Question about Sony (XL-2400) Projector Lamp for KDF-E42A10, KDF-E50A10
I have a Sony KDF-E50A10 LCD Projection TV, my TV going on and off every 30 to 40 second, I can hear the fan still running....green led flasing in front of the tv while the picture and sound goes off, this is the Power/Stand by led. I followed instruction from Sony.com and was advised to unplug for 30 second and try again. This did not resolved my issue! If the lamp going on and off for 30 seconds, that telling me the problem is not the lamp of course! Is there any type of reset?
  • 2 more comments
  • robgon52 Jan 25, 2009
    TV is about 2 half years old...So you recommend replacing the lamp even though on the front of the TV doesn't have a red led telling us to replace the lamp?
  • Anonymous Feb 27, 2009
    I have the same problem - try replacing the ballast! Not the DLP Lamp, we have replaced ours already! The repairman has now ordered a ballast. In the meantime, we have delegated the Sony to a great place in the basement and purchased a 46" Sharp Aquos LCD - heck, what a difference and guess what - much more "user friendly". Sony is a bad word in our house!
  • necarrothers Apr 29, 2009
    Same problem as described.
    Not sure what the resoltuion is lamp or ballast?
    Thanks
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    When Lamp got weak TV got that symptom.
    Lamp light will glow when Lamp got dead but now its weak.
    Buy Sony original Lamp and replace it. By the way, how old is this TV?
Make sure the safety door is in place and properly locked. We didn't have ours in correctly and kept getting the 3 blinking lights. After we resecured it - it worked.
Posted on Feb 03, 2010
Whats the part number on the ballast?
Posted on Jul 09, 2009
  • 10,594 Answers
I'm practical TV tech and fixed these TVs.
Symptoms shows weak lamp and TV requires new lamp.
Posted on Jan 25, 2009
We have a sony wega KDF e50a10
Over Voltage Protection 03. This is the fault. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1200 posts to different brand TVs now. Pull up older posts there.
Blinking codes to Sony TVs are described in detail.
Nov 12, 2012 | Sony Wega KDF E50A10 TV
Kdf-e50a10. tv was working for 1minute then turned off and green LED flashing for about 1 minute then turned ON again. it repeated every minute.
replace the ballast power supply block that will solve the problem .its on left side back of the tv by the fan
Feb 20, 2012 | Sony KDF-E50A12U 50" LCD HDTV
My kf-e50a10 lcd projection tv suddenly just shut off and when i
Check your fans. You have a stuck fan. You may want to call a service center as it is a pain to get to one or two of the fans. Theres 3 or 4 of them.
Dec 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
"my kdf e50a10 has a green screen Is this is a lamp problem or an
Green picture is caused by the light engine (the projection part of tv) failing and has to be replaced. Sony has extended the warranty on some models so you might be in lick. Contact them with model and serial number they can help setup repair if you qualify. If it is not covered it can cost between $1000-2000 to fix, which is way too much.
Rustym62
http://www.the-tv-dude.typepad.com
Mar 23, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10 No Picture
4 times blink error shows that any FAN is not running in TV as there are 4 fans in this TV.
Please check fan connectors and make sure all are plugged securely.
Feb 13, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KDF-E50A10
Have the Ballast (power supply to the lamp) replaced.
Jun 23, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Sony (XL-2400) Projector Lamp for KDF-E42A10, KDF-E50A10 Logo
1,300 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
