Question about Cell Phones
How do you lock keypad on bluechip bcsc
Lock/unlocking keypad
I can't unlock my vteck 15300 dect6.0 cordless pH handset help
I guess you mean the Keypad Lock/Unlock!
You can turn on the keypad lock of a handset.
In idle mode, press * button and then LOCK to turn on the keypad lock. "PRESS UNLOCK TO USE KEYS" is displayed on the LCD.
In keypad lock mode, press UNLOCK to turn off the keypad lock.
Aug 27, 2016 | Lands Phones
I have a bluechip android phone,my son locked it,it says i need my google account user name and password,wnich i dont know because i have never needed it
This is a common problem, where you input the correct name and password and it still doesn't work. To solve this: Try going to this site from your PC: https://www.google.com/accounts/UnlockCaptcha Put in your info and it should say device unlocked Re-enter your info into your phone and it should take you to a new screen to set a new pattern and once you set it your phone should be unlocked. After you unlock your phone, you can take off the pattern unlock in the settings.
Apr 28, 2012 | Cell Phones
How can I lock the keypad?
Keypad lock: To lock the keypad press Menu then Star (*) key. To unlock the keypad press Unlock (Menu key) then Star (*) key. Press both keys in a fast way.
Hope this help and if helpful RATE please
Feb 22, 2011 | Nokia 6310i
How to unlock nokia 2700c
Keypad lock
To prevent accidental key presses, select Menu, and press * within 3.5 seconds to lock
the keypad.
To unlock the keypad, select Unlock, and press * within 1.5 seconds. If
the security keyguard is on, enter the security code when requested.
To set the keypad to lock automatically after a preset time when the
phone is in the standby mode, select Menu > Settings > Phone >
Automatic keyguard > On.
To answer a call when the keypad is locked, press the call key. When you end or reject
the call, the keypad locks automatically.
When the device or keypad is locked, calls may be possible to the official emergency
number programmed into your device.
Jun 05, 2010 | Cell Phones
The keypad on my nokia 5310 will not lock even though keypad lock is switched on
1.5 seconds. If Security keyguard is set to on, enter
the security code if requested.
call key. When you end or reject the call, the keypad
automatically locks
Aug 30, 2009 | Nokia 5310 Cellular Phone
I forgot the keypad lock of my n3110c hoe do i unlock it
long press unlock key , when appears "now presss *" then press *. and ur code will broken.
May 04, 2009 | Nokia 3110 Cellular Phone
How do I lock the keypad?
You can manually lock the keypad to avoid pressing keys by accident. You can still answer an incoming call and the keypad will lock again when the call is finished. The keypad remains locked until you unlock it manually.
Depending on your phone model, you can activate the automatic keylock. When the automatic keylock is activated, the keypad locks shortly after you stop pressing keys.
Please note: with some phones you can still use external keys when the keypad is locked. If you wish to lock the external keys you must lock them separately.
K530i To manually lock the keypad:
  1. From standby, press the * key.
  2. Select 'Lock keys'.
To activate automatic keylock:
  1. From standby, select 'Menu' > Settings.
  2. In the General (tab), select Security.
  3. Select Automatic keylock > On.
To unlock the keypad:
  2. Select 'Unlock'.
Mar 31, 2009 | Sony Ericsson K530i Cellular Phone
How to lock and unlock keypad Motorola VE240
To Lock your phone
Hold down the # symbol on your phone until it says: "Phone Keypad is now Locked"
To Unlock your phone
The screen should now read in the bottom right hand corner "Unlock". press the corresponding key. It then asks "Unlock Keypad?" "Yes" or "No". Select Yes and press Menu button (also the play/pause button).
Hope this helps you all!
Jan 02, 2009 | Cell Phones
How to lock the keypad with security code for sony ericsson?
I DONT WANT THE AUTOMATIC KEYPAD LOCK..BUT I WANT TO KNOW HOW TO MAKE KEYPAD SECURITY CODE SAME AS NOKIA..PLEASE HELP ME..
Dec 26, 2008 | Sony Ericsson S710a
Lock the keypad
K800i To manually lock the keypad:
  2. Select "Lock keys".
  1. From standby, select "Menu" > Settings.
  2. Select "Unlock".
  3. hope this helps Thanks and God bless
Dec 15, 2008 | Sony Ericsson K800i Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
