Question about Polaroid PDC 5070 Digital Camera
How do i save the pictures to see them without a memory card
The camera will not save pictures, do i need a memory card to save them?
    President:
  • 2,961 Answers
There is only a 16 MB internal memory built into the camera, which at 5 Million pixels will allow you 1 or 2 photos, so you will have to by an SD type card, i would suggest either a 512MB card or 1GB if you are taking pictures at the highest resolution.
Posted on Jul 14, 2007
SOURCE:
Why doesn't my digital cammra save my photos
Do you have a memory card in the camera? Without a memory card some cameras do not have the capability to store pictures. If you do have a memory card make sure it is for photos. I had 2 friends this year that had the wrong cards in their cameras and no pictures were saved. Hope this helps.
Mar 04, 2013 | Vivitar ViviCam X024 10.1 Megapixel...
Took pictures without memory card Nikon D3000 camera, can I retrieve them?
No. Without a memory card the camera stores the last picture taken only so you can view it to verify proper operation. It overwrites the previous picture, and it disappears when you turn the camera off.
You NEED a memory card if you want to save the pictures. Sorry if that wasn't the answer you wanted to see, but that's the way the camera works.
Jul 28, 2012 | Nikon Photography
Why does it keep saying memory full after I have only taken 6 pictures
You need to go to the store and buy Samsung S730 A-DATA 4GB SDHC Memory Card (Class 4)
It is worth about 8-20$. The memory card is used to save pictures. Here is an example: http://www.cellularfactory.com/camera/SAMSUNG/3/46100/
Apr 02, 2012 | Samsung Digimax S730 Digital Camera
I have a nikon coolpix s60 and when i go to view the pictures, the screen turns black and i cant turn the camera off unless i pull the battery
What name brand memory card do you use? I recently discovered myself that Nikon only supports SanDisk, Toshiba, Panasonic and Lexar. Try taking out the memory card and take pictures without the memory card inside the camera. If you can view the picture saved onto the camera memory then you will know that all you need is a new memory card, with one of the above mentioned name brands. Hope this helps.
Mar 01, 2011 | Nikon COOLPIX S60 Digital Camera
Took pics with shoot without card setting on
No. This setting simply allows the camera to go through the motions without a memory card, so you can demonstrate it in the shop. The alternative is to lock the camera so as to prevent shooting without a memory card. Either way, no pictures are saved.
Apr 21, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Picture from camera memory to memory card
http://www.nikonusa.com/pdf/manuals/coolpix/L12_en.pdf
Page 34 says if you put the SD card in you can put them on the card.Hope this is what you were looking for?
Jan 05, 2010 | Nikon COOLPIX L12 Digital Camera
Internal memory card full
You are using built in internal memory (11Mb).
One of these must help:
*Check memory card.
*Check picture saving settings.
*Reset to factory defaults.
User Manual
Feb 13, 2008 | Pentax Optio E30 Digital Camera
Samsung s370
I'm willing to help you out on this.
Basically, there is no settings for picture storage on your camera.
Once you took pictures WITHOUT a memory card, all pictures taken will automatically be saved on the INTERNAL MEMORY of the camera.
When taking pictures WITH a memory card, all pictures are just saved on the memory card itself.
*** If you want to transfer pictures on the internal memory of the camera to your MEMORY CARD, you just have to follow the steps below:
- Make sure there is a memory card inside the camera
- Turn on camera
- Press on PLAY mode button to view pictures
- Press MENU/OK button
- Keep scrolling to the right until you see COPY TO CARD
- Select YES using the arrow keys
- Press MENU/OK to confirm
* When you've done these steps, all pictures from the INTERNAL MEMORY of the camera will be copied to your MEMORY CARD but it depends on the space left on your memory card
Jan 12, 2008 | Samsung Digimax S630 Digital Camera
Cannot access pics
Once you took pictures without a memory card, all pictures taken will automatically be saved on the INTERNAL MEMORY of the camera.
When taking pictures with a memory card, all pictures are just saved on the memory card itself.
If you are seeing 100-757 on the LCD screen. It means that there are already 757 pictures taken from the first time you've used the camera.
It is possible that some of the pictures are in the internal memory and some are in the memory card.
STEPS to DOUBLE CHECK:
1) Remove memory card out of the camera
- Turn on camera
- View pictures on the internal memory
by just pressing on the PLAY mode button
(lowest of the 3 little buttons)
- Pictures seen are just the ones saved on the internal memory
2) Return memory card back in the camera
- Turn on camera
by just pressing on the PLAY mode button (
- Pictures seen are just the ones saved on the memory card itself
- Turn on camera
** If still, you could not view the pictures, it's possible that the pictures are really gone when you have transferred the previous pictures to your computer.
** Once you have transferred pictures to your PC, and you have deleted those on your camera, the FILE NAME of the pictures will not start from 100-001 again unless you have reset the file name on the settings of your camera.
In example, i already have 256 pictures on my camera so the filename reads 100-256 for the last picture taken. And then i decided to transfer those 256 pictures to my PC and i deleted those immediately after being transferred. So, as i took another picture, FILENAME will start with 100-257 if i have not reset
the FILE NAME settings to 100-001.
Hope i've helped you enough.
Jan 02, 2008 | Samsung Digimax S630 Digital Camera
Polaroid PDC 5070 Digital Camera Logo
104 people viewed this question
Top Polaroid Cameras Experts
Ekse
Damen Wong
Damen Wong
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
