The Innovage site is a bit confusing to me. I just purchased the above phone but the instructions had been removed.Where do I go and how do I download the instruction manual? The model id number is 1604007.
Hi Everybody,
I would like to thank
wiccan8house
for the manual scan. I revised it a little and created a pdf file out of it. Check it out.
http://mdcnursing.com/Documents/Innovage_phone_1604007.pdf
1/ ensure that it is NOT in hands-free mode. You can check by seeing that a year is at the bottom of the LCD screen. eg 2004 2/ Press the DELETE key to show the LCD in normal view 3/ Press the Set / Save key to enter the setting mode. 4/ Use the updown key to choose what you want to set - eg date or LCD brightness etc. 5/ When you find the function you want - press the set-save key again - and enter the date (or whatever) using the up and down keys. Note: the up / down keys will alter whater field is blinking. To tab onto the next field, press the set/save key again. 6/ Press delete when done to return to normal screen. The rest is fairly self-explanatory - except the Auto IP functions. All the manual says is: "not applicable in the USA market".
I hope this helps everyone. I have scanned the manual that comes with the phone and uploaded to rapidshare, here is the link.
http://rapidshare.com/files/98135606/Phone_Manual.zip.html
hope this helps--wicc--
I'm not sure how it happened, but solution #4 was posted before I uploaded that manual. The date shows it was posted 2 months before mine, so ignore that it says "its a junk". The file I uploaded is not a junk file. I am more than happy to mirror it from a different file share if anyone has problems with rapidshare.
Thanks for trying but this was useless. Pressing delete key does nothing, zip, nada whether the handset is in the cradle or in your hands (off hook).
phone doesn't ring, nor does the talking device
Need manual for LCD touch-panel phone ID 1604007
I have the same phone and also no manual? What gives with this company? Does someone have a pdf file for a manual anywhere? Even a word file would do.
Thanks
Bought 2 of these and neither has a manual. Help! need a manual. How do I set this thing??????
Arborgreen
[email protected]
where can i find the user manual?
i also need to download the manual for this phone
no manual for talking caller ID LCD touch-panel phone, where do I get this?
I HAVE THIS PHONE AND THE PHONE DOES NOT RING OR TALK WITH THE NUMBER WHEN A PERSON CALLING HELP WITH THIS
The only time the LCD panel displays any information is when the handset is off the hook and then nothing works as described in the operations manual insofar as setting the phone up for the first time is concerned. If the handset is off the hook the LCD shows the calendar and etc but it goes awy when hung up.
There are no instructions with the phone. I can't get out of the 24 hour mode, among other features I'd like to use.
how do i get my phone to lay flat
I talked to someone the other day about getting a manual for model 1604007 they said they would e-mail me one, but i have not received it yet, can you help me. thank you.
innovage 1604007
