Question about Health-O-Meter Health & Beauty
Healthometer sca HDM037DQ-01
Scale will not give an accurate reading or register body mass
  • 2712 Answers
SOURCE: body fat scale Question
Like all body fat tests, body fat scales don't actually measure your body fat percentage. They determine your body density. The examiner (or the scales) then uses a formula to calculate body fat percentage based on body density. These formulas just predict your body fat. Unfortunately there is no one formula that accurately predicts body fat for the whole population. Differences in age, gender, ethnicity, body size, and fitness level all have a significant affect on the results. Well, whether body fat scales measure your "true" body fat percentage or not doesn't matter! As long as they can accurately monitor changes in your body composition over time, that's all you need.
Posted on Aug 27, 2008
SOURCE: Healthometer Bathroom Scale
http://www.healthometer.com/Manuals.aspx
Posted on Aug 23, 2010
Konchok
  • 7 Answers
SOURCE: Have had the BS 365
Not sure if you knew this but you can change the batteries. I had the same problem and had forgotten to change the batteries. However, the weights may still fluctuate because you need to reprogram the settings. Unfortunately, i do not remember ever having an instruction manual...
Posted on Jan 24, 2011
joeguest2
  • 2080 Answers
SOURCE: I lost my instruction manual
Look on the bottom of the scale for a sliding switch to alternate between Kg and lbs.
If you do not see one then remove the little cover and check inside the battery compartment for it.
Good luck.
Comment back here and rate with 4 Thumbs up if this was at all helpful.
Thank you.
Posted on Feb 23, 2011
jas247
  • 844 Answers
SOURCE: I have a healthometer scale,
Welcome to FixYa!
1. The Platform on which you stand may be hitting the base of the scale. The corner that your heels are on is adjustable from the bottom of the base. Turn the scale over on its side and remove the round plastic foot. Insert an Allen wrench into the now exposed hole and turn the screw to raise that corner of the platform.
Note: If you adjust one corner, be sure to adjust the opposite corner to keep the platform levelor.
2. Look under the base of the scale and make sure no foreign item is lodged into the base and that no parts have come out of the base.
Thank you for using FixYa!
Jas247
Posted on Apr 19, 2011
SCALE READS 20 LBS TO HEAVY HOW DO I CALEBRATE
Sounds like reset access points. Try pressing something in the hole gently to see if you can hear it clicking a switch...if it does the hold the button in and turn th scales on or turn the scales on and the press the reset. Good luck
Nov 24, 2013 | Healthometer Health o meter Glass Digital...
How to change a Bfm883dqn 01 from kg to lb
Hold the 1st button down until kg pops up on the screen. Let button go, hit 1st button again, it should change to lb. hit select button. Should stay on lbs.
Jul 06, 2012 | Healthometer Health o meter BFM883DQN 01...
Healthometer change kg to lbs
With scales off. Hold select button for approximately 5 seconds, lbs flashes hit select to confirm
Apr 28, 2012 | Sunbeam Healthometer Body Fat and Weight...
I have a healthometer BFM920KD-01 scale and
Just push either the #"1" or "2" user button and hold it down. The display will flash the height numbers. Hit the Up or Down arrow to change the flashing "5" to a six, etc. Then hit the "set" button to "enter" your choice. This advances the display so that you can now change the inches, gender and age. You're good to go!
Apr 14, 2012 | Health-O-Meter Health o Meter BFM588DQ-81...
How do you change the weights and height?
you can go to shemox.com.. hope this site will help you to your problem
Mar 06, 2011 | Healthometer Health o meter BFM883DQN 01...
Recently when I step on the scale I get and E
Try stepping off when you get the E and step back on after 5-10 seconds and see if it works.
Aug 12, 2010 | Sunbeam Healthometer Body Fat and Weight...
How do i reset each individual person
mcdevito75 here, There should be a button or knob close to the indicator you can press, turn, to return scale to zero for each person.
Jun 26, 2010 | Sunbeam Healthometer Body Fat and Weight...
Health & Beauty Logo
15 people viewed this question
Top Health-O-Meter Health & Beauty Experts
creative_lac
Level 1 Expert
His Example
Level 1 Expert
TheHCGInstitute
TheHCGInstitute
Level 1 Expert
Are you a Health-O-Meter Health and Beauty Expert? Answer questions, earn points and help others
