Question about SmartDisk FireLite 40 GB Hard Drive
FireLite FWFL40-N (Firewire) External HD wont turn on PC or MAC
I have a FireLite FWFL40-N that was bought in either 2003 or 2004 around x-mas and just in the last year it randomly quit working.  I haven't had time to fix it yet or even really search for much troubleshooting on it.  I just remember one day when trying to use it on my Powerbook G4 that it wouldn't turn on, no power showed on the HD and it wasn't showing up on my drives list on the desktop.  I tried again on PC with the same problem.  I just found a power adapter to see if the "no power" was the issue of my firewire, which must be part of the problem because after plugging it in w/ the AC adapter it turns on but it still doesn't sound like the HD is running at all and it is still not showing up as a drive on my MAC.  Has anyone else had this problem or is there any genious out there that might know what it is?  I'm about to the point of taking it apart to work on the insides if I have to!
  • 3,153 Answers
Make sure the poer adaptor you use is rated for the same or better in terms of current. The instruction for the drive tell you what this is but for example it may be 5V 500mA in which case you need either the original power supply that is known to be working or another on that has those ratings (it does not matter if the mA or A is a little higher but never lower.
If its not the PSU then by all means dismantle it take the drive out and fit it into a pc to check the drive itself. If the drive comes up OK then you know for sure it is the enclosure and these are now cheap enough.
Posted on Aug 11, 2009
3 Suggested Answers
  • 158 Answers
SOURCE: firelite smartdisk
sounds like the firewire drivers are corrupt try and re-install drivers and if that did'nt help take drive to a friends house that has firewire on his computer and try on his if you get the same it's got to be sent off to be repaired and hopefully you can get files back thats why i take 2 copys one on one hdd and another on another and if one goes down I've got a back-up to fall back
Posted on Aug 14, 2007
  • 5 Answers
SOURCE: PowerBook G4 does not seem to recognize. (Worked well on previous Apple lap top)
If your Firelite SmartDisk was formatted for a PC, and you are using the Mac side of the G4 it won't. They use a different format scheme. Need to load Parallel, bootcamp, or another virtual PC program, and then Windows. Using that it will recognize it.
If you know another Mac user that is using both sides (Mac and Virtual PC) is a quick way to retrieve data to move it. Be careful reformatting the FireLite. There are some more complex ways. Hope that this helps.
AAirwolf
PS: I use a 160GB FireLite on my G4, MacBook Pro as well as my Tower and notebook PCs.
Posted on Aug 08, 2010
Power supply
Input voltage for the FWFL40 is 33V DC. I hope this helps
Nov 04, 2013 | SmartDisk FireLite 40 GB Hard Drive
Where can I purchase the cord for my FWFL40-N to be used with a MacBook Pro?
I have a firelite USBFLB60 60gb. My cord broke, so I just ordered "Cable Wholesale USB Type A Male / Mini-B Male Cable, 5 Pin, Black, 1 ft" from Amazon for very cheap. I think that is the correct adapter, and I imagine it would be the same for yours.
Mar 13, 2012 | SmartDisk FireLite 40 GB Hard Drive
I have firelite external and it's not working. There's light but no spinning sound. what can I do?
This a firewire drive and needs to plugged into a firewire port to spin up. If you do not have a firewire port on your computer (most PC's don't) it will not work. I don't believe a firewire to USB connector will pass enough power to the drive to spin it up.
Mar 12, 2012 | SmartDisk FireLite 60 GB Hard Drive
I have a smartdisk firelite hardrive, is it possible to transfer the data onto a windows7 laptop. Model number of the hardrive FWFL40-N
Yes, it will work if the disk is operational and the laptop has an firewire port with all the drivers installed.
Just connect the disk and it will appear in Computer as an external disk.
Apr 26, 2011 | Computers & Internet
I have a Firelite Smartdisk External 60G hard drive - Model #FWFL60-N which I bought to back up my previous MacBook. It only has FireWire outlets and cable with only FireWire ends - no USB port...
Hi Selina It was a big mistake for Apple to omit the FW port on the white MacBook. The problem you hilite is the reason I don't recommentd the macbook to any of my clients. However, the problem is solveable - although you may/will have to do some breaking and entering.
There is no cable adaptor - nor will there ever be, the protocols are so radically different that they can never talk to each other.
The simplest option is to connect your drive to another mac that has got FW (800 or 400 - it doesn't matter as long as the cable will connect the two units) then use file sharing to transfer the conent of the drive to you MacBook either by ethernet (preferable) or by wifi (much slower).
The breaking and entereing option imvolves opening up the firelilte and removing its HD (it's easy) then get a unit like this Overview or this http://www.maplin.co.uk/sata-hard-drive-usb-docking-station-222999
There are other much cheaper units and they all work fairly well. I have several as I'm up against your problem regularly
Apr 01, 2011 | Computers & Internet
Smartdisk Firelite 120 GB wont delete
Try to reformat the external hd thru the disk utility.
Sep 03, 2009 | SmartDisk FireLite USBFLB120 120 GB USB...
Verbatim 160 GB portable hard drive doesnt want to open IbookG4
must be usb, usually if you have other devices using this resource and have not closed them it will not work. close all then add hardware, follow the rest it should work.
Apr 24, 2009 | Verbatim 160GB USB FireLite: The "drive...
Formatted hard disk on pc now it won't run on mac
Try plugging your hard drive into your mac, open "Disk Utility" select your hard drive in the list on the side, Click RAID, change the Volume Format to MS-DOS (FAT), and it should work.
Hope this helps!
Apr 03, 2008 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
My Book firewire not bootable on mac
I picked up a couple of My Books lately( via Ebay), and noticed that i can not get them to work on the Firewire interface with my Dual Core Intel Mac. Shows up on USB2.0 fine however.I found an online reference that said Apple changed some things on the Firewire interface year or two ago, and that vendors had to update their firmware (it related to Firewire devices reporting a unique ID to the Mac).
Jan 12, 2008 | Western Digital My Book Essential Edition...
FireLite FWFL40 - need to upgrade the HD
Hi, Your basically correct, the only requirement is to physically fit the enclosure (2.5inch), other than that, hard disk capacity is a matter of your personal preference/need; Toshiba is one of the better brands. Others are Seagate, Maxtor to name a few. I guess it's a matter of who can provide better after sales support. Hope this be of help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 24, 2007 | FireLite (USBFLB80) Hard Drive
SmartDisk FireLite 40 GB Hard Drive Logo
785 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
