Question about Zenith ZRY-316 Video Recorder
Need a new remote for DVD player
I purchased the DVD Video recorder as a display model. They were unable to find the original box and or the remote to go with the machine. We have a universal remote but I can not get all of the features to work that are needed to run the divice properly. So I am looking for a place to purchase the original remote for this unit if it is possible to do so.
Ebay has it, i just bought one.
Posted on Dec 20, 2009
Hi i got a vhs/ dvd recorder from a friend who upgraded,but dont have a manual,i have set it up to my portable tv upstairs,which has a set top box,but dont really know if i have the cables right. the...
Hello Audrey,
If you can watch the videos on the TV, your cables are correct, but you don't generally record a video to DVD using the record button. Most VCR/DVD combinations have a DUBBING button on the front of the player and/or the remote control for copying from one to the other.
Additionally, some players can only record from video to DVD, some can only record from DVD to video and others will do both. On players that can do both, you need to instruct the player whether you want to record from video to DVD or vice-versa.
If you can le me know the model number of the player, I can let you know which recording options are available on your player, how to record and (hopefully) supply a new manual which you can download and print. The model number may be on the front of the player, but usually these are found on a label on the back of the player.
Regards,
BElectric.
Apr 14, 2011 | Televison & Video
I have a PYEvideo dvd recorder with video cassette recorder,PY90VG.i need remote control # NB654UD.remote control quit working
Provided you know the part/model number of the original remote, and you're prepared to spend the extra few dollars to replace the original remote with an identical new one, assuming it is still available, then go ahead and order it. Otherwise try a universal remote which is cheaper.
Not all functions can be guaranteed with a universal remote but most of them should work. Universals are cheap enough to buy just about anywhere. Only consider this option if the original remote control is not possible to buy or no longer available.
Feb 11, 2011 | Televison & Video
Need Remote fo RCA DRC8312N DVD-VCR Combo Thanks, Monte Haun mchaun@hotmail.com
My original remote malfunctioned for my RCA DRC8312N. I have purchased a RCA universal remote # RCR6473. I have used code # 3242 for the DVD code.It does almost everything that the original remote did except to open the DVD door. You just need to experiment with the onscreen info display in order to change title names and thumbnails etc. The remote also works great for other euipment functions as well as working features on my Sharp tv.
Sep 05, 2010 | RCA DRC8312N DVD Recorder/VCR
Connecting a freeview box
Your dvd player should be connected to the TV INPUT under norma conditionsl.What kind of recorder are you using? VCR player ?, Is it also a VCR recorder ( one cannot assume because I happened to own a VHS\vcr PLAYER, not player & recorder)Is Your VCR recorder? Then It must be connected to freeview box with universal scart to RCA converter box.You have "" dvd player in av2, vcr av1"" where? TV? freeview box scart connector ?
You will need scart to RCA converter box for sure.
Aug 08, 2008 | Televison & Video
External tuner
if it's possible attach a free-view box to it.
Jul 29, 2008 | Philips Magnavox DVD/VCR Dual Player
Toshiba dvd recorder model rdxs34su
Hit the display key on your remote control
the display key is situated on the bottom of the remote
bellow "ShowView"
Enjoy
Tournesol
Jun 26, 2008 | Toshiba RD-XS34 DVD Player/HDD Recorder
Programming remote?
on your remote try pressing enter and then the #3 this should program the remote to match the dvd player. It worked for me last night.
May 01, 2008 | Sony RDR-VX525 DVD Recorder/VCR
Sony SLV-D350P DVD/Video cassette Player
I have the manual. Are you trying to record something live? if so:
1) Turn on both the DVD/VCR and your TV.
2) Switch the input selector on your TV so that the signal from the player appears on the TV screen (this is usually something like 'input 1' or 'line 1' and so forth)
3) On your remote, set TV/DVD-VIDEO to DVD-Video, then press SELECT VIDEO to control the VCR. These buttons are at the upper left hand corner of the remote controller.
4) To record from a cable box, turn it on.
5) make sure the tape is longer than the total recording time.
6) insert a tape into the VCR.
7) press CH +/- on the remote to select the channel or line input video source to record.
8) select the tape speed SP/EP (SP provides better quality, EP provides three times the recording time as SP)
9) Press the record button to start recording. The VCR display will display the message REC.
Nov 25, 2007 | Sony SLV-D350P DVD Player/VCR
Can't set this thing up
I have the same model and it works wonderful, but you need the remote control to record.  connect cable from video out on recorder to video in on you tv. at least you'll be able to play the dvd.  If this doesn't work it's because you need the remote to set the date and time features.
Aug 26, 2007 | GoVideo R6640 DVD Recorder
LASONIC DVD PLAYER NOT WORKING WITH COMCAST BOX OR SOYO TV
you have to plug everything to the tv. only thing them are good for is recording to some other unit. like dvd recorders
Mar 05, 2017 | Lasonic DVDP | DVD-7050 5.1CH
Zenith ZRY-316 Video Recorder Logo
101 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
