninstall it. it should take care the old one at the same time.
Oct 16, 2008 | Microsoft Windows XP Home Edition
How could i remove tr/Agent.Abt.34 virus what is the antivirus that can remove this such virus
You can run AntiVir, then Spybot and Adaware, Just run them in safe mode because the virus runs in residence..
Dec 30, 2007 | Computers & Internet
Symantec client security
here u got:
Question/Issue:
When you install Symantec AntiVirus or Symantec Client Security, you see the error message "1920 Service Defwatch failed to start. Verify that you have sufficient privileges to start system services."
Solution:
This problem has more than one cause, so more than one solution is provided. To fix the problem, try each of the following solutions in the order that they appear.
Confirm that you have the correct rights and permissions
The most common cause of this problem is incorrect rights or permissions. Make sure that you have Local Administrator rights to the target computer. Confirm that no restrictions on the Local Administrator or Domain Administrator accounts exist.. Follow the directions in the document Troubleshooting Symantec AntiVirus Corporate Edition installations: Checking rights and permissions.
Confirm that the Defwatch service has the correct settings
This problem can happen when the Defwatch service account has incorrect settings. Make sure that the Defwatch service is set to log on as the Local System account. Confirm that the service is allowed to interact with the desktop.
To confirm the Defwatch service settings
  2. In the Open box, type services.msc and then click OK.
  3. Do one of the following, depending on your program version:
    • For Symantec AntiVirus 10.x, right-click the Symantec AntiVirus Definition Watcher entry.
    • For Symantec AntiVirus 9.x and earlier, right-click the Defwatch entry.
  4. Click Properties.
  5. On the Log On tab, confirm that the Local System Account is selected and that "Allow service to interact with desktop" is checked.
  6. Click OK.
Look for a Program file at the root of the OS drive.
If McAfee antivirus 4.03 or 4.5 was installed on the computer, look for a file that is named "Program" at the root of the OS drive. If the file exists, delete it.
Delete leftover registry keys from a previous version of Symantec or Norton AntiVirus Corporate Edition
Leftover registry keys from a previous version of Symantec or Norton AntiVirus Corporate Edition can cause this problem. Delete the registry keys and then install Symantec AntiVirus again.
WARNING: In the next steps you will edit the Windows registry. Back up the registry before you make any changes to it, because incorrect changes to the registry can result in permanent data loss or corrupted files. Modify only the registry keys that are specified.
For instructions, see How to back up the Windows registry.
To delete the registry key
  2. In the Open box, type the following text:
    regedit
  3. Click OK.
  4. In the Windows Registry Editor, in the left pane, click My Computer.
  5. On the Edit menu, click Find.
  6. In the Find what box, type the following text:
    VirusProtect6
    Delete all keys and values that contain this string.
  7. Go to and delete the following key:
    HKEY_LOCAL_MACHINE\SOFTWARE\INTEL\DLLUsage\VP6
  8. Exit the Windows Registry Editor.
If the problem persists, manually remove the previously-installed version of Symantec AntiVirus. To find directions for your product version, read Manual uninstallation documents for Symantec Client Security products
And please if it was helpfull for you rate this solution as SOLVED
Nov 02, 2007 | Computers & Internet
Sony DVD RW AW-G170A will not install
Code 39 loadTOCNode(2, 'moreinformation'); Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Resolution:
Reasons for this error include a driver that is not present; a binary file that is corrupted; a file I/O problem, or a driver that references an entry point in another binary file that could not be loaded.
Uninstall the driver, and then click Scan for hardware changes to reinstall or upgrade the driver.
On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
Is that the actual model number?
Nowhere does that item exist on SONY's support page.
If so, it may no loger be supported....
Keep me posted.
Sep 26, 2007 | Sony (1-796-293-13) Plug-In Module DVD...
HP Pavilion dv6000z Notebook Logo
505 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
