Question about Nintendo Wii Console
Display on screen is stretched Vertically
Both Wii and TV set to 16:9. Bottons on top and bottom of screen are cut off making it hard to see instructions or correct buttons. This is on every screen from setup to games.
    Problem Solver:
  • 6 Answers
There should be an option for the TV that will adjust the display mode on the tv,
Posted on Jan 25, 2009
I aquired a used Wii. When I hooked it up it worked great. Now, all of a sudden, the top and bottom of the screen are cut off. I did not change any settings on the console or TV and can't figure out how...
You might want to try and gently clean the video plugin on the back of the Wii and the cord. It could be a dirty connection not allowing the entire video signal to come through. if not, try a different cord
Aug 11, 2013 | Nintendo Wii Console
I accidentally set my wii to HDTV settings and I need to reset it back to normal tv but my screen is so messed up I cant see options or anything
You can reset your Nintendo Wii video settings to use Composite (or RCA - Yellow, Red and White) cables by doing the following:
1. Make sure the Nintendo Wii is powered off and a red light is showing.
2. With the power off, unplug the video cables from the back of the Nintendo Wii, leave them plugged into your TV (these should be the RCA/Composite cables)
3. Press the Power button on the front of Nintendo Wii. Make sure the cables are still unplugged.
4. Keep the Nintendo Wii powered on and plug your cables back into it with it still running.
5. If all went well, the picture should appear normally now.
6. Once the picture has reappeared, you should go into the Nintendo Wii Menu (the Wii button in the bottom left hand corner) and change the display back to 480i to make the changes permanent.
May 01, 2011 | Nintendo Wii Console
My Wii is connected to a widescreen tv. All the settings are correct according to the manual, but the top and bottom of the picture is off the screen. The sides are ok. Just the top and bottom don't...
Hi.
This is probably seting on the TV that needs to be adjusted. Go into the picture settings on the TV and change the viewing settings to a setting that you're comfortable with. For example change the settings from 16.9 to 4.3 or change zoom.
You will no doubt find the correct setting in the TV's picture menu.
Regards.
Jan 25, 2011 | Nintendo Wii Console
The wii display on the LCD widescreen is cutting off the top and bottom a little(enlarging the pic vertically). As if the picture is too big vertically. I'm using the 3 plug av cable that came with the...
hi, if you switch the wii on without a game in and then you get that start screen where you can choose the squares, well in the bottom left hand corner it will say wii, click on this then enter the settings and you should be able to adjust everything you need from their.
i hope this is some help to you, if you still have problems after then give me a shout back and ill do my best to assist you further
Dec 07, 2010 | Nintendo Wii Console
Screen set up will not change
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
raterakash12
Jan 07, 2010 | Nintendo Wii Console
Big and Stretched picture
It is most likely that somehow the aspect ratio of your display has been changed. If you go into the wii system menu by pressing the wii button on the wii channels screen, then go into the display settings and alter them as the guide shows here:
http://www.nintendo.com/consumer/systems/wii/en_na/settingsScreen.jsp
Jan 01, 2010 | Nintendo Wii Console
Screen Alignment
switch it to widescreen instead of standerd its in the screen settings
Apr 05, 2009 | Nintendo Wii Console
Wii console...cursor doesnt appear on the screen but everything is sychronised and buttons on remotes work?
In the Wii settings make sure that the sensor bar setting is correct wheather it is top or bottom of tv. Then make sure the sensor bar is as far font as you can get it to give clear line of sight to the controller.
Apr 28, 2008 | Video Game Consoles & Games
Nintendo Wii Console Logo
483 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Troy Gorman
Troy Gorman
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
