Question about Sony STR-DG520 Receiver
No play back from HDTV to threater system
Have a 32 Vizio LCD, hooked outside co axil cable to TV. Then from TV to sony system,STR DG520,one hdmi cable and red and white cables to sony system.I think in proper outlets from TV to proper inlets on sony. No play back on sony, no
surround sound from the threater system.The system works ,somewhat , I am getting the AM/FM tuner coming through system, any ideas? Cable to TV from TV to system, HDMI cable and Red and white cables to proper in lets and outlets?
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Please check..does your TV has HDMI OUT port? or it is HDMI IN port.
    Scholar:
  • 127 Answers
Do you have set-top-box or antenna-cable directly to TV?
You have connected TV with received via HDMI, but that won't work in this direction - TV has HDMI INput only, not output.
You can use HDMI to connect HDMI-out on DVD player for example to HDMI-in on receiver and HDMI-out of receiver to HDMI-in on TV.
But to get sound from TV to the receiver, use spdif optical or coax cable if TV supports that - this way you will get surround sound.
But also your connection via analog white/red RCA plugs should work, but only for stereo sound.
Posted on Mar 03, 2010
Can a 32in vizio tv be connected to an outside antena
Janice, yes you can hook up antenna. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://cdn.vizio.com/documents/downloads/hdtv/VOJ320F1A/171Manual.pdf
How to Hook Up TV Antenna
can watch tv on vizio without cable or dtv box
How to Connect an Antenna or Cable to Your HDTV For Dummies
Aug 04, 2016 | Vizio VW32L 32 in. LCD HDTV
Im having a hard time getting audio useing the hdmi ports on my sony str-dg520
The HDMI on this receiver is for video pass through only. It basically only serves the same purpose as an extension cord for an HDMI cable that's too short.
For audio you need to connect either a digital coax, an optical or composite cables.
Aug 25, 2010 | Sony STR-DG520 Receiver
I bought a hdmi cord so my son can play ps3 we
Hi:
Check the video connector on the PS3 for a switch to switch from composit video to HD video.
Dec 26, 2009 | Vizio VW32L 32 in. LCD HDTV
Video but no audio
This receiver does not support audio via HDMI. You need to connect BD player via spdif cable. Use optical or coax depending on what does the BD player support - receiver supports both.
Dec 24, 2009 | Sony STR-DG520 Receiver
What cables do you need to connect a dvd player to a vizio hdtv
If your dvd player has a hdmi hook up "easy" just use 1 hdmi cable from the dvd player to the tv. If not use the 5 cord for better picture quality.
Nov 08, 2009 | Vizio L32 32 in. LCD HDTV
I connected my STR-DG520 5.1 to my TV Toshiba
In your str-dg520 menu you have the option to have the sound routed to your tv or out your stereo system. select which one you want.
Jul 12, 2009 | Sony STR-DG520 Receiver
Connect home theatre to ps3 to 32" lcd tv
if your tv and home theatre system as all hdmi or component hook ups then follow these steps but only use all one or the other cables.
1. hook the cable from the ps3 to the home theatre "imput slot" (you choose which one you want to use)
2. hook a cable to the output slot on the home theatre system to your imput slot on your tv.
3. turn on all three systems, put your home theatre system on the correct function (which ever slots you decided to put the cables in to the input slots) then turn your tv to the correct AV channel
Apr 05, 2009 | Vizio L32 32 in. LCD HDTV
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
Vizio 42" LCD HDTV - sound went out
Same thing just happened to me contacted Vizio had me unplug the TV from the wall for about a minute and then replug and cut the TV back on and everything was fine. I have the television hooked into HDMI1.
Sep 07, 2008 | Vizio L32 32 in. LCD HDTV
Sony STR-DG520 Receiver Logo
347 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
