Question about Home
How do I set the timer
Timer Injector 1 Model 2001S6-F1-0C-17
How do i use the diehl m111-8 timer and how to set it
1) Copy following link for Diehl timer manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html#dial
2) Model number given does not match known product.
Google search shows fixya on first page result, implying there is no information on this model number timer.
Add comment and describe timer in detail.
Feb 17, 2013 | Hardware & Accessories
Lost manual for Intermatic DT 17.
1) Copy following link to identify timer and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#DT300
2) Add comment and describe timer in detail
Dec 16, 2012 | Hardware & Accessories
Stanley raintight outdoor 2 outlet timer instructions model # 28468
10-17-12
Copy following link, and scroll down page, to help identify same/similar timer and download outdoor timer manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Or add comment with clear description of timer, saying how it differs from timers shown on link above.
Oct 17, 2012 | Stanley Proto Stanley 31217 Digital...
I have intermatic model ET70115c timer would like programing example so i can program our buildings lights, on, off 7days a week sametime .no holidays.I must be doing something wrong ,need example to...
I recommend calling Intermatic.
http://www.intermatic.com/customer%20service.aspx
815-675-7000
Timer prompts user through the set-up and programming.
The manual does not show exact steps.
Example programming on page 17 of manual does not show how to set timer for 'fixed' 24-hour operation, with specific on-off set times
http://waterheatertimer.org/pdf/Intermatic-et70115c.pdf
Sep 19, 2011 | Intermatic ET70115C Electronic Energy...
Need instructions to set the First Alert TM220 Timer.
For the Model TM-220, 24 hour timer set as follows:
1. Begin with all timer segments on the dial 'pushed up'.
2. Push 'down' the segments required for the 'ON' time;
each segments represents 1 hour.
3. Rotate the dial clockwise until the 'TIME NOW' aligns with the pointer.
Mar 19, 2010 | First Alert 24 Hour Timers - 2 For The...
Phillips Magnavox Model 20MT1331/17: It shuts off
The poster, Jim K, is probably in possession of at least a layout of the power supply and the 'location' is likely derived from a grid used to physically find parts on a board.
220 uF is a common value for an electrolytic capacitor and the 200V is the rated sustained DC voltage it can tolerate.
The 130 volts could be caused by a capacitor that is failing and not smoothing the rectified voltage as it should.
In other words, you kind of need a tech.
Apr 13, 2009 | Philips Magnavox 42MF521D/37 Television
Home Logo
42 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
