Question about Whirlpool 24 in. GU2500 XTP Built-in Dishwasher
Flashing clean light GU2700
Why won't the clean light stop flashing on my GU2700 whirpool dishwasher
  • 338 Answers
SOURCE: my whirpool dishwasher model du930pwps2 stopped working
sounds like the fuse on the control blew. you can replace the fuse for around $20 or you can cut and splice the wires for free. If that doesnt work then you may have a loose conection in your junction box under the dishwasher.
Posted on Dec 01, 2008
  • 161 Answers
SOURCE: whirpool dishwasher
if blinks 7 x and pauses,you have a problem w/in heat circuit,inspect the element for cracks or breaks.the actual door latch could be out of alignment also find the latch and bend it downward ever so slightly to assure good connection at door switches. to clear code push hitemp-airdry-hitemp-airdry,this will allow you to run cycle if code comes back,you may need servicer
Posted on Mar 10, 2010
  • 552 Answers
SOURCE: whirpool dishwasher quiet partner 2
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Posted on Mar 07, 2011
Macmarkus
  • 2605 Answers
SOURCE: I have a Whirpool DP1040XTXQ
Hello, Welcome to FixYa.
Based on your description, "clean light flashes " this is actually an error code as you may or may not know associated with the heating process. What typically happens is poor water circulation preventing the water from heating properly.
To resolve this, I'd start with the following...the wash pump area. You`ll need to follow these steps to clean it.
1 ) Remove the turbo wash tube if applicable to your model, it pulls off, i.e.
2 ) Spray arm removal. hold the center nut and spin the arm.
3 ) Now you can remove the upper spray arm supply tub or referred to sometimes as "rear feed cap".
a ) lift to depress the rear tab, i.e.
b ) Then twist the feeder to the right ( clockwise ), i.e.
4 ) Now you can remove the center nut...
Then remove the four # 20 torx head screws holding the filter in place, and lift the filter out.
Below the filter you`ll find food debris, undissolved detergent etc, but also a cover with a single #10 torx head screw to remove and the cover will pull straight up and out. the arrows from left to right in the image indicate...
1) screw location
2) tab to pull up on
3) the latch you may need to twist to the left to remove the cover
i.e.
Now you should see the chopper and screen assembly, it too can be clogged up pretty bad, clean it best you can...you don`t really want to remove this part.
If my explanation is not clear enough, here`s a link which provides a pretty good video of how to do this, these guys aren`t pro`s but the "how to" video is pretty thorough nonetheless.
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
Once these actions have been performed you'll need to clear the error code. to do so is as follows.
Press the following buttons in this sequence...
HEATED DRY - NORMAL, HEATED DRY - NORMAL, HEATED DRY - NORMAL
This diagnostic cycle may take approx. 15-20 minutes to complete. Let it proceed through to completion and you should be good to go...unless the heater itself is at fault or a wire has vibrated loose from the heater...those are steps to follow if OR when necessary.
Let me know how you make out, please keep me informed if you need further assistance or anything is unclear. Please take a moment to rate me assistance and a short testimony is appreciated as well.
Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Posted on May 10, 2011
Daniel S
  • 4323 Answers
SOURCE: The "clean" light is flashing
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Posted on Jun 19, 2011
Whirlpool gu2700 dishwasher
Water is not heating. Could be bad heater, bad control board, or poor water circulation due to clogged, stuck, or bad pump.
Jul 27, 2014 | Whirlpool GU2700XTSB / GU2700XTSQ /...
The CLEAN light is flashing on my Kenmore QuietGuard3 , but it won't clean anything. It starts a cycle for a few minutes, stops and starts flashing clean again. Any suggestions?
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing.
If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
Apr 21, 2013 | Dishwashers
Bosh washer won't stop? model SGS45C02
major recall of bosch dishwashers. recommend you check the list. https://www.consumerreports.org/dishwashers/maker-bosch-expands-dishwasher-recall/
Jan 01, 2018 | Bosch SGS45C02 Dishwasher
Intake/Drain light is flashing and dishwasher won't do anyhting. I gve cleaned the filetr and still nothing
Hi
Intake/Drain light flashing means an issue while draining. You would need to check for air gap on the dishwasher, it may be clogged. It prevents dishwasher from draining, sometimes the drain flow is restricted due to gunk. Cleaning or bypassing the air gap will resolve the issue. If this doesn't resolve the issue then it is due to seized (or stuck) drain pump. Disconnect the power to the dishwasher or turn off the breaker to the dishwasher. Tip machine on its back; remove screws that hold the bottom tray on. Remove the hoses to the main motor, remove electrical connections & remove motor (single screw holds motor, it is on the outside back of the machine). Try to rotate the motor (use WD40 is necessary). If you cannot rotate it, then motor will be required. If the error still appears then cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Switch the appliance off and then back on again. Hope this helps... Please post back if you need more information.
Daniel
Jun 08, 2011 | Miele 24 in. G638 Plus Free-standing...
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
WHIRPOOL DISHWASHER CLEAN LIGHT SATYS BLINKING AND IT WON`T START WASH CYCLE
you have either a bad heater and or your water temp is too cold
toggle heated dry and high temp wash withing 8 seconds until all the lights light up
then hit cancel you should be able to use it now
Aug 24, 2010 | Whirlpool Dishwashers
My whirpool dishwasher clean button is flashing.
Does the clean button flash 7 times then repeat... if it does you have a heat problem,, you will need to run diagnostics to clear the code and or find the problem.. let me know I can help
Sep 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher stopped mid cycle
My whirpool dishwasher model ADP4601 is flashing a green light three times and is not doing anything else - any suggestions
Aug 10, 2008 | Dishwashers
Whirlpool 24 in. GU2500 XTP Built-in Dishwasher Logo
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
