Question about Behringer Europort EPA900 Ultra compact 900 Watt Portable PA System
No sound from speakers how to fix the problem
  • 110 Answers
Assuming that you've checked the fuse, and the lights come on...
1) Can you hear any "hiss" from the speakers at all?
2) What have you tried to input into the device? (guitars, keyboards, mics, etc.)
3) Have you reset all buttons to "basic" mode?
Let me know, and we'll go from there...
Posted on Jan 26, 2013
Fishman Loudbox amplifier rattle sound on bass notes
Either the speakers have loosened from the faceplate, or one or more have blown. Open the amp and tighten them down. If that doesn't fix it, remove them a take them to the nearest speaker repair shop for a checkup. If blown either have them re-coned or replace them.
Oct 06, 2016 | Fishman Loudbox 100 Acoustic Guitar...
My speaker sounds like it is blown
take it to a Sound Production company and ask their opinion. If they use Mackie gear-even better. They will better be able to tell you what's goin' on if they hear the speaker. Good luck.
Oct 16, 2013 | Mackie SRM450V2 POWERED SPEAKER
Muffled Sound From Speakers.
Please illuminate me explaining the word "Muffled" means and i will be glad to help you out...
Feb 10, 2013 | JBL *new* Jbl Jrx115 15" 2-way Speaker...
How to fix a Samson XP40iw Speaker PA System
Have you checked the cables? If that doesn't fix it, you probably have a loose connection inside between the "mixer" unit and "amp" unit
Jul 23, 2012 | Samson XP40iw Speaker PA System
One of my Fender Passport 500 speakers has started to crackle sometimes, particularly when the song has a lot of base. What could be causing this? Would a regulator help?
You have probably blown the speaker... swap left and right to verify it is the speaker... These speakers are NOT too well suited for bass... They typically have low impedance speakers in series. You run a risk of popping the amp running with a blown speaker. You MAY have to replace all the speakers in the defective cabinet. ALL the speakers must be identical. The Passport 250 uses four 2 ohm speakers in series... not sure about the 500. It may have two 8 ohm in parallel. Do not use the speaker until it is fixed... the amps are hard to repair if a defective speaker cooks them.
Sep 08, 2011 | Fender Passport Deluxe 500watt Sound...
How can i get more bass out of my frontman 65, it sounds good but it has very bright thin sound. i was wondering if an eminence swamp thang speaker would fix that problem.
Changing the speaker MAY turn out disappointing results. There is a limit what you can get from a 12 inch speaker in the bass range. USUALLY the amp manufacturers match the speaker/cabinet/and amp for about the best performance that can be expected. Want more bass? Step up to a 15 inch speaker.
Nov 01, 2010 | Fender Frontman 65R 65W 1x12 Guitar Combo...
No sound from Yamaha keyboard
The keyboard takes only a specialist to fix the problem. Its also very delicate. The best you can do is to reset it and if the resetting does not work, then you will have to take the keyboard to a repairman to fix it for you.
Firstly, connect a headphone to the keyboard and observe if it will give a good sound. if it gives a good sound, then it means the speaker for your keyboard may have loosed contact or gotten burst.
But if it does not make any sound with the headphone, then it might be a board or sound ic problem. You can also try resetting the resetting the keyboard to default.
Turn off the keyboard, press and hold the last white key and turn the keyboard on while still holding the white key. The keyboard will then restore to its factory default.
If that doesn't solve the problem, you will have to dismantle the keyboard, use a meter to read the panel/board in order to detect the fault and do every necessary replacement. Also, you can do a deep cleaning, by cleaning all the dust in it.
If you can't do any of this, then you will end up taking is to a repairing man to fix the problem for you.
Good luck.
Jul 08, 2010 | Yamaha Full-Size Keyboard
Korg pa-50 no sound from right speaker but has sound from left
Several things to check:
If the speakers are cut off when externaal cables are connected to line outs, possibly the jack sensing switch for the right channel thinks that a plug is in there... you might cycle one in and out to see if that might fix.
Another thing is they LIKELY have a PAN control setting and it might be set full left. The external MP3 would NOT be under PAN control, only the keyboard voices would be affected by it.
Feb 01, 2010 | Music
Yamaha PSR-GX76 musical keyboard problems
Does it have onboard speakers?
If so, try to tighten down (fix firmly in place) the wire mesh that protects the speakers, if it's loose, it will vibrate and cause distortion in the sound.
I once had to repair a portasound which sounded really crappy when a group of keys was struck at high volume, and it would only calm down when i fixed the speaker mesh so that it didn't vibrate with loud sounds.
You may want to put some rubber or similar into the groove where the mesh edge fits in to prevent it from vibrating (i solved mine just by tightening up the mesh strips where they protrude into the housing).
If this doesn't help, then it's something else (possibly a bad or dirty connector contact or a bad solder contact).
regards
3rq8 (Triarcuate)
Jul 30, 2009 | Music
Behringer Europort EPA900 Ultra compact 900 Watt Portable PA System Logo
118 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
