Question about Welding Tools
My welder wont do anything but click
I have a 110v lincon stick welder and when i plug it in and turn it on it clicks a couple times but nothing happens, the fan doesnt kick on and none of the lights come on.
  • Robert Lee May 11, 2010
    do you have a model number or a code
  • 92 Answers
If the unit clicks twice it souds like the relay makes then breaks, take a look at the relay contacts if you can get at them, also check the wireing to the relay for damaged connections or bad soldered joints.
Spray the contacts with electrical contact cleaner.
Posted on Feb 15, 2009
Wire wont feed on my welder
I would call miller and get a number for the closest repair station. They have a three year parts and labor warranty. 1-920-735-4505
Jan 10, 2015 | Miller Multimatic 200 MIG TIG & Stick...
My lincon welder sa 250 won;t turn on after i turn it off
Lincoln's welders have a very weak on/off switch sometimes you need to wiggle the switch a little bit to help make contact. Try this, open the welders cover and using an insulated tool and insulated gloves try to bridge the switch. If the machine makes contact then buy a new on/off switch and change it.Other tip is to check your cable plug to see if all cables are still in place.
Nov 10, 2011 | Welding Tools
I have a Lincoln 120v wire feed welder, model 140, and while welding, the gun cam unplugged and it arced a little on the plug end, and now, the fan runs, but nothing else will happen, it has been two hours...
Check your switch terminals, if they are connected and everything looks good, then unplug the terminal and bridge the connector (bypass it) if it start turning your drive rolls then your switch it's damaged, if nothing happens then you burned the pc board.
Dec 08, 2010 | Welding Tools
Lincon LS 2006 5600 kl coolent fan runs in winter when the temp gage is normal the radeator is not hot.The fan is very noisy, the engin has ben bled of air. The car has ben looked at by Lincon dealer said...
the fan has a low and high speed or some have 2 fans. It comes on low speed when the temp starts to climb or when you turn the a/c, defrost, or mix mode (it turns on when the a/c compressor kicks on. If the temp of coolant gets to about 230 F, then the high speed kicks in.
What is your doing? Very nosiy sounds like high speed. Could be a defective ECT - engine coolant temp sensor.
Dec 07, 2010 | 2006 Lincoln LS
Lincoln 3200hd. welder,when power switch turns on, the fan comes on, but when i pull the trigger on gun to start to weld nothing happens the wire does not feed. i am not sure what is happening
open the area were the role of wire is and check when trigger pulled if any action to feed motor. [wire might be stuck at end, or there usually is a small fuse in that area for feed motor]
Dec 04, 2009 | Lincoln Electric K1170 AC-225 Stick Welder
Welder doesnt turn on...
Have you connected the feed from your breaker box to ADJACENT lugs on a dual pole breaker? By code you must use a ganged breaker.
You should use a voltmeter to verify the plug is getting power on teh desired pins.
Sep 25, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Hobart handler 140 wire feeds properly, will not weld
If it is new i would not play around with the welder Just take it back to where you bought it get them to replace it under warranty
Jun 10, 2009 | Hobart Handler 140 Mig Welder
Welding Tools Logo
71 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
