Woorlpool imperial series wtw5550sq wont spin
3 Suggested Answers
farr64
  • 121 Answers
SOURCE: the spin cycle does not always spin clothes dry. how do I tighten belt?
check relays and main fuction switch
Posted on Apr 30, 2009
jsrock516
  • 5911 Answers
SOURCE: Washer full of water wont rinse or spin can hear
First of all, if the model you have this question listed under is correct, this washer does not use a drive belt. It is a direct-drive transmission that uses a motor coupling in place of a drive belt. If the motor coupling were bad, the washer would not agitate at all.
Secondly, the pump on this washer is ALSO used to recirculate the water during the wash cycle. It is not true that it is only used to drain the wash tub. These pumps are driven by the drive motor and only have one moving part - the impeller. If the pump were seized, the drive motor would shear off the drive shaft of the pump.
Check your lid switch.
If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If the switch is not activated by a lid strike, it will activated by a hinge actuator located next to either the left or right lid hinge. You will need to remove the operator console in order to access this type of switch.
If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
A new lid switch (if needed) can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. All these sites offer competitive pricing, so shop all them for the best price.
If the washer still drains, but will not agitate or spin, the problem is your motor coupling. The following link explains how to access and replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The part number is included in the link I provided and only costs about $11 at appliancepartspros.com. These couplers do wear out due to normal wear and tear and need replaced from time to time.
If you have questions, or need additional assistance, please let me know. Please post back with a complete model number (located on a nameplate around the wash tub opening) with your questions, so that I may be able to provide you with better assistance. I hope this is helpful.
NOTE: You do not need to bail or empty the wash tub to complete this repair.
Posted on Sep 07, 2009
On my ifs40 imperial fryer the pilot knob just spins around and wont send gas up to pilot orifice when i push it in
There is a little tab on the knob that is broken. Replace the knob and the fryer will work. One center screw holds the knob on the valve.
Jul 19, 2016 | Imperial IFS40 Deep Fryer
I have a Whirlpool Ultimate Care 2 Imperial Series washer that doesnt spin out very well. It will sometimes spin out but leaves the clothes very damp. Sometimes the washer will try to spin itself out but ...
First thought is that the cycles are off.we have the same problem with ours right now. That slow spin speed concerns me. The motor could be going bad. If this washer is 10-12 years old, you may want to look at replacing it. Does the machine ever start agitating before it finishes filling. If so, the cycle mechanism is going bad. This has a whole host of potential problems. Ave a rep look at it. He can narrow it down quickly.
Feb 06, 2013 | Whirlpool Washing Machines
Whirlpool washing machine imperial series My washing machine is shaking hard when it spin dry
Well if it's a new machine then it look normal or let me know if you note some changes in natural function, most of this series washing machines shakes hard when they are on dry spinning. This series is mostly known for dryer's.
Regards
Nov 06, 2011 | Washing Machines
Washer won't rinse or spin
clean filter and pump
Mar 19, 2010 | Washing Machines
Whirlpool imperial series dryer heats not spinning
This problem is almost always a broken belt. Yes you can do it yourself.
Go to repairclinic. com and put in your model number for the exploded view of your dryer. Locate the belt part number and belt orientation.
Jan 03, 2010 | Whirlpool Dryers
My washing machine won't spin!
as with basic spin faults -a number of reasons usually 1 motor brushes, 2 motor 3 motor control pcb or the obvious one - the belt has come off.
Mar 13, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Replacing spin belt whirlpool clothes washer
There is no belt. This is a direct drive unit. There is a motor coupler located between the motor and the transmission.
Dec 26, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
Top Washing Machines Experts
