Question about Brother MFCJ410w AllInOne InkJet Printer
Clean brother mfc-j410w print head - Brother MFCJ410w AllInOne InkJet Printer
the kowalski
  • 86 Answers
SOURCE: Brother MFC 5840 won't print red. ink is full. printer head clean
If the regular cleaning does not work, you can try the power purge. Perform it by doing the following:
  • Press Menu, 2, 8, 6, 4 quickly (within about 1-2 seconds from the menu-press, all five buttons should been placed, in order).
  • The display and some buttons should start flashing, and it should say "Maintenance".
  • Press 7, 6.
  • It should say "CLEANING ALL", press right arrow key until you get "CLEANING MAGENTA" or similar.
  • Press 3, it should now change to POWER_P or P_PURGE. Press Mono/Black Start.
  • The display should say "Cleaning", when it's done, it will say Maintenance again.
  • Press 99 and you will leave Maintenance mode, you can now try and see if magenta works again.
If it doesn't work, you'd probably need chemicals to clean the ink tubes. But, this power purge should work.
Posted on Jun 05, 2009
SOURCE: Brother MFC-620CN print head clogged
Open up amd release blue stay at bottom by pressing edges inward and pulling slightly forward. Remove the 4 screws, 2 small plastic covers and the earth screw. Pull out the ribbon connector near the USB plug. Unplug the 2 white and one red connectors, noting how the cables fit in. Fully open the lid and pop the scanner part off. Remove all the ink cartridges. Now using a flat screwdriver unclip the top of the base all the way round and lift off. The print head is now accessible. Rotate the white paper feed cogs to release the print head. Slide it all the way to the right and remove it by tilting the back edge upwards. You mow have access to the print head!!!!
Posted on Jun 02, 2009
cene765
  • 787 Answers
SOURCE: I have a brother mfc-420cn. I am getting a unable to clean messa
Do you mean "unable to clean"?If it this follow this instruction.
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If numberis over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Posted on Nov 02, 2009
cene765
  • 787 Answers
SOURCE: unable to clean print heads
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the error is 48 - defective print head cable or circuit board.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Posted on Nov 24, 2009
SOURCE: brother mfc-215c unable to clean?
I have the same problem my printer (a MFC-215C) is unable to clean and when I press Menu/set I do not have "Black print"? So what do I do now?????? HELP... Thanks Nathalie
Posted on Apr 30, 2010
Brother MFC J4120W unable to Print 4F
Error 4f appears to be an electrical problem in the print head, see this link:
Fix your printer
Jan 30, 2015 | Brother MFC-J410W
Prints one page only
I need you to tell me if the control panel shows an error.
In most case this printer needs cleaning cartridges. You can find the procedure in the video below.
Apr 06, 2014 | Brother MFC-J410W
Why black ink does not print
Clean print head in, menu, ink management. If unsuccessful after 2-3 cleans, replace print head.
Apr 03, 2014 | Brother MFC-J410W Wireless Compact...
How do you repair a 4F error message for Brother MFC 2550CW
machine error '4F' indicates print head or the PH PCB is faulty.
Mar 16, 2014 | Brother MFC-J410W Wireless Compact...
Brother printer MFC-J415W error unable to cleaning5A
can any one tell me what is the price of printer head & maintance unit of brother printer MFC-J415W. in INDIA.
PLEASE MAIL ME ON roomysamir@gmail.com
Sep 04, 2012 | Brother Mfc-j410w All-in-one Inkjet...
Brother Printer Jamming Issues
Do you have ink smudges on your paper? If so then you need to take out your roller clean it with alcohol really good and that should fix the problem.
Apr 18, 2012 | Brother MFC-J410W Wireless Compact...
Can't print from my computer on mfc j410w
Please follow the steps below: 1. Disconnect the mfc from the computer. 2. Uninstall it through Control Panel->Add Remove Progs. 3. Reboot. 4. Reinstall the drivers from the CD that came with the device. 5. Re-connect the device 6. Allow enough time for Windows to autodetect and load its drivers. 7. Happy printing.
Jul 23, 2011 | Brother MFCJ410w AllInOne InkJet Printer
Print head for brother mfc420cn
Cleaning the print head
To ensure good print quality, the MFC will regularly clean the print
head. You can start the cleaning process manually if needed.
Clean the print head and ink cartridges if you get a horizontal line in
the text or graphics on your printed pages. You can clean Black only
or three colors at a time (Cyan/Yellow/Magenta), or all four colors at
once.
Cleaning the print head consumes ink. Cleaning too often uses ink
unnecessarily.
Caution
Do NOT touch the print head. Touching the print head may cause
permanent damage and may void the print head’s warranty.
1 Press Ink.
2 Press ▲ or ▼ to select Cleaning.
Press Menu/Set.
3 Press ▲ or ▼ to select Black, Color or All.
Press Menu/Set.
The MFC will clean the print head. When cleaning is finished,
the MFC will go back to standby mode automatically.
If you clean the print head at least five times and the print has
not improved, call Brother Customer Service
Hope that helps,
Take Care,
Michael
Nov 13, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MFCJ410w AllInOne InkJet Printer Logo
1,534 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
