Olympus r27 pedal issues - Computers & Internet
My Olympus RS25 foot switch stopped working.
Yes, you can assume that after 6+ years, the pedals have gone bad and you need new ones.
Jan 08, 2016 | Olympus AS-2300 PC Transcription Kit
HOW TO INSTALL OLYMPUS DRIVER FOR FOOTSWITCH RS24
Hello your foot pedal don't need drivers but you need for sure a transcription software, the pedal will required a program to work together to control your audio files for example you can get a Olympus transcription software that will be compatible with your pedal, at http://www.tvps.com/Products/Olympus-AS-5002-DSS-Player-Pro-Version-5-Transcription-Software---New__OL-AS-5002.aspx or you also can used http://www.tvps.com/Products/Olympus-AS-7002-Pro-ODMS-R6-Transcription-Software---New__OL-AS-7002.aspx
May 01, 2014 | Olympus AS-2300 PC Transcription Kit
Nikon d50 error code r27
r27 is not an error code. the camera is telling you that you can take 27 photos (app) before the camera's internal memory is full and it has to stop and write data to the SD card. This is a normal function of this camera.
If the camera will not fire, check to make sure that there is a SD card inserted. If not, set the camera menu so it will fire without a card. Also check to make sure there are no plastic bits from the broken lens jamming the shutter or mirror. Also, try pressing in the reset button on the bottom of the camera.
Feb 15, 2013 | Nikon D50 Digital Camera with 18-55mm Lens
I have just installed the software for an Olympus DS 2400 and cannot get the foot pedal to work.
The player standard software that comes with your DS 2400 does not support the Olympus wav pedal (RS 27). You need the transcription version of software, the AS 2400 transcription kit (169.95) or, just the software, Player Standard T (99.95).
Cheers,
cost-plus.com
Jan 25, 2011 | Olympus DS-2400
HP R27 says "Processing..." for minutes at a time & won't allow
press the putton harder than slowly let up and it should take the photo if not just tinker with it i had the same problem you kinda just learn
Jan 23, 2010 | HP Photosmart R927 Digital Camera
Foot pedal operation
Hello no really you probably have a bad pedal you can buy a replacement pedal the model is RS12 at http://www.tvps.com/Products/Olympus-RS12-Foot-Pedal---New__OL-RS12.aspx
Dec 26, 2009 | Olympus Pearlcorder T2020 Desktop Cassette...
I require a replacement foot pedal for an Olympus Pearlcorder T2020, I do not have one at all.
The foot pedal model for this unit is Olympus RS-12 you can fine one at TVPS online The model OL-RS12 the cost $32.00 for a New one
Nov 24, 2009 | Olympus Pearlcorder T2020 Desktop Cassette...
Nikon D300 When I depress the shutter half way or fully on my D300 the frame counter reads r27 and the lens (any previously compatible Nikkor lens) will not auto focus. The camera is not set in burst mode...
Only reason the lens will not auto focus when you depress the shutter half way is due to either lens AF switch is set to Manual OR camera body's focus system is on M. There is 3 way toggle switch below the synch port around the lens mount. It should be set to C or S in order for auto focus to work. If all the settings are correct and even "AF-ON", next to rear dial doesn't activate auto focus then the issue maybe in the setting or the body itself. As for the buffer reading r27, I think mine displays r## regardless of burst/continuous mode.
Jul 13, 2009 | Nikon D300 Body Only Digital Camera
RS-25 & RS-27 Foot Pedal not working with Vista x64
I had the exact same problem. Per Olympus you have to buy the RS 27 foot pedal. It IS compatible with Vista 64bit. RS 25 which is what I have IS NOT compatible with Vista 64bit.
Cheapest I found online is $43+ shipping for RS 27 foot pedal.
There is a free upgrade to DSS Player 7 on Olympus website that you will have to do for it to work with RS 27 foot pedal.
Jun 05, 2009 | Computers & Internet
Driver Issues
My dictation pedal for the Olympus AS-4000 used to work on windows XP, but I upgraded to windows Vista and and the foot pedal no longer works. I have tried it on another XP machine and it works fine, so it can't be the foot pedal.
I have downloaded a patch from the internet, but unfortunately this does not seem to have resolved the issue.
I have contacted olympus twice and they have been very unhelpful.
Dec 07, 2006 | Olympus AS-4000 Desktop Digital Voice...
Computers & Internet Logo
David Payne
David Payne
