Question about Proview PA-32JK1A 32 in. LCD Television
Won't show cable channels
I have a new proview flatscreen that will only view basic channels 2-13; no cable???
  • jesstaylor16 Jan 25, 2009
    Trap,
    Your the man, thank you so much. It is previewing the channels now!!
    Problem Solver:
  • 13 Answers
Try to find a spot in the setup menu that says Antenna in there you may find the spot that says cable etc
Hope this helps
Trap
Posted on Jan 25, 2009
When i power up my 47 inch flatscreen the power comes on for a second with the picture than shuts off
With most televisions there are two options why you won't get any image on your screen:
1) You are using cable and haven't chosen a channel yet, try using the power button, and immediatly chose a number of which you know is a chanel.
2) You are using a DVDplayer, Digital television, ... and your tv is still connected to the cable or another input. Look for a button on your remote that is shaped like a square with an arrow pointing in it from the side, hit this button to swap between input channels to find the right input.
Aug 22, 2012 | Televison & Video
I just bought an RCA flatscreen and brought it home and hooked it up. I don't have a cable box for this tv, but I do have a cable cord that I plugged in. Anyway, I don't get most channels. I get...
Some cable companies use the 'tier' pricing with their "Packages".
Here in Tallahassee it goes something like this..............................
1) Basement 'Basic" pkg. No converter.>>>>>>>>>>Lineup>>>>>>>>>>>>>>>>>>> CH 1-9
2) Basic w/converter.>>>>>>>>>>>>>>>>>>It varies, but there are a lot more than 9!
3) Basic w/Digital converter>>>>>>>>>>>>>> more channels,and PPV
4) Premium pkg>>>>>>>>>>>>>>>>>>>>>>HBO,Sports etc.
Go to the menu on the TV, run auto channel search, and check the type of signal assigned, i.e. Antenna or cable.
Good Luck!
Sep 02, 2011 | RCA Televison & Video
I have timewarner basic cable and would like to view the hd channels such as 5.1 or 5-1. how to I get there, the remote has no . or -?
go to the options with the remote on your tv, then do a channel scan. it will scan for any channels you are picking up. if you have basic cable you will only have a few HD channels. if you have a cable box then the cable box should show you what channels are HD
Dec 11, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I got a 32in. Proview from a friend and they lost the book on it. I need to know how to program the t.v. to display my cable. Everything is hooked up but it won't show anything but a blue screen. But the...
Check-out the Proview website www.Proview.net
go to tech support and e-mail a lady by the name of Kamisha Fernandez. She will email to you the user manual. She did for me and it was a great help. But what I need is the electronics schematics to the RX326 if anyone can help out on this matter.
Jun 14, 2009 | Proview PA-32JK1A 32 in. LCD Television
My monitor does not work right. it says vga not support.. its a proview 17" flatscreen..active matrix tft lcd
I suspect your Computers Display settings need adjustments and or a Driver from Proview installed...therefor if you can get on the net, I would look at FAQ's on Proviews Website, i.e:
http://www.proview.net/Support/FAQ_Question.aspx?pi=2026
hope that helps,
Bastian
Jun 02, 2009 | Proview PL713S 17" Flat Panel LCD Monitor
I have a Proview TV that we just bought from Rent A Center and when we connect our cable to the TV it tells us to scan the channels. We did this and still we get a blank blue screen that says No Signal....
Try this as your model is basically the same as mine.
Push Menu on your remote.
Then a small screen comes up.
Using your left right arrows move left to set up.
Scroll down to tuner mode and again using left right arrows, there are 4 setting you can choose. Once the setting you choose is showing then scroll up to Channel Searching and hit OK on your remote. This will scan all the channels Digital and Analog.
Depending on which of the 4 setting you picked on TUNER MODE you may have to do this again in the next mode to see which will get the most channels on your TV.
I hope this is helpful; Ken, Attica, NY
Nov 27, 2008 | Proview PA-32JK1A 32 in. LCD Television
Proview 3200 Flatscreen with HDMI Problem
Maybe the input on the tv needs to be adjusted to work with the cable tv for example in the tv menu where you can adjust the sources for the inputs maybe it is set to something like RGB instead of HDMI. If you have a user manual consult it on how to change the input devices. Good luck.
Sep 17, 2008 | Proview HX303 30 in. HD-Ready LCD...
Proview 3200 HD TV
as you are using the ch3 , have you previously scanned and locked in all the channels for cable,
Apr 25, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
PROVIEW 19" LCD TV - FLATSCREEN - KV SERIES
I have same problem, im goin to try this fix i found on youtube.. different tv but same problem
http://www.youtube.com/watch?v=_0175VbmV9M&feature=channel
Jan 08, 2008 | Proview HV-207 20 in. HD-Ready LCD...
Proview PA-32JK1A 32 in. LCD Television Logo
117 people viewed this question
Top Proview Televison & Video Experts
Steven Wander
Steven Wander
Tony
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
