Question about Panasonic DMR-E85H DVD Recorder
DVD drive door won't open "LOCK" shows on display
I fixed the "Please Wait" message by replacing the 2 capacitors that were suggested. HDD records and plays back. DVD plays but door won't open and when I try to record display shows "disc full." It did let me finalize the disc. Please help.
  • heldnova Jan 26, 2009
    I found the solution to DVD drive LOCK message. With the unit ON, hold down STOP and POWER at the same time for 10 seconds. Then hit EJECT button and drive door opens.
5 Suggested Answers
SOURCE: Lock message
Hi!
My DMR-ES10 appears since last month, the same message, and lets myself crazy!
Today, after a desperate try, pressing the buttons, I found the solution:
Simple press the POWER BUTTON and STOP BUTTON of the unit for a few seconds...
VOILá: The UNLOCK message appears in the display and the unit return to operate without the lock message !!!
For Lock again, press the same buttons at same way until appears the Lock message in the display.
This is an undocumented command...
I hope to help you!
Posted on Apr 01, 2008
worldvet
  • 859 Answers
SOURCE: Panasonic DVD player won't finalize
You can try a dvd+r disc. Borrow one before buying a stack of them.
The other thing is that you may not have enough free space left to burn the finalization track; 7 1/2 hours is a lot of recordings.
Give the +R disc a try even though it says it can't use them in your documentation, a lot of users report it works anyway.
Please don't forget to rate all of our solutions here on the board. Thanks.
Regards,
Worldvet
Posted on Jun 22, 2008
pogiboi
  • 85 Answers
SOURCE: "NO READ" on Panasonic DMR-EZ27 DVD Recorder
good day 2 you,, ,, i have some little advice on you,,
just open the top cover of your player and check the RIBBON WIRE of the LENS/EYE part then clean theGOLD FINGER/LINES
and get some clean cotton buds and a lighter fluid 2 clean the lens,,,,,ok,,
PS. dont use cd cleaner fluids,,, that wont clean, , , , , ,just lighter fluid ok!!!
GODBLESS U
Posted on Sep 22, 2008
  • 5 Answers
SOURCE: Polaroid dra-01601a hdd to dvd recording
You will have to split the title and record on more than one DVD. The default speed is SP, that is 2 hours of recording. If you want to record longer programs, go into setup and change the default record speed to one of the other settings, for example: SP+ which is 2 1/2 hours or one of the other longer record settings. This DVD burner will only record at the same speed as you recorded to the hard drive. You can also edit out the commercials by using segment. Go to the title you want, press the right arrow, scroll down and select segment. When you want to start your edit, press enter. when you want to stop the edit, press enter again. You can use your right arrow to skip forward 30 seconds and your left arrow to skip back 10 seconds if you went too far when editing. You will see where your edits are on the screen by the darker color. Do this through the whole program. When you record to DVD, the commercials will not be recorded. Hope this helps you.
Posted on May 13, 2009
SOURCE: pansonic e 85h won't play recorded disc or
Chris you were right on with the cleaning I paid $50.00 for the lens cleaning from a certified Panasonic technician and now works like brand new I have invested a total of $200 for the power supply and lens/laser cleaning but I got the unit as a gift, minor probs with unit but great dvd recorder thanks!!!
Posted on Mar 29, 2010
Panasonic DMRES15 DVD Recorder disc not spinning
Troubleshooting Solution
1.Display Message " Please wait" Not
booted
2.DVD-Rom Two-Three times make noise but doesnt spinning
3. Doesn't
open tray, No video OUT
1.Bad Main Board VEP79117
2. Bad DVDROM
3. Bad Prosessor
PCB
Mar 16, 2013 | Panasonic DMRES15 DVD Recorder
Error message
ERR-15 hard drive error. need to replace hard drive also it would be easier if you just take it in a repair shop
Sep 10, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
No turn on but a message on the display. The message is PLEASE WAIT
This message is displayed when the device is checking for its hard drive and DVD drive to signal back that they are operational. You can consider this a bit like the BIOS of a computer as it is waiting for its devices to come back with a "READY" signal. If "PLEASE WAIT" is scrolling across your screen for a really long time it could mean that the two devices with moving parts (HDD / DVD) may be having an issue coming up. UNPLUG unit from wall. Wait for some time (5 min) and then plug it back in. If your device is still not working then you have either a bum HDD or a bum DVD. Considering which one is working all the time (HDD) you probably have a dead hard drive, but my own unit's DVD drive went nuts, so that is also a potential source of the problem.
