Question about RCA 32V420T 32" TV
RCA 32V434T TV turns itself off and on by itself. Any suggestions on how to fix it?
  • trimguy012 May 01, 2009
    tv turns on and off by itself and then scoans channels by itself
When your tv turns on by it self you prob have the alarm set. For the tv to turn like a clock would go off when u need to get up. You need to check the the sleep/ wake up timer to see if it is set.
Posted on Jan 26, 2009
My 32v434t television.
The TV was making the clicking noise and not turning on because an internal error was being detected.
Now things had got worse , and something had blown inside the TV.
The burning smell and high pitched noise is coming either from Flyback transformer or PSU board. Repair is a delicate matter and must be done by a technician.
Jul 05, 2009 | RCA TruFlat 27F520T 27" TV
Got an rca 32v434t, plugged in hooked up, and it
we would need more information:
has TV worked before
how many hours has TV been used
I have seen this 'ShutDown' on many failing monitors..
Typicaly the Power Supply circuit in your TV
have 'Over Current' detection\protection
and your 10 second is just about how long somthing is probly taking to either:
over current and shut down
or more specifically:
one or both things wrong with it:
bad electrolytic capacitors ( maybe )
but if it's a perfect picture for all 10 seconds then probobly some specific semiconductor or module is: 'Heating Up' then 'OverTemperature' and failing in a manner that causes an immediate overcurrent condition, shutting off the TV.
- give more information
- if capable of safely removing the back of the TV to allow for inspection...
WITHOUT GETTING ELECTROCUTED
by the high voltage that remains stored inside the tube, even after power has been removed !
then pop her open and have a look at
the PCB's ( circuit boards )
if somthing has been running hot and has led to this type of failure; then your circuit board will be discolored near the mounting of that device... You may even notice a burnt pcb smell at that area.
anyhow
somtimes you can find these semiconductors or modules in catalogs or online ( OfCourse )
and yourself or sombody with sufficient knowledge of soldering and the
' Potentially Life Threatening Hazzardes '
that exist around CRT monitor repair....
... can go ahead ad replace the suspect part.
Ed
Jun 16, 2009 | RCA 32V420T 32" TV
RCA 32V434T TV Turns itself on and off, changes channel and volume by itself. Frquency of off and on is as many as 20 times in 5 minutes. I even removed the batteries from the remote to make sure it wasn't...
I had the same problem. Got it to stay on by unplugging the front button pc board while I researched the issue. It seems that the switches on said pc board begin to "leak resistance" and cause all kinds of problems like on/off, color maxes out, as well as other crazy stuff. After calling RCA and getting no help I decided to remove those seven micro-switches off of the board and, wouldn't you know! Everything is ok with the exception of not being able to controll the tv from the tv itself. Small sacrifice for a free fix. All tv functions work from the remote. Again, a small sacrifice for a free fix! Just be careful when poking around inside, high-voltage and stuff.
Jun 12, 2009 | RCA 32V420T 32" TV
RCA 32V434T (32'') TV has no Red or Green pixels, only Blue
The color problems are caused by cracked/broken solder joints on the circuit that controls the display.  Usually this is located at the back of the tube on a small circuit board. Your description suggests that only the blue signal circuit is intact. I suggest these joints be resoldered for more strength.
It's a possibility that another IC senses this problem (or another one) and then shuts down the system.
Resolder those joints and see what happens.
Jun 03, 2009 | Televison & Video
RCA 32V434T Flashing Red Light
Flashing led..in protect mode..internal shorted component.
Aug 14, 2008 | RCA F32450 32" TV
RCA MODEL #32V434T
Mine does the same thing I'm thinking a fuse has blown out and if taken to a tv repair shop or finding the right size fuse you can fix or get it fixed yourself..
Apr 10, 2008 | RCA 32V430T 32" TV
Rca 32v434T need part numbers
The H.O.T. Transistor number (original is 2SD3402 (which is no longer available)) it's replacement is the 2SC5902.
The H.O.T. Transformer part Number is RCA 271996
Oct 30, 2007 | RCA 32V550T 32" TV
RCA 32v434t
Has anyone confirmed what the problem is? Mine wont turn on. The red light next to the power button just stays lit when pressed.
Oct 22, 2007 | RCA 32V420T 32" TV
Rca 32v434t
went in the menu and blocked the panel buttons on accident
Oct 13, 2007 | RCA 32V550T 32" TV
Power problem rca 32v434t
RCA 32V434T likely has a bad flyback--#271996. RCA 32F531T flyback no longer available,#262343 Fix one,dispose of other.
Sep 26, 2007 | RCA 32F531T 32" TV
RCA 32V420T 32" TV Logo
314 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
