Question about Sanei Freescale IMX6Q Tablet PC
Sanei n10 tablet not 3g using a lot of battery on phone standby mode, no airplane mode available. How do I turn off standby mode
Battery use at 50% phone / cell standby mode. This is not 3g version and has no airplane mode to turn this off. Using heaps of battery, how do I turn it off
I have an sanei n83 tablet but battery is dead after an hour
you probaly have to replace the battery thats actully inside the tablet itself
Nov 01, 2014 | Sanei N83 Dual Core RK3066 1.6GHz 8 Inch...
My tablet n78 is shut off .it wont charge or show any sign....
Test your charger with a multimeter or take it to a Battery+ store to see if it still provides the proper charge (they test it for free). If your charger is good, it might be the internal battery of the tablet or the main board.
Dec 08, 2013 | Sanei N78 7 Inch Android 4.0 Tablet PC...
Sanei tablet not switching on
It's normal for a device to heat up during use and charging. As long as it's not too hot to hold, there isn't a problem. If it is hot enough to burn you I'd replace the battery
Dec 08, 2013 | Sanei N80 8GB Allwinner A10 Cortex-A8...
Sanei tablet 3it is not running on laptop pc hp
To connect up a tablet with a laptop you need to connect them with a USB cable.
On plugging in the cable with the tablet powered up, you should see two things.
1. A question on the tablet as to whether you want to use memory disc mode or diagnostic(ADB) mode. Choose Memory disc mode.
2. You should see on the PC laptop it recognise that an external device is connected, it may recognise it as a phone or a memory drive.
If neither of these things is happening it is probably the cable at fault.
The tablet should then start providing the pc laptop with the drivers it requires to be recognised. If this does not happen, then the fault is with the tablet and you have to consult your supplier.
You should end up with at least one memory drive which you can browse through with the PC's file manager. The data will be on the tablet.
Nov 30, 2013 | Tablets & eReaders
It's my iPad mini what does airdrop and airplane mode mean?
Airplane mode turns off 3G and wireless etc. Good for when you are on an airplane or when you are out of range and wish to save battery.
Eg. get on a airplane activate airplane mode, switch off device, plane takes off, then when the seatbelt sign comes off turn device on, and play angry birds or watch a movie without any risk of interfering with plane.
Airdrop is a public folder, that allows you to share images, vids and links via wireless. Similar to Bump, it is less dorkier than having 2 phones have to "kiss". lockable to no airdrop contacts or everyone. See http://howto.cnet.com/8301-11310_39-57602505-285/getting-to-know-airdrop-on-ios-7/
Oct 26, 2013 | Unknown Apple Ipad Tablet 16gb 32gb Wifi...
Users manual Sanei N79 Android 4.0 3G
A .PDF version of the Sanei N79 user manual in English will be available shortly (Mid Nov 13), if you require a link to it, mail us at nexusgruppe@gmail.com
Jun 10, 2013 | Tablets & eReaders
How do i do factory reset on sanei n91 tablet
How do i do factory reset on my daughters sanei n91 tablet she lost pattern lock and had tablet in flight mode so cant recover from email holding power and volume does nothing for reset.HELP
Mar 07, 2013 | Tablets & eReaders
Sanei n10 manual english
i have sanei n10 tablet and i lost the password and google accaunt what can i do ?
Jan 21, 2013 | Easy SANEI N10 Android 4.0 Tablet PC 10.1...
Sanei Freescale IMX6Q Tablet PC Logo
Top Sanei Tablets & eReaders Experts
Are you a Sanei Tablet and eReader Expert? Answer questions, earn points and help others
