Question about Fantom Drives 300 GB Hard Drive
Weird noise Whenever I turn on my external hard drive it makes these weird chirping noises. It beeps twice about every 3 seconds then eventually gives up and shuts itself off. My computer seems to know that the device is there but I can't do anything with it.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 198 Answers
These drives are fragile! Idiotic design--perched upright instead of flat. Knock it over once, and it may be history. If you hear squeaking, back up all your unique data on the drive elsewhere, or you may be in for total loss.
Posted on Jan 01, 2008
The same is happening to me though it worked yesterday Sigh ill put into a comp and take it out of case
Posted on Nov 27, 2007
    Novelist:
    Champion:
  • 254 Answers
The drive may be defective. You might see if the manufacturer has a utility to do diagnostics on it. At least some of these external drives are merely a desktop or laptop drive with appropriate electronics in an external case. You could possibly disassemble the case, remove the drive, set the master/slave jumpers properly and try installing it in a standard computer, & see what kind of results you get there. If the drive is defective, then data recovery would be difficult at best, perhaps only available via a business specializing in such.
Posted on Jul 16, 2007
SOURCE:
Beeping hard drive ?
Beeping or chirping?
Check it in a PC if you can. If its more of a chirp than a beep your HDD inside likely failed.
Dec 01, 2013 | Hitachi 2TB Touro Desk DX3 USB 3.0...
Chirping cricket sound
oopppsss.. time for replacement
Jun 19, 2017 | Western Digital 500GB My Passport...
My Maxtor One Touch 3 (300gb) external hard drive is not being recognized by my computer (or my laptop). I plug it in to the back usb port, turn the Maxtor on, then the light turns on, but the computer is...
Hi Jane,
If you are using Windows as an operation system, you can try to install the HDD manually
Click on the Start button
Right click on My Computer
click on properties at the bottom
look for the Hardware tab and click on it
look for the Device Manager button and click
look for Action in the top menu
then scan for new hardware
If this does not work, look on the Device Manager screen and you will see + Disk Drives
click on the + and it will list the drives that it sees
if you see the external HDD uninstall it and reboot
Hope this helps
Dec 22, 2010 | Computers & Internet
My 500gb wd "my book" is making weird noises and wont show up
The whirring noise is the heads trying to read hard drive and then the weird rubbing screech sound and not showing up in your pc. sounds like the drive is dead.
Jul 14, 2010 | Western Digital My Book Essential 500GB...
I own a 320GB seagate freeagent hard disk and accidentally unplugged it from my laptop a few days back. It gives a beeping sound whenever I try plugging it into a laptop and I've tried 3 laptops, all gave...
Connect the 320GB HDD before switching ON the laptop and try to repair using scandisk option to repair the drive. Also use chkdsk /f option in command line mode.
Revert back for more assistance.
Jan 20, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My WD external hard drive does not stay recognized on my computer. When I first plug it in it makes the ding/beep noise and shows up on "my computer" but after a few seconds it makes the ding/beep noise...
Try the hard drive on another computer to see if it is the external or a laptop interface problem. There are EIDE/SATA to usb adapters that you can connect a hard drive to that the computer will then read as an external hard drive. The problem with external HDDs is the usb interface built into them, these are mounted on controller cards and that is ususally where the failure occurs.
Jan 10, 2010 | Western Digital Passport 320GB External...
External Hard Drive doesn't work
There is a (laptop-size) hard-drive inside the case, and that hard-drive is failing. As it spins, it generates those noises, like a dying dinosaur. If it still is under warranty, exercise the warranty, and replace it. If the warranty has expired, tough luck.
May 21, 2009 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
I dropped my Western Digital 1TB [(2) 500 GB?] book on the floor now it won't boot up, and it makes strange clicking sounds like it's trying to, but no go. Is there hope? I have a WD My Book 1 TB Home...
The drive is indefinately junked, however I would not fully give up as it may still be honoured under warranty. The warranty is great on these drives. As for the information I would not worry too much about any one reading it off thats a lab job. If you don't want to pursue warranty and still want to destroy the data then open the drive(s) up and you will find very conveniently inside a VERY strong magnet which you could run over the platters. The magnet is hard to get out because of its magnetic strength but its located at the pivit point of the head arm.
If this info is handy rate me kindly
May 08, 2009 | Western Digital My Book Essential 1TB...
Beeping sound
Sounds like the motor got stuck.
Is it melody-like beeping?
Anything similar to these: http://datacent.com/hard_drive_sounds.php
Nov 09, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Open Questions:
Fantom Drives 300 GB Hard Drive Logo
885 people viewed this question
Top Fantom Computers & Internet Experts
michael ramos
michael ramos
Ekse
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
