Question about Reddy Heater-30-55,000 BTU Variable
Need wiring diagram for Reddy Heater RCLP50 Lp Gas 50,000BTU Serial # 3048135
  • Anonymous Jan 27, 2009
    need to ring out the switch reset
Go to
Posted on Jan 26, 2009
Have an rlp30 reddy heater, have spark and gas but will not light.
wile red button is pushed no flame or turns off when the button is released the flame dies ? if no flame tank is too small or spark isn't in far enough to catch gas . if flame is present with button down then the over heat switch on the in line thermal coupler could b bad u can check the over heat switch with a jumper between the two wires and if it stays lit you got it if it goes out then its the thermal coupler that's bad
Dec 12, 2013 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Reddy heater, 50,000btu, won't ignite, no spark at plug, good fuel spray
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
Jan 18, 2011 | Reddy R60A Utility Heater
30000 btu reddy heater is throwing flame way out of the heater
The gas pressure is way to high... you need to adjust the regulator to a low pressure or replace the regulator...
Propane, LP, or Natural Gas Regulator Problems
Dec 10, 2010 | Reddy Heater-30,000 BTU Propane Forced-Air...
I have reddy heater 35000 btu.starts ,then works 5 seconds and shut off
I have a LP gas version. I had to disconnect some kind of sensor (looks like a watch battery with 2 red wires). I made a jumper wire and put in place of red wires. Works fine now. This sensor might be an Oxygen sensor.
Nov 19, 2010 | Reddy Heater-30-55,000 BTU Variable
L.P. Propane Heater not staying lit Fairly new heater (Reddy) 30,000 BTU Piezo Igniter not functioning use long match and unit fires nice. plug in /turn on blower good once I let go of primer valve button...
Sounds like you have a bad gas hold on valve. I have a tip at which explains the problem, how to fix it and where to get the parts. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
Jul 30, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
My reddy heater R50,(50,000btu)when started will
the unit is working exactly as designed , the system is noticing that the unit has not fired so it shuts down so there is not a lot of unburnt fuel everywhere.
try to find out why the unit is not igniting . is the igniter sparking continually
Nov 12, 2009 | Tools & Hardware - Others
How do i light a Reddy Heater rcp 2000 lp gas heater?
hold down the pilot valve knob and turn the arrow to pilot position push down on red button to allow gas thru pilot tube hold down and light keep button held down for 1-2 mins while pilot is on to heat up the thermocoulple then release and turn knob to on position.
Sep 12, 2009 | Reddy Heater RLP100 Portable Forced Air...
I need a wiring diagram for a Reddy Kerosene Heater Series 125T
Here is a link to a owner's manual for a RL125T ... You can find a wiring diagram on page 19. I hope this helps you.
Dec 26, 2008 | Reddy Heater RH125T Kerosene Forced Air...
Reddy Heater-30-55,000 BTU Variable Logo
185 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
