Question about Aloha Housewares (93645) Ceiling Fan
What doesthe small yellow wire connect to - Aloha Housewares (93645) Ceiling Fan
    Problem Solver:
  • 13 Answers
It is normally coming out of a small black box, it is a capacitor, actually a pair of capacitors in one box, it is used to set the speeds.
If it is a three speed fan then the wire will go to the empty port on the pull switch that sets the fan speen
Posted on Jan 26, 2009
Why doesthe revlimiter kick n at 9000 rpmonmy hayabusa?
Did you double check any harness or wiring that may have been disturbed ?
Jul 30, 2015 | Cars & Trucks
I replaced the belt and got the dryer back together but have one small green wire with a yellow stripe that I dont know where it connects
Dear Sir:
The small green wire with yellow stripe is Ground or earth. is attached to the chassis or frame of the machine. See the diagram.
May 23, 2012 | Roper REX4634KQ Electric Dryer
Please help western australia.britax trailer lights not connected properly.this is how currently connected.left hand trailer light top pin yellow,side pin green,bottom left pin brown,bottom right pin...
plug wiring is in
the following web site
ww.narva.com.au
the site is very specific for 7 pin , 6 pin and rectangular to round 7 pin
the small tag that you have to use to put the plugs together is identified at the top oh the round plugs
you can get the site by googling and typing in ---trailer plug wiring australia
Apr 02, 2017 | GPS
Need to find out what color wires to use to fix my enforcer infared security camera the wires got cut. Color wire for splicing the wire on.
I have a small color security camera with infrared that is intact. This camera is an exclusive Harbor Freight Tools distributed product. I have attached pics of it, the last pic of the small connecting box looking into the connection starting from left to right are 4 wires 1=yellow 2=blue 3=orange 4=white. I hope this is of some help to you. I unfortunately don't have the other end of the connector and am looking for pinouts to hard wire it to my monitor. If some one has this info please pass it on to my email zimpmd at aol. Thank You Michael Zimpleman
Jun 05, 2011 | Cameras
On the washer what doesthe code f11 mean
This is a communication error between the motor control unit and the central control unit.
Could a loose connection or a bad wire harness.
Copy and paste the Factory Service manual referenced below for detailed information.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Sep 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Pioneer DEH-4100 No power
if you dont have a 12volt power supply, you can test the headunit by connecting your yellow, red, and black wires directly to a car battery. connect the yellow and red wires to the positive terminal and the black wire to the negative terminal. Before doing this make sure the red wire has the small inline resistor supplied by pioneer and the yellow wire has a 10amp fuse.
May 19, 2009 | Pioneer DEH-P4100
Broken coax connection on back of unit
If you are comfortable doing some small repair work, you might be able to fix this with stuff you have laying around.
All you need is:
1 - 8" piece of coaxial cable with male connector on one end
1 - set of RCA cables (Red/White/Yellow)
1 - coaxial coupler
2 - small wire nuts
electrical tape
Take the back housing off of your TV. You may have to unscrew the small nut holding the threaded connector to the TV. This threaded connector should connect to the motherboard with a male RCA prong that should be soldered to the component on the motherboard. You will need to carefully cut
& remove the old soldering & wiggle the connector off. This is the hardest part, but it WILL come off with a little trying.
Now get your coax cable and strip off about 2" of the black outside housing ONLY. Your solid copper` interior cable should be protected by a small plastic coating which is covered in braided wire. You'll need to be careful not to cut the braiding off. Untangle the braiding down to where your cut stops and try and get it all on one side of the cable so you can twist it all together and make a nice wire. Now strip about an inch off of your interior plastic sheathing to reveal the small solid copper wire on the very inside.
Get your RCA cable and cut about 6" off of the one yellow side. Follow the same process above to get a braided sheathing wire and a solid copper wire. Attach this yellow wire to the coaxial cable by twisting the two braided wires together and the two solid copper wires together. Use your wire nuts & electrical tape to secure your connections making sure none of the wires can touch each other.
Connect the yellow cable's male prong into the component on the motherboard and attach your coaxial coupler to the male end of your coaxial cable. If you saved the small nut from earlier, you can re-attach this new coupler to the housing on your TV. Screw your housing back on the TV and you should be good to go.
Jan 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Broken coaxial
All you need is:
1 - coaxial coupler
2 - small wire nuts
electrical tape
Nov 10, 2008 | Samsung LNT4066F 40 in. LCD Television
HELP!!! Help wiring new motor for CKL60-1
  1. This is what your wiring should look like if you are using two caps. then you should be using a potential relay as well. This is the diagram for using a potential relay. Hope it helps you.
Aug 25, 2008 | Goodman CKL60AR60 Air Conditioner
Aloha Housewares (93645) Ceiling Fan Logo
97 people viewed this question
Top Aloha Housewares Dryers Experts
Steve
Cesar Quant
Cesar Quant
Craig Butler
Craig Butler
Are you an Aloha Housewares Dryer Expert? Answer questions, earn points and help others
