Question about Lexmark Wheelwriter 3000 Typewriter
Keys not hitting the ribbon. nothing printing
2 Suggested Answers
  • 3594 Answers
SOURCE: Typewriter not printing
There is a plastic cap on the end of the print solenoid plunger that nis probably broken the part is available about 10.00 but a little tricky to replace.
dickto
Posted on Dec 13, 2007
Typewriter beeps incessantly, does not respond to input
First try a little WD40 on the shaft thatb the carrier slides on and look for debris in the carrier movement area,
DickyO
Nov 13, 2013 | Swintec 7000 Typewriter
When power is turned on the machine acts like it is supposed to. The carrier repositions itself and the motor is heard running. However, when I type, the carriage (with the disk) moves to the right with...
its a printer right?
and it dot matrix type right?
if yes. try this
check flexible cable from main PCB to print head. if its torn. maybe the initial sensor is ok but not the data line.
replace flexible cable.
Mar 04, 2011 | Computers & Internet
Ribbon strike mechanism won't move and strike ribbon when key is hit
You most likely have a broken plastic print solenoid cap.
We sell them for 20.00 with instructions and shipping.
DickyO
Cleveland Business Machines
216-241-0027
Sep 16, 2010 | IBM Wheelwriter 6 Typewriter
Hi can you help ? My zebra TLP 2824 printer keeps printing out of alignment. I reset the printer by holding the feed button while powering on but instead of printing dump info the label moves for a while...
If you are using a ribbon remove it and perform a calibration, hold down feed key for 2 seconds as you power on, release key and wait for it to complete its calibration, when it has stopped shifting labels (wait for 10 secs to be sure) HIT THE FEED KEY to exit dump mode. If it has successfully calibrated it will feed a label each time you hit feed key. Re-install ribbon, make sure ribbon is pushed formly onto drive sprockets and then re-run the calibration..
If this does not fix problem. download firmware to latest version. This will automatically reset printer to factory default condition.
Nov 12, 2009 | Zebra TLP 2824 Printer
Hi, my printer is printing blanks. Windows XP, Zebra ribbon I replaced the ribbon and still no luck. I tried setting the darkness to maximum, but that didn't work either. I tried the "dump"...
The zebra ribbon has ink on one side and the other side has a backcoating which protects the printhead. simple way to check is to peel off a label and momentarily stick to ribbon and remove. This will show you which side is inked.
If ribbon is installed correctly then reset the printer and re-calibrate it. 1. install labels and ribbon 2. power on printer. If you have a solid green light on then 3 turn printer off. 4 hold down feed key 5 power printer on and after 2 seconds release feed key. printer will perform a calibration routine and eventually print out status page. IMPORTANT 6 Hit Feed Key once more. Printer will display Out Of Dump message. Your printer has now been sucessfully calibrated.
May 06, 2009 | Zebra LP 2844 Thermal Printer
No Characters Typing
could be the ribbon is not lifting, do you see an image on the ribbon, also may be twisted inside the cartridge the shiny side has to be facing the keyboard.
Jul 09, 2008 | Brother EM-630 Typewriter
dickto
Nov 27, 2007 | Lexmark Wheelwriter 6 Series II Typewriter
KEY STRIKING PRESSURE
Try taking the ribbon out and looking at it see if there is one spot for each character on the ribbon or if they are overlapping.If they are over lapping then either you have a problem with the ribbon drive assembly on the machine or it is set for a multi-strike ribbon.
Nov 13, 2007 | Lexmark Wheelwriter 15 Series II...
Replacing typewriter ribbon
Linda, Depending on what make and model you have it could be several things. The newer TW's use a print wheel which has to home itself each time the power is turned on. This tells the print motor how far to turn for the correct letter. Make sure there is no debris and everything is seated properly... platen, print wheel, etc. Once again, this depends a lot on what kind of TW you have. MM85
Sep 04, 2007 | Office Equipment & Supplies
Print head and ribbon do not in sync
sounds like the ribbon carriage is out of position, try holding the shift, and code keys, then power up, if thats no help the hold frame might have to be resitted.
May 01, 2007 | Brother SX-4000 Typewriter
Lexmark Wheelwriter 3000 Typewriter Logo
29 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
