Question about Gateway 700g 17" Lcd Monitor
GATEWAY MODEL NUMBER 700G
SCREEN BLACK BUT CAN HEAR BOOTUP POWER LIGHT ON MONITOR BLINK FIRST AND THEN STEADY BLUE BUT STILL BLACK.... USE MOUSE AND KEYBOARD....UNPLUG AND REPLUG EVERYTHING CHANGED BLUE CABLE CORD
  • 26 Answers
SOURCE: Dell E151FPp LCD Monitor
Next time you reset, check both the monitor settings and your BIOS settings for wake up
Posted on Feb 25, 2008
freetek
  • 5568 Answers
SOURCE: Gateway Monitor
Unfortunately, the power supply is internal to the monitor and this is the likely problem.
It is of the 'universal' input type that is compatible with a range of  90-264 VAC 50/60 Hz indicating that it is a 'switched mode power supply' and these have a design problem that makes the reliable operation of the supply doubtful unless a certain weak point (electrolytic capacitors in the feedback path) is properly attended to.
The run-of-the-mill capacitor in this useage is subjected to high ripple currents which can cause a cheap capacitor to chemically break down, dry out and then finally fail to pass enough signal to keep the supply running or enable it to start up.
If you are adventurous, you can open the monitor, examine the components near where the AC power cord terminates and look for vertically mounted, cylindrical parts with shrink wrap bearing the values and an exposed, scored, aluminum top.
Sometimes, the top will bulge or the base at the board may show signs of crystalline deposits.
If you find no parts that appear as described, the alternative is to find a tech who owns a capacitance meter with DF (loss) function. So equipped, the failed part is fairly easy to find.
The values of these parts will lie between 4.7 to 100 uF with voltage ratings of 6 to 35 VDC.
Defective parts need to be replaced with special capacitors that are rated for high frequencies with low losses. These parts cost a few pennies more and most companies don't seem to care about the eventual failure of the inferior parts since it will typically happen after the warranty expires.
Posted on Sep 12, 2008
  • 152 Answers
SOURCE: gateway monitor, black screen with blinking power button
wjfarm48, Sure sounds like a power supply problem. How old is it? How many hours of use? Do you understand what a switch-mode-power-supply and an inverter supply is? If not, then here are your options. Check with Gateway to see if there is a swapout program. You box up and ship them your monitor+cash, and they return a REFURBISHED same model with new CCF tubes and inverter/SMPS. When you box up the monitor, follow this lead. "A 3 inch thick layer of breathable air shall be the only thing touching the lcd front panel" Next option is find some local TV/Monitor repair guy who can get parts and or replacement boards/CCFtubes from Gateway. Last but not least, is to repair yourself. Not Recomended.. But do a search on lcd monitor repair or Bad Capacitors In LCD Monitors or Repair of SMPS in LCD/FPD Monitors. Also check for videos on YouTUBE related to lcd monitor repair just for your own info. Here 's what you are dealing with. The light that makes your FPD bright white is generated by Cold Cathode Fluorescent Tubes (2) that require 600-1200vac at high frequency that is generated by an INVERTER which gets 12-24vdc from the SMPS. Almost the same technology is used in the new style screw-in curlie-que Compact Fluorescent light bulbs. Only they call the inverter a electronic ballast. Anyway, thats about all the info I have. Let me know how you make out in you quest to get your LCD up and running again. I'm louie12fix on fixya or lmistyrel@ aol.com BYE for now.
Posted on Apr 03, 2009
bootz84
  • 197 Answers
SOURCE: Gateway 19inch wide screen, lcd monitor stopped working randomly.
It could be a faulty power cord. Try plugging it in and moving the cord around in the areas where it takes the most movement. Do the same with the data cable to see if you get a response there. If your cables are fine, the problem is most likely hardware in the monitor - in that case you're better off replacing the monitor.
Posted on May 06, 2009
FixinFax
  • 3085 Answers
SOURCE: Needed: power supply for a gateway 700G monitor!(internal)
try ebay.
Posted on Jun 13, 2009
Why does my gateway fpd2185w monitor screen go black after showing my desktop for about 1 minute
David
That problem is calle,refresh, thats happend when the monitor try to refresh the page or "clean" the page, you can set that in your video driver options. but if you don't have a video driver for your particular video card already installed, you don't have a right refresh rate and this delay, may happend.
Carl
Mar 22, 2016 | Gateway Computers & Internet
Black screen blue light blinking
LCD backlight is faulty. Need repair.
Oct 25, 2013 | Gateway HD1900 19" Monitor
My monitor does not turn on and the power button light keeps blinking ... <my Gateway monitor light blinks blue slowly but the screen is blank
This is usually a sign that there is no signal going to your monitor, check all your cables and then reboot.
Jun 28, 2010 | Gateway FPD2275W LCD Monitor
Monitor appears to be in permanent standby mode - - black screen and blinking blue power light. It is a Gateway FPD2185W monitor. It will not turn off or on. Unplugging and re-plugging changes nothing. ...
Look for bad caps with bulging top in the power supply. I would replace all 10 with PANASONIC FM or FC series from DIGIKEY. Post back what you see inside so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 22, 2010 | Gateway FPD1975W 19" LCD Monitor
Gateway FPD1750 monitor's keep go black screen, no picture at al
tgordon60, If you know how those NEW "CURLIE-Q" energy efficient CFL light bulbs produce WHITE LIGHT, then you will know what makes an LCD display panel produce all the pretty colors and the WHITE BACKGROUND of the FIXYA web page!!! Only difference is that your "cold-cathode-fluorescent-lamps" are thinner and straight, and hung on rear of LCD glass panel and have a DC to AC electronic ballast called an "INVERTER" circuit to produce 600 to 1000vac to light them up. Get to my FIXYA profile and read my responses to other BLACK screen lcd owners to learn about all your options for repair. Follow any of the links to other web pages you find there. Your monitor not any different than ACER, DELL, VIEWSONIC, BENQ, SONY, AOC!!!!! 12fixlouie aka louie12fix
Dec 30, 2009 | Gateway Computers & Internet
THE WINOWS STARTUP SHOWS ON SCREEN ON/OFF BUTTON IS BLUE
Is your keyboard also wireless? Check batteries on all wireless devices. If batteries are fine, restart your computer (hold down your power button until your computer shuts down unless you have a reset button) and then try unplugging and plugging back in your wireless receiver, then hit your connect buttons starting with your keyboard followed by your mouse.
May 06, 2009 | Gateway FPD1975W 19" LCD Monitor
Monitor problem
i have the same problem , so after the p.c. is turned on and gone through it;s startup procedure, i wiggle my mouse and press the last button to my right on my monitor , and there you go, hope this helps?
Jun 08, 2008 | Gateway FPD2275W LCD Monitor
Gateway 700g 17" Lcd Monitor Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
