Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Belking g plus mimo 928995 NAT open help
I need to open my NAT for that router and i dont know how to do it please someone help i need it for xbox live i got the wireless adapter for my xbox live
  • tom giles Jan 27, 2009
    i have an xbox too i need opening the nat hellp please
When you solve the issue you have can I borrow a guru to help upgrade from my 2wire modem to my Linksys wireless Router?
Posted on Jan 26, 2009
Problem with NAT type for xbox live? I have a Belkin wireless G Plus Mimo router and i have strict Nat type when geting on XBL. Any way to make this open?
yup....you can login to the router setup page by typing 192.168.23.1 in internet explorer...
on the left side you will find an option called firewall....click on that..it ll prompt for the password..(password: leave ot blank and click submit)
go ahead and disable it...
also click on DMZ on the left side of router setup page and enable it for the IP address assigned to the XBOX...
also get into virtual servers on left side and open common gaming ports like,
port 80
port 88
port 3074
port 53
port 443
for both tcp and udp....
in addition to that you need to open ports suggested by XBOX vendor...
thats it, you are done with that....as you open ports for xbox in virtual servers
the particular ports for xbox gets bypassed from NAT...so you need not worry about NAT hereafter...
also make sure that the modem provided by the ISP is not NAT enabled...if so ask the ISP to Bridge the
modem,so that you would not face further issues with XBOX....
Apr 02, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
NAT on xbox live is moderate! i need it to be open, for best results. What do i need to do?
You are trying to open the NAT on the router for X-box.
For this you will need to reduce the MTU settings on the router to 1365.
You will also need to trigger some ports on the router.
For this you will need to open the router set up page.
Router set up page is the page where you can change the settings of the router
Click Here to know more about router and network
Jan 28, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Change NAT to open
maybe instead of nat, set you xbox as a DMZ host. This would be done on the router itself. It will allow the Xbox to bypass the firewall and nat on the router/gateway, and at the same time keep your computer safe.
Apr 16, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin g plus mimo nat problem
Step 1 : Check the IP Addressof the Xbox And take a note of it
Step 2 : Open RSP By typing 192.168.2.1 on the Address bar of the internet explorer
Step 3 : On the left side Click Firewall
Step 4 : Leave the Password blank and click Submit
Step 5 : Disable it And Apply Changes
Step 6 : On the left side Under Firewall Click DMZ
Step 7 : Add the IP Address of the XboX in DMZ
Step 8 : Click Apply Changes
Step 9 : Restart the Router
Step 10 : Test the Connection
Apr 12, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
We've just moved house and have aquired to belking routers a belkin wireless pre n and a belkin ADSL G Plus MIMO I want to use the latter as a bridge how can I?
You need to access the setup page of your Belking router and go to the wireless setup, look fro Use as Access Point, now just a reminder this will defeat the NAT IP sharing feature of the router. Configure the IP address of the router to the same subnet as the network your tying to bridge here's the more detailed procedure:
1. Enable the AP mode by selecting "Enable" in the Use Access Point only page. When you select this option you can now change the IP Settings.
2. Set your IP settings to match your network. Click "Apply Changes"
3. Connect a cable from the LAN port of the router to your existing network.
Sep 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I need to open the nat on my router for xbox live and dont know how
go into the router settings and look for uPnP and enable this it will then open the firewall for your xbox automatically
Sep 09, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I need to know how to get into my belkin wireless router so i can open my nat on xbox live
Open up a browser window and in the address bar type 10.0.0.2
That will get you into the control page for your router and you can then access all of the settings.
Jul 10, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How to change my NAT
You need to check first if your router is Xbox Live compatible (all routers will work, but only certain ones will allow an open NAT):
http://www.xbox.com/en-us/support/connecttolive/xbox360/homenetworking/equipment.htm
If your router IS on the list, make sure you have a compatible firmware version (usually the firmware version is written on the router somewhere). If you do not have the proper firmware, you will need to downgrade your firmware (reply to me for instructions on this).
If your router is not on the list, you're outta luck.
May 21, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My Belkin Software!
Try the Belkin WEB site or Google the driver
May 10, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Nat settings
try going to http://192.168.1.1 default user name and password is admin for both. go to your wireless security and set up security as xbox allows. i think i set mine up with wpa and all i had to do was put the code into the xbox settings after the router page generated an encrypted key sequence.
Nov 13, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
584 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
