Question about Amana PTH123B25AJ Heat Pump Air Conditioner
Need to know what the settings are for the range adjustment A,B,C,D slide switch on the front panel on a Amana PTH123A35AC PTAC
  • batrob Feb 11, 2009
    I found the info printed on the curcuit board under the metal shield same as the above after I found a flash light to look at it more closely, problem solved, thanks.
  • Tommy Walker May 11, 2010
    I have this info. for you. I will send it if you are still in need. Let me know.
  • 142 Answers
Here they are;
Position A, Cool 70-78, Heat 65-73
Position B, Cool 68-81, Heat 68-76
Position C, Cool 66-83, Heat 61-78
Position D, Cool 63-88, Heat 58-83
Amana calls this a Temerature Limiter and says to only set one switch on at a time. If all switches are off then the unit is at full operating range.
Please rate this answer to let me know if it was the fix.
Posted on Feb 11, 2009
Replacement of Whirlpool part 77001257 by 8203529 for Amana ARTC8600WW range...
Control switch for dual heating surface element in our Amana ARTC8600WW range (year 1999) failed and did not cycle power after the heating element was turned on. The range was in very good condition so we wanted to replace the switch. However, the original Amana part Y0315855 was not available. The company was taken over by Whirlpool and we found that Whirlpool part 77001257 should be used. But that part was not produced anymore either. On Best Buy web site we found information about an alternative 8203529 Whirlpool part. We order it, installed into the range, and got no action. From other web sites we quickly learned that the part is not the right replacement and that there is no replacement switch for our range at all. We hesitated to replace entire range so instead of returning the part to Best Buy we decided to investigate the differences between the original part and 8203529. Soon we began to believe that 8203529 should work. Specification as well as all connections were fine so we tried to adjust a little bit the tension of bimetallic element inside the switch. There is a tiny screw accessible for this purpose. The adjustment can be done be a 5/64 hex key which, for electrical safety, we insulated by a plastic tube. Immediately we got the expected action. We tested all settings before mechanical installation and all of them worked very well. The mechanical installation of the switch needed a makeshift bracket to distance the switch from the back of the panel wall in order to get the position of the switch knob properly leveled with the front wall of the panel. Just shortening the shaft of the switch was not sufficient. The bracket that comes with 8203529 was not suitable for our range. It was not difficult to make another bracket so we repaired the range without compromising its functionality or safety. That confirms that part 8203529 can be used in place of Whirlpool part 77001257.
on Sep 06, 2015 | Kitchen Ranges
My amana ptac is not heating....the code "np" is do I correct this...we just installed the unit and know little about operation. Thanks
I don't see this error code in the manual. I do see nP as an error code for Window Switch lockout. I just had this happen to me and they had me reset the control board.
Remove case, flick master switch to OFF for 10 seconds. Press Heat/Cool same time turn switch back on HOLD until off light comes on.
You should be fixed. Just had to do this for my unit. I was playing around with the settings and turned on the window switch option by accident.
Feb 02, 2013 | Amana In Wall Install Kit For Digismart...
I have an Amana packed unit...blows cold air when on heat but if i turn temp to 90 then heat will come out but not at 72 or that range.
you probably have a packaged unit with a line voltage thermostat which is out of calibration...not an unusual situation. other than replace the stat, why not just use it by just setting where you need to - to get the results you desire? use a regular thermometer placed where you want to control to help you adjust properly.
Jan 27, 2013 | Amana R410a Package Terminal Ac Ptac 7600...
I need a manual for a Amana PTAC model PTH123A35AC. I been looking for one & just can't find it. Please any suggestions, thanks.
Here's a good place to start:
The Amana PTAC PTH123A35AC is obsolete and replaced by the Amana PTH123E35AXXX. The literature is similar. Search out your model # and than visit the "literature" tab to find everything's that available. Everything from service manuals to parts manuals. Good luck!
Aug 27, 2012 | Heating & Cooling
Looking for manuel reset on heater amana ptac unit heat won't come on new control board
I dont know about this model but in general electric heat wont have a reset button the heat is controled by a sequencer and each elememt has a safty limit switch incase the sequencer sticks in the on mode here is a link to where you can get more info on this model
Oct 30, 2009 | Amana PTC153B35AJ Air Conditioner
How to remove timing control panel on Gas Amana Range AGS746E
Here is a diagram of your stove console. Make sure you remove the nuts holding the switches to the console.
Feb 25, 2009 | Ovens
Need parts for an Amana PTH123A25AA PTAC
The Amana parts line # is 1-800-227-2919, you can also obtain parts numbers and names from their website,
Please rate this answer and let me know if this helps.
Dec 13, 2008 | Amana PTH123B25AJ Heat Pump Air...
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
324 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
