Question about NAD AMC 3020 Stereo Integrated Amplifier
How to plug headphone to amp using pre-amp of NAD 3020?
I want to use the headphone through the power of the amp link to the pre-amp of NAD 3020, The power amp don't have a heaphone jack. How to do it? With a speaker switch box (with headphone jack) or with a headphone amp? If with a headphone amp, how to connect to make it works?
  • Michel Gagnon Jan 21, 2013
    Hi, i could use a Y connector and plug it to the NAD 3020 but this is not what i Want. The NAD is connected as pre-amp to a pyle PTA 1000. Tha Pyle dont have a headphone jack. The connection bet ween the NAD and Pyle is: RCA from NAD then RCA in quarter in inch jacks to Pyle. Do you need more details^
robotek
  • 1512 Answers
SOURCE: connect subwoofer etc to nad 3020I stereo amplifier
Hi Info
You can use a 2 x male RCA to RCA female adaptor lead(what you need to ask for)  like this one 4d0dcde.jpg
use it to jumper your pre-out/main in connection on the rear, and connect an RCA lead to the Female socket on the adaptor lead. That will get you going. You can get them most places that sell electronic bits and peices. I am happy to answer any questionsa you may have
regards robotek
Posted on Mar 08, 2009
  • 83 Answers
SOURCE: Connecting an outdoor MP3 player to an NAD C352 Amp
you could get a bluetooth dock and cables or just get a saeltech bluetooth speaker and run it off your computer .It will let you run your i tunes or media player and go thru your playlist or artist songlisting can also be operated remotely on the speaker unit ! Volume And tracks!!! swamp ratt!!! AAEE!!!!
Posted on Jul 21, 2009
technical114
  • 1851 Answers
SOURCE: Short Pin/Headphone jack issue with NAD CBE 720 Receiver
It's logical since the headphones jack is connected at the main amplifier. Does your new main amp has headphones out?
Posted on Feb 20, 2010
  • 88 Answers
SOURCE: No sound from my NAD C325BEE amplifier
audio ic problem or component around audio ic.. good luck
Posted on Apr 26, 2010
gopakumarg43
  • 74106 Answers
SOURCE: I have just bought a
Hello
You have replaced your old NAD 3020 with NAD C326BEE. You are using the old speaker system with the new NAD 326 too. The Amp you replaced [NAD 3020] have only 20W/channel output power, and the present NAD C326BEE has a rated output power of 100W/channel. Both specifications are for 8Ohms speker impedence. Your old speakers haven't got the power handling capacity for the new Amp. That is why you hear it very clear at low volume levels and disorts at high volume levels. Distortion is not due to the Amp, but with the speaker you uses. You have to replace either speaker system or the speaker in which your old speaker box is fitted, with a new one, whcih can handle the power of the present Amp. OK.
Posted on Dec 16, 2010
Can i hook up a power amp to my Nad 7155 receiver and how
If the Nad has pre-amp out sockets that are currently connected to the power amp in the receiver. Then you can sever those link and put the pre-amp out into your Aragon inputs.
Otherwise I don't see how you can connect the amp.
Aug 10, 2016 | NAD Audio Players & Recorders
How can I turn off the sleeping mode on the nad 3020
You may want to try this if you need a manual or other info.
http://www.hifiengine.com/manual_library/nad/3020.shtml
May 10, 2014 | NAD D 3020 Hybrid Digital Amplifier
My NAD C350 plays very faintly. when I turn the volume dial to the max position, I can bearly hear the music. I can hear properly from earphones output. Thanks
Take care. First put the volume down complete. Then unplug the head phone and than try to raise the volume. Could be the headphone connector does not switch through correct. Could be the connections between the pre and power amp are not in place or not proper pushed in?
Always take care when working with amplifiers. When switching them on with volume to max, you easy can kill your speakers. Also when disconnecting the headphones on full power kan damage the loudspeakers.
Aug 29, 2013 | NAD Audio Players & Recorders
My NAD C320 outputs a very low sound volume
Hi there I have a C340 that has similar problem, you must have bought this from ebay, lol.
Nad made a mistake on the C range, the pre - power link can be shorted out. if the pre is shorted out it takes out the pre amplifier stage, I have managed to get the right channel working, I will keep you informed what is the cause of the left channel. I have replaced the pre-amp IC and a couple of Jfets and transistors. Once I have repaired the Amp I could repaire yours if you like???
Apr 14, 2012 | NAD C320 2-Channel Amplifier
Hi, I have a NAD C162 Pre-Amp which I am using with a NAD C270 Poer Amp. Th problem is that the Pre-Amp doesn't seem to be driving the Power-Amp efficiently. By this I mean i need to turn the gain up...
Hello, I have an idea:
at the rear side of the NAD preamp there is a switch, it can be in mode MM or MC . Please check it whether it is in right position or not.
Good luck,
gylacz
Feb 15, 2011 | NAD C162 Amplifier
Feb 20, 2010 | NAD T752 Receiver
Amplifier only making buzzing sounds
u r amplifires output system is not working properly somthig pcb break problem go to thew mechanic
Apr 05, 2009 | NAD D 3020 Hybrid Digital Amplifier
PreAmp to Amp problem
Sorted it. You have to put the plugs back in the PreampOUt/Main in or it cuts out the pre-amp.
Nov 18, 2008 | NAD C320 2-Channel Amplifier
NAD C740 no longer reproducing music through loudspeakers
what was your amp? ic or transistorized? the output transistor of your amp may be opened, mostly it will short but because u still hear sound, maybe open and only the driver transistor are working. replacing output transistor or IC could solve the problem.
May 14, 2007 | NAD C320 2-Channel Amplifier
NAD AMC 3020 Stereo Integrated Amplifier Logo
98 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Larry Stiles
Larry Stiles
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
