Blank screen Screen is black can hear the fan, no display have
  • 32,281 Answers
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Jan 19, 2013
Eddie333
  • 176 Answers
SOURCE: Blank screen on start up on Acer Extensa 4620
If you're hearing the fan, HD and see power lights but still see no display even the BIOS splash screen display then confirm toggle (fn key) to external monitor. No display in either internal or external monitor indicates board level failure.
Posted on Jan 04, 2009
knotbeerdan
  • 413 Answers
SOURCE: laptop shows blank screen
It appears that the display has gone out in the computer. Sorry to say but you have two options.
1. You can take the computer to a computer repair shop and get a new motherboard put in.
2. You can go buy a new computer.
They both will cost about the same but it is more worth it to buy a new computer in my opinion. The reason i say this is originally i was thinkning that the LCD monitor in the laptop may have gone out but if it is not showing anything on an external monitor than the computer is not putting out any display at all.
Posted on Jan 12, 2009
SOURCE: blank screen
from the acer web site
follow this link it will fix this problem -- witht the blank screen
http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=1319&formid=3390&website=AcerPanAm.com&siteid=7117&words=all&keywords=&areaid=2
Posted on Mar 18, 2009
  • 13 Answers
SOURCE: Aspire 1. blank screen when switched on
I recentyl had to have Acer repalce my video card for the same issue. Take side cover off with computer turned off and unplugged. ground yourself and check connections insides expecially the video card.
Posted on Sep 28, 2009
  • 101 Answers
SOURCE: eMachine e627 screen blank
I am assuming you have plugged the screen into a known working power source. You have pressed the 'on' button to turn the screen on and you have hooked up the screen to the back of the computer. What I need to know is if when you power up the computer if you see any text at all from the post AND if you see any lights on the front of the screen itself. (most all screens have lights on the front of them to tell you they are turned on, and most of the time the light is green). If the screen is on but is getting an orange or amber light that means something. Also if you see text or something on the screen initially but not in windows then it could be a resolution or driver issue.
Posted on Jul 07, 2010
My computer comes on just fine, but then while loading the screen goes black. You can hear the computer still working. Sometimes the screen will pop back on but it will be faint and flicker then goes...
Regarding the blank screen, your monitor is most likely faulty - I'm assuming an LCD screen, in which case the backlight is failing, possibly the tubes or the the inverters.
Regarding the fans, you may have pulled the fan leads out of their connectors on the motherboard. Check to see if the CPU fan spins while the computer is switched on.
Jan 03, 2013 | Sony VAIO VGC-JS160J/S 20.1-Inch...
Im a user of Laptop nc6230 for long time , not i found a problem with my laptop. Same time when i switched on the laptop, i can hear everything sound,fan but the screen remain blank. And some time it...
@rashid386
If you turn the computer ON and you can hear that something's running on the background but there's no display , this is a sign that the screen's FL Inverter (this is the chip that controls the backlight of your LCD) or the LCD screen itself is already wearing out and needs to be replaced. If you can see a background image but there's no backlight - you need to have the FL Inverter replaced. If the screen is all black, you may need to have the LCD screen replaced. If you know your way around the computer, you could order screen replacement here and disassembly guide here.
Good luck.
Sep 11, 2011 | HP Compaq nc6230 Notebook
Screen is black or blank. Displays still show but
LCD screen is damaged and replacing the lens is the solution for your camera.
May 24, 2010 | Panasonic Lumix DMC-LZ1 Digital Camera
The screen suddenly went black while connected to an electrical outlet. Nothing works.
Three immediate possibilities in order of expense:
1) Make sure the brightness is on. Press the F2 key.
2) Screen backlight could be blown out, especially if you can hear the disk seeking, fans, etc. even though the screen is black. Connect your Mac to an external display or TV using the appropriate adapters. If you get an image, you need a new backlight or LCD panel.
3) Entire machine is plotz, especially if you hear absolutely no chimes, disk movement, optical reset, fans, etc. This may indicate a power board or logic board issue.
Sep 30, 2009 | Apple PowerBook G4 Mac Notebook
NOKIA N70 Screen problem
it is white screen on display or black?
white screen problem can come from the ASIP filter on the mainboard.
change the ASIP or it usualy called Display IC.
before you change it, try with other LCD.
why the IC Display easy to broken.
cause it placed near the backup bateray.
the bateray producing liquid and the liquid make the IC Display broken
Sep 23, 2009 | Nokia N70 Cellular Phone
My Apple screen stays black!!!!!
If you hear the fan spinning and the screen stays blank chances are very good that the video chip on your logic board has failed. That was a common issue with many Apple laptops of that generation.
Before you give up on it however try resetting the power manager and reseating the RAM. Below is a link to instructions on how to reset the power manager on a powerbook.
http://support.apple.com/kb/HT1431
Aug 31, 2009 | Apple PowerBook G4 Mac Notebook
Blank screen when i turn on my pesario 2500 lap top
Sounds like a bad motherboard. Do you hear anything else happening at all?
Feb 12, 2009 | HP Compaq Business Notebook NX9010
Did you switch displays to the external video? Try hitting the Fn key and whichever function key at the top of the keyboard has a little TV screen icon over it at the same time.
Jan 04, 2009 | Acer Extensa 4620 Notebook
Technically Black Screen
when u power up the system press F8 key untill u get safe mode menu.
then goo to enable vga mode set your resolution to 800*600 or 1024 * 768.
also u can try safe mode or last known good config.
Oct 22, 2008 | IBM ThinkPad T20 2647 Notebook
Dell inspiration 1150 laptop
sounds like screen is blew out try rebooting it with orther screen get back to me lala linda
Apr 25, 2008 | Dell Inspiron 1150 Notebook
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
