Question about Amana Refrigerators
Amana Bx22s5W freezes food in the crispers
Any vegetables or food in the two bottom crispers, or in the cold cut drawer, will freeze. Also have had soda freeze on the lower shelf. Refrigerator is about 12 years old. This has been happening for a while. Have seen answers about thermostat and other answer about the vent in the back left that draws air to freezer...went on to say that there is no fix. Help please.
  • salomonas Mar 20, 2009
    Vegetables freeze in lower left crisper drawer. Takes about 2 days depending upon the amount of vegetables stored in drawer. Vent damper is operational and has been tried in all states. Eggs also freeze at the back of the refrigerator above same drawer. Separation of items makes some difference indication that the refrigerator has an air flow problem.
I've had the same issue with an Amana BX21TL. In my case, the problem was that the various air flow adjustments were all directing the cold air to the bottom of the fridge, underneath the vegetable crispers.
What I've done to fix this was:
1- Made sure there was a tight seal between the vent opening at the back of the fridge (at about mid-height) and the rubber/plastic duct that directs air to the meat/cheese drawer.
2- Made sure that the adjustable opening at the back of the meat/cheese drawer was fully open.
3- Made sure that the adjustable opening at the back of both vegetable crispers were fully open.
Hope this helps.
Posted on Aug 10, 2009
Our amana side by side works well, in fact too well. It freezes salad greens in the vegetable drawers and now freezes things like yogurt on the open lower shelves too. We've turned dow the settings to...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Apr 07, 2011 | Amana SXD524VW Side by Side Refrigerator
Vegetables freezing in crisper drawer
This is an issue with the convection system in the refrigerator, while the cold air trapped withing the crisper drawer remains and the temperature of the moisture in the area drops below the freezing point, the water content acts as a cover and thereafter enables the vegetables to freeze. A slight rearrangement of the utensils within the refrigerator solved the problem
Jan 21, 2011 | GE GSS22SGM Side by Side Refrigerator
Vegetable draw overcooling vegetables are almost to the freezing point
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 13, 2011 | Amana ABB1927DE Bottom Freezer...
Fridge is freezing food
Make sure nothing fell below your crisper, deli drawer section. There are some air return vents below them and if they get partially obstructed would allow cold air to pool in the bottom of the fridge.
Make sure your freezer control did not get turned up too high.
Also you may want to check with the manufacturer as they did have some issues with some of the bottom mount models exhibiting this problem and they developed a repair kit for them.
Jun 11, 2010 | Amana ABB1927DE Bottom Freezer...
Freezing in the bottom draw of my LG Refrigerator
YES!!!!!!
Remove the bottom drawer.
In the back you will see a small dime sized hole.
The hole allows cold air to circulate around the crisper.
Plug the hole with tape or anything that will fit the hole.
Set temps back to say 36 in the ref. and 0 for the freezer.
This should help.
Jan 09, 2010 | LG Refrigerators
Salad in drawer is freezing
Good day,
One user claims that the return air vents or vent located at the bottom rear of the fresh food compartment, have collected enough junk to block the cold air from returning to the freezer compartment. You can clean them out but I cannot verify that solution.
The crispers are located in the coldest part of the fresh food compartment.
This problem can occur when the machine gets light usage especially in colder weather, when the machine running time drops and the air in the fresh food stratifies, causing to cold air to pool in the bottom.
Normal may no longer be normal. Controls by their design will tend to run colder as they age. You might try tweaking the control warmer.
Patience and time are the most important tool you have to work with in dealing with this issue.
Dec 04, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Vegetable and fruit crisper drawers freezing foods
You have a defective thermistor and damper control in the fresh food or a bad control board.
Check the thermistor first.
Also, adjust the return air damper at the bottom left side of the fresh food sction to warmer.
Feb 21, 2009 | GE PSS25SGN Side by Side Refrigerator
Bottom vegetable/fruit drawer freezing fruit
to the left of the bottom drawer is a veg/meat slide switch.make sure it is all the way on veg.if it is on meat,it opens a small doorway to the freezer and lets the cold air in and will freeze the food in the bottom drawer.in some cases,you will need to remove the drawer and shelf and then take apart the doorway.ball up some putty and jam it it the hole to completely seal it off
Jan 11, 2008 | Amana ARS2661BS Side by Side Refrigerator
Refrigerators Logo
2,044 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
