Question about Westinghouse L1975NW Monitor
Computer Monitor Only has a little green blinking light.
The monitor was previously working. However, this morning the computer booted up normally, but the screen was black. The only sign that the screen is working is that the little green light next to the power button is blinking. The power switch on the monitor doesn't turn the monitor on or off. If I disconnect the cable from the screen I do not see "No Signal" on the screen.
  • pbb3239 Feb 11, 2009
    same problem, woke up, screen in energy saver mode, with amber LCD, hit the keyboard, LCD turns green, but screen stays blank. hit OSD button, nothing happens. plugged into another computer, still the only response is moving from amber to green LCD.
  • 1,684 Answers
It sounds like you have a monitor with a common problem, this series of Westinghouse monitors are known to have this issue. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. When the capacitors blow out they also damage the driver MOSFETs. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. I am putting together a step by step repair guide for this series of LCD monitors, it should be up by 07/11, check my web site for the guide. Repair parts kits are also available for $16.95 If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. If you are not going to repair it we will buy it from you for parts, we pay $30 for dead/as-is units.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 11, 2009
Hello when I turn on my monitor and computer this morning I have a black screen on my envision monitor and the green light keeps blinking do you know how to fix this
Unplug everything from the tower. Including power cord.
Press the power button for 5 secs.
Proceed to connect, power line, mouse, keyboard and monitor
That should reset the power or hibernation mode that you might have issues.
If everything looks normal, proceed to connect your remaining devices.
You must be aware that having a BIOS settings to boot from USB, DVD or USB-FLOPPY might prevent to boot into windows.
Feb 24, 2015 | Envision Computers & Internet
I have A Chimei CMV 221D LCD monitor. I am thinking from memory it is a 17 or 19in monitor. It's black in colour. It worked well, loved it but one day I booted the computer up and the light went from...
boot your computer into safe mode that eliminates any special resolutions from your normal windows if your display is good in safe mode then your computer resolution is set at a level the monitor cannot use you then will need to reset your normal resolution to a lower level
Mar 25, 2017 | Chi Mei Corporation CMV-221D LCD Monitor
Blinking green light
this problem is adjust not screen resulation on your computer safe mode restert your computer and fress F5 go to safe mode
thanks Tareq
Sep 08, 2009 | ViewSonic VX922 19" Monitor Flat Panel
Monitor goes black............
try checking the cables first.
May 28, 2009 | Dell E176FP 17" LCD Monitor
Envision EN7410e monitor
hi this is jannet and am expert to solve your issues kindly call us to this numaber +1(518)348-9393
Oct 06, 2017 | Computers & Internet
Viewsonic vp930b-3
MY VP930b has the same problem.
It takes a very long time (5-10 minutes) before it becomes normal.
Aug 04, 2008 | ViewSonic VP920b 19" LCD Monitor
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
Monitors on/off green light flashes
Try first unplugging the monitor and the computer from the wall for 12 to 24 hours. If this does not work, hook up another monitor to the puter to see if the problems with the puter or the monitor.
Sep 22, 2006 | Dell E171FPb 17" TFT LCD Flat Panel...
Westinghouse L1975NW Monitor Logo
341 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
