Question about Haier Heating & Cooling
I want to find a control board for haier air conditioner with this code 0010404503e or the user manual. Thak for your help.
Control board or user manual 0010404503E
  • 3 Answers
SOURCE: KELVINATOR AIR CONDITIONER
whats the furnace doing exactly is the filter clean ? does the blower come on if you just put fan on ? do you have pwer to the unit ?
Posted on May 30, 2008
rylee_smith
  • 8619 Answers
SOURCE: E2 error code on Haier cprd12xh7 portable air conditioner
Hi! You need to check pump filter. It could be jammed with a coin or hair clip. Now take the machine outside and empty it then lay it on its side and you can access the pump. Take it off, stand up the machine and pour hot water into the soap draw and check water should run out of bottom freely taking any fluff or bits with it. Now take apart the pump and clean it and dry all components before re-assembly. If the machine still doesn?t work then you need to replace the pump. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
Posted on Jun 13, 2009
SOURCE: VULCAN BONAIRE Users manual.
Try here http://www.bonaire.com.au/support/documentation/owner/default.aspx
Posted on Jan 05, 2010
SOURCE: Leaking Haier Commercial Cool air conditioner.
there are 3 drain holes in the primary pan right underneath the evaporator that need to be clean with a pipe cleaner or a wire of somekind and there is also a secondary drain behind it that will work only if the unit is 100% level. To access the primary drain pan you have to take all the screws of the back cover 5 on each side and 3 in the center above the electric cord and behind the air filter and only then will you be able to see these very small holes. Use a flashlight to make sure. Have fun!Reply
Posted on Jul 07, 2010
SOURCE: i want user manual for
Need instructions to use Expertair Heat Pump ZH/LW-01
Posted on Nov 16, 2010
Haier a/c model esa408k-l mode is set on cool, speed set on high temp is 81 held temp button down, goes to 61 with in seconds goes back to 81.
Free Haier Air Conditioner User Manuals ' ManualsOnline ...
homeappliance.manualsonline.com > ... > Household Appliance Haier
Products 1 - 50 of 548 - Haier Split Type Room Air Conditioner Operation Manual. Pages: 0 Saves: 0 ... Haier Room Air Conditioner Installation Manual. Pages: 0
Aug 26, 2015 | Haier Heating & Cooling
Haier service manual
This is what you error code means.
E1 = Room temperature sensor fault
Haier Air Conditioner Fault Codes
AC Repair Tamarac
Aug 25, 2014 | Haier Esax3186 Energy Star 17,000 Btu...
Wont turn on display says stop
Air Conditioner Haier CPRB07XC7 User Manual (36 pages)
Haier cprb07xc7: user guide Size: 2.13 MB
Aug 21, 2013 | Haier CPRB09XC7 Portable Air Conditioner
Broken control board on Haier HWR12XC5 air conditioner
You can get a new control board HERE
Thanks for using Fixya.
Please remember to vote for any solution that helps you out.
Dennis
Jul 01, 2011 | Haier HWR12XC5 Air Conditioner
What Is Error Code 'e0' I Have a HAIER HWR10XC7 Air Conditioner, and whenever I plug it in it displays this error "E0". What can the problem be?
i have a haier esa412m that had that same code e0, in my case it was a loose solder connection for the thermal sensor in front of the evaporator behind the intake air filter, the board with the loose connection sits behind the control pad, you will need to remove the covers, both front and top/side, disconnect the main power board and look for bad solder connects and resolder them, takes about 45 mins if you are a little handy.
May 28, 2011 | Haier hwr10xc6 Air Conditioner
Lost manual
Hello, I found two user's manuals available from Haier. Neither is specifically for the HPAC90ER, but in my experience sometimes there is one manual for several different products so it's worth checking out. I hope this helps you!
- CBR2009 Here's the link to the PDF user's manual for the HPAC90E
http://www.haieramerica.com/en/asset/archived/HPAC90E.pdf
Here's the link to the PDF user's manual for the HPAC99ER
http://www.haieramerica.com/en/asset/archived/HPAC99ER.pdf
Jun 23, 2009 | Haier HPAC90ER Air Conditioner
Haier 8000btu Airconditioner
One thing you can try is to hold down on the power button and plug the unit in. Hopefully you will hear a "beep". Then you need to unplug it for a minute and plug it back in. This is a known procedure to clear error codes from the control computer on units similar to yours, so it might possibly work. Something else you can do is download and look through the Users Manual for your model, which is at this URL: --> http://www.haier.com/products/product.asp?proID=3705 Hope this helps! ;)
Jun 18, 2007 | Haier HWF08XC5 8K RAC Mechanical Window...
Haier air conditioner
One thing you can try is to hold down on the power button and plug the unit in. Hopefully you will hear a "beep". Then you need to unplug it for a minute and plug it back in. This is a known procedure to clear error codes from the control computer on units similar to yours, so it might possibly work. Something else you can do is download and look through the Users Manual for your model, which is at this URL: --> http://www.haier.com/products/product.asp?proID=1797 Hope this helps! ;)
Sep 03, 2006 | Haier ESA308 Air Conditioner
Heating & Cooling Logo
51 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
