Question about Black & Decker V9610 DustBuster Handheld Vacuum
How do i change the battery in my dust buster15.6v
Eureka airspeed one
DustcupScreen
Latch
Pull dust cup latch to release
dust cup. Remove filter and wash. Allow to air dry thoroughly (24 hours) before placing back in dust cup
Empty the dust cup into the trash container. Wipe debris off screen.
Hold dust cup handle in one hand and the bottom of dust cup in the other, turn dust cup counter clockwise to unlock the cup from the lid.
Hold dust cup handle in one hand and the bottom of dust cup in the other, line up arrow on dust cup with unlock icon on backside of dust cup. Turn clockwise to lock the cup to the lid.
Replacing the Belt
Unplug vacuum.
Recline cleaner back. Using Philips screwdriver, remove 4 screws from hood.
Using thumbs, push down on height adjust knob, while pulling up on
inside hood edges with fingers. Lift and remove hood.
Lift left side of brushroll out of
grooves. Then lift right side of
brushroll out of grooves.
Line up corners of hood and put hood tab inside the front of cleaner. From front to back, push hood onto base, keeping hood in base grooves, and line up 4 screw hol
Remove belt from the brushroll and motor shaft. Loop new belt over motor shaft and brushroll, onto grey belt pulley.
Jun 28, 2013 | Vacuums
How to change bag
Hey, changing the dust bag can be a little difficult. Remove the old dust bag, then using a new dust bag, align the cardboard wiht the bag holder's black grooves. Slide the bag cust into the grooves with the black arrow pointing up.
Here's a link to the user guide if you can't locate yours.
http://www.bissell.com/user-guides/?searchtext=4122&searchType=search&mode=undefined&lf=228&cid=ccsocial
Dec 25, 2012 | Bissell Vacuums
4210 battery light is full charge. runs for 5 sec. and nedds to be recharge again
Roomba's are noted to catch dust inside inwhich they will not operate correctly. Remove the entire housing parts and clean out all existing dust in this machine. It will run much better
Jul 05, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
How do you change the dust bag on the Nilfisk King 505?
Press the middle rectangular Nilfisk button in the top centre of the machine. The front cover will fold down. There is a greay retaining bracket which clips forward off the top of the old bag. Fold that forward, replace the bag, clip the holder back on, and then close the lid.
May 20, 2010 | Vacuums
Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
Feb 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Black and decker handheld vacuum phv1800 type 1 low battery power
Hi I know what you mean! My B&D dust buster used to do this too. The hi power boost means that it can only be used for a limited amount of time. Due to the age of the dust buster though its a sign that the battery is on its way out and regardless of whether or how long its been used or not used, batteries can lose power regardless.
Try to let the dust buster completely lose power and then charge it up for its initial burn in period of 14 hours. Also clean the connection metal strips or hole with a dry cotton bud incase there's any static or dust. Then see if it lasts longer. If the turbo mode or speed 2 is still short, then the battery is dying out.
I don't know where you are but in the UK its hard to get battery replacements for B&D products. You could check your local seller where you are if they have battery replacements but at the cost of current dustbusters it may make more economic sense to consider buying a new dustbuster.
Jun 19, 2009 | Vacuums
CHANGING THE FILTER
You have to install the filter in the dust cup lid first, then put it in the dust cup. There are some clips that filter will fit into on the lid. Also, take a look at the maual. http://www.eureka.com/service/manuals/75287_eng.pdf
Feb 26, 2009 | Eureka 431A Optima Bagless Upright Vacuum
DUST BUSTER 7.2 POWER LASTS FOR UNDER ONE MINUTE??
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=859375
Generic problem for all Vacuums
Posted by bettedxx on July 31, 2008
DUST BUSTER 7.2 -- POWER LASTS FOR UNDER ONE MINUTE??
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The problem that people have with dustbusters is that when they 1st get them they need to say train the dustbusters to extend the battery life, the process is simple – when you 1st buy the dustbuster then you charge it up the 1st time and then you turn it on and drain the battery down to nothing, and then recharge the dustbusters again, and by doing that you have a larger battery life and it will run longer – but dustbuster and vacuums like that do not tell you and when people buy the item they just turn it on for a minute or two and then the battery does not get a “memory” as per how long it should run. By doing this the dustbuster will last and run longer and will have fewer problems. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 31, 2008 | Vacuums
How do I change the belt for my dirt devil vacuum cleaner? It blows out dust.
To change the belt, take off the bottom plate, the belt runs between the brush roll and the motor shaft. But if it is blowing out dust, you may have a clog in the dirt inlet by the brush roll, or in the hose.
Mar 23, 2008 | Vacuums
Black & Decker V9610 DustBuster Handheld Vacuum Logo
52 people viewed this question
Top Black & Decker Vacuums Experts
GG TECHNOLOGIES
Greg Cann
Greg Cann
Are you a Black & Decker Vacuum Expert? Answer questions, earn points and help others