Either way, your local computer repair store can have a look at this issue, considering what the unit is is basically a single purpose PC
Graham Leach
Aug 24, 2011 | LG RH-4820 DVD Recorder
Display reads please wait
Replace all power supply's capacitors that are on the secondary.
This should solve the problem.
Jan 16, 2011 | LG RH1999H DVD Recorder/HDD Recorder
PLEASE WAIT
I contacted Panasonic about the "PLEASE WAIT" on display and after a few attempts to fix I was told that it would cost $130 minimum to repair.Then I found I had the same problem that hpwhite & RandyChev described "PLEASE WAIT" on display. I followed their very precise and informative directions and found that I also had two bad (bulging) caps, C1270 & C1271 Thanks to the pictures he posted, I was able to find replacement 1000uf 35v Radio Shack #272-1032 capacitors and replaced them with no problems. I then was able to power it back up and all of my information was still on my hard drive, even the correct time in the display. If you can find RandyChev's description with the pictures, it is very easy to understand
May 23, 2009 | Panasonic DMR-E85H DVD Recorder
DVD locked in and door is not opened
might have stuck inside...u got to open up the system onlly
Apr 01, 2008 | LG RH177 DVD Recorder/HDD Recorder
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Hdd error
try replacing the red sata cable which runs from the HDD under the DVD drive to the main board on the right-hand side. these are a common problem on these models, there cheap and unreliable. you can purchase a better quality cable from a computer store for little money. HDD ERROR is'nt necessery an HDD fault as i found out with my rdr-hx525. if however the HDD is faulty and you buy a replacement, once installed you will need to pair the new HDD with the unit by entering the service mode by unplugging the AC then while holding down open/close and play together then re-insert the AC lead while still holding open/close and play and wait until you see an "S" in the display then let go and the service mode will appear on the tv screen. go to no.9 HDD mode, press enter then go to no.3 Write ID then it will say "execute write ID?" yes and press enter and then it will say "writing HDD serial ID.... OK" once this is done, exit the service mode by keeping your finger on the power button for approx 10secs. your DVD recorder should now recognise the new HDD. if you don't follow this process, you will still have an HDD error message as your DVD recorder will have your old HDD installed and won't recognise your new one. given the amount of time since you posted this fault, you may still have the unit in question in which case i hope this solution is helpful, or for anyone else with the same problem.
Jan 08, 2008 | Sony RDR-HX725 DVD Recorder/HDD Recorder
For those users who just bought their machines, I would suggest warranty service. Roxanne2 should contact Philips directly with the seiral number, and they should be able to say which store they sold it to. That unit probably has a bad internal DVD writer drive.
The following solution should only be done if your machine is out of warranty unless you get permission from the manufacturer, as it will likely void the warranty otherwise:
Unplug the unit, disconnect all cables and move it to as static-free of an area as possible. Remove the cover, which usually means removing a lot of screws. Most DVD recorders have regular drives like you see in PCs. There is usually a tiny hole in the lower-right part of the drive that you can stick a small wire into, such as an unbent paper clip. You can then manually pull the drive open to get the DVD out.
Oct 29, 2007 | LG RH177 DVD Recorder/HDD Recorder
LGRH177
it should be the internal HDD failure...befause the player fails to checking the HDD during starting up ...
good luck !
Aug 25, 2007 | LG RH177 DVD Recorder/HDD Recorder
Panasonic DMR-E85H DVD Recorder Logo
208 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
