Question about Drills
Drill press, 120-IND - Drills
Does any know much about a Rockwell delta drill press model o-2140-a?
Rockwell Manufacturing Co. - Photo Index ...
vintagemachinery.org/mfgindex/detail.aspx?id=698&tab=4
02/24/2015, Jointer, 6" Short Bed Jointer, Model No. on Motor: JB82B710CW · 6" ...12/30/2014, Drill Press, Delta Rockwell Homecraft Drill Press 11-120 · 11" ...
Aug 27, 2015 | Delta Drills
I need a switch for my Milwaukee electric drill listed under UND.LAB.INC.
Go to eReplacementparts.com. Enter the make and model number.
Oct 11, 2014 | Drills
I bought 18v cordless drill with power source 120 but my power source is 220, how can I charge it without causing damage to it.
Some power supplies have a little switch on them for either 220 or 120. See if yours has this. Also some power supplies have a notice that they are good for 120 or 220 volts and either 50 or 60 cycles. If yours is one of them then it will work however if yours is not one of them then it will immediately burn out the power supply as well as your drill.
Good luck
Feb 26, 2014 | Black & Decker Computers & Internet
Can i change the plug socket over from 110v to 240v supply on my HR2470T-1/1
It would not be OSHA approved if in the US in an industrial location.
While not recomended practice, it can be done in the US to run off of 4 wire 240. You are just connecting to one half of the 240 outlet.
If you are in the UK or elsewhere with 240/250 volt mains- do not do this, use a voltage reducing transformer instead..
In the US, the standard is 120 /240 Or put another way- a 240 volt circuit in the home in the US, has 2 120 volt branches that share a common return, the 240 is derived across the 2 "120 sources"- hence your 2 pole breakers on 240 volt branches. If the socket is 3 terminal- which was old code- ground and the return were common at the outlet, it is a matter of just making sure the 240 volt plug terminals the 120 volt drill gets attached to is the ground/return (the one with the nib on it to make it index correctly in the outlet- (should be the wide blade lead or white and one black in the drill goes to either"hot" side of the plug- either one will work, and only one. On a 4 wire outlet, which is new code- the return goes to the white wire of the drill. And the black goes to either one of the hot sides. If drill has conductive case and grounding wire- that should connect to the outlet ground.
Mark on plug which two blades are used, so if you take it somewhere else, you can check (which should be standard operating procedure) with a meter to make sure their outlet is wired correctly.
Feb 11, 2012 | Drills
My new Miller Bobcat has low amperage on 120 volt outlet.
Increase your idle setting on the 1/8" threaded rod protruding to the left of the carburetor until V= 125. Then run your drill. Actuating the drill should call the throttle solenoid to open up to produce more power.
May 12, 2010 | Miller Electric Manufacturing Electric...
Owners manual
you can downlopad one from microsoft but you would need to buy it first. or you can try to ind a free copy of one
Dec 14, 2009 | Microsoft Zune JS8-00001 Digital Media...
Bosch cordless drill PSR 120 12V will not charge up.
About the only indication if the charger is not working is when you put the batteries into the charger and no lights come on. This indicated that the charger is faulty. If the lights come on it is most likely the batteries. The best thing to do is take the batteries and charger to a Bosch service center and they will test them for you. Most will do this for free.
Nov 10, 2009 | Bosch Drills
Power goes off
Your neighbor is connected to your electrical line. Don't you care???
Sep 01, 2009 | Powermatic 1140 B,f 14 " Drill Press...
Drill quit working
what you are missing is a dewalt hammer drill.
Apr 25, 2009 | Rotary Ryobi 1/2" Hammer Drill ZRD551HK
Drills Logo
193 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
