Question about Watches
Battery replacement polar s520 - Watches
Polar f4 batery
The Polar F4 needs to be sent into an authorized service center for repair or battery replacement.
Jan 18, 2011 | Polar F4 Heart Rate Monitor Watch
Watch stopped working, replaced battery still doesn't work?
The only solution is too send into a Polar Authorized Service Center. Regular watch shops are not equipped to diagnose and/ or fix problems with Polar watches, or most other Heart Rate watches for that matter.
Nov 22, 2010 | Polar F6 Wrist Watch
Hi - is the battery on the Polar FS2C changable - and if so how can I do it?
Open watch case back, then release the metal contact covering the battery. Memorize battery's polarity (+ up and - down), then take the battery out. Memorize the combination of letters and numbers on battery (should be something like: CR 3216 or similar). Make does not matter - Seiko is as good as Maxell, Panasonic and other reputable makes. Buy new battery with identical combination of letters and numbers and put in your watch. Replace back contact, gasket and case back. Set your watch and enjoy. Rate me, please.
Feb 28, 2010 | Polar FS3 Heart Rate Monitor Watch
How to replace battery in polar f4 watch
HOW TO REPLACE BATTERY IN MY POLAR TARGET WITH A TS1 TRANSMITTER
Nov 25, 2009 | Polar F4 Heart Rate Monitor Watch
What battery do I need for Polar F6?
Always look at the numbers on the old battery first and replace with the same. If you don't have the old battery then I would check with a local business that sells that watch. Sometimes you might find the battery number engraved on the case back. Hope this helps you,.good luck.
Nov 05, 2009 | Polar F6 Wrist Watch
Which battery do u reccommend for the polar ft80 ?
Hi
Thanks for using FixYa. You need the battery recommended by polar as replacement. You can buy it/view from this link--
Polar ft80 Replacement battery
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 05, 2009 | Polar Watches
No screen display
Try new battery
From
AmFix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Oct 01, 2009 | Polar S520 Wrist Watch
How do I change the battery?
Someone posted a link on how to change the batter on an F11. If it's not longer under warranty or you just don't want to bother with sending it back and the extra costs, you could follow this: http://timlaqua.com/2008/09/how-to-replace-the-battery-in-a-polar-f11-heart-rate-monitor-hrm/
Jun 10, 2009 | Polar M32 Heart Rate Monitor Watch
Chenge the battery
Response to Wasilij: The belt is sealed, so it can be used while swimming. It's not meant to be opened. They replace the whole thing, instead of replacing the battery. So sorry, not going to work.
May 12, 2008 | Polar M32 Heart Rate Monitor Watch
Watches Logo
96 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
