Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Cannot turn television off
Dear Fixya, Lots of trouble all at once. Thought HD cable box was bad-turned out to be trouble outside at junction box. My Dennon Home Theatre unit went bad-needs repair. By passed all equipment and went directly from source to cable box to t.v.-worked fine for about 20 minutes then picture froze up (in black and white), then screen went completely blank. Presently, with the room darkened, I can see very light, blue screen on and hear a slight "buzzing" sound from the tv. Pushing the "On-Off" button on the set will not turn it off. Have held it down for up to 20 seconds and still will not go off. Same with remote. Really need some help to see what is problem with tv before I start repairs on the Dennon. Thanks for listening, and, (I hope), the help!
You need at new DMD board
Posted on Jul 15, 2007
SOURCE:
12 inch black square in center of the viewing screen when I turn tv on or switch stations
The black square is a text box for the deaf. You can turn it on and off with the closed captioning button on your remote or from the closed captioning section in your television's menu.
However if you are connecting a cable box or satellite tv receiver you would need to turn the text box off from its menu. There is often a hidden menu that needs to be accessed on the cable boxes and satellite tv receivers that can be reached by turning it off and then immediately pressing the menu button on the outside of it. For more details about a specific cable box or satellite tv receiver call your cable or satellite company.
Apr 04, 2011 | Insignia NS-L19Q-10A 19 in. HD-Ready LCD...
I have a circuit breaker that controls a light switch and all the outlets in one bedroom and controls half the outlets and a light switch in another bedroom. None of which work now. I have replaced the...
One single cable runs from the circuit breaker to a junction box in that area of the house.
The cable has a black Hot wire, white Neutral wire, and bare ground wire.
Once the cable arrives at junction box, it can split up 2 or 3 directions.
Each successive box receives a cable that feeds back to the first junction box.
Chances are the junction box is on the ceiling. And it will be the ceiling box that is closest to main breaker box.
Junction box can also be a switch box. In that case it will be switch box closest to main box.
Find the junction box, as point of organization.
Open junction box and separate all black and white wires.
Turn power on and see if breaker sets.
That will tell you if problem is between main box and junction box.
Junction box wires are separated.
Tape tester leads to wood sticks to keep hands away from power.
Turn power ON and test each wire in junction box to bare ground wire.
Tester will light up on Hot wire.
Test Hot to each other wire in box, except bare ground, and tester lights up on Neutral
This identifies the cable that comes from breaker box.
Now, reconnect cable from breaker box to one of the other sets of black and white wires located in junction box.
Check if breaker resets.
If breaker resets, see what circuits are working, and you can eliminate them as suspect.
Remember each successive box in a circuit has 1 cable that connects back to main breaker box
Going 1 box at a time, and disconnecting black and white wires, will eventually lead to the suspect.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 05, 2011 | Electrical Supplies
No picture out of hdmi for ky hd
The first thing I would like you to check is the back of the HD box. There is a port that look similar to the HDMI port but its called SATA.
Just Double check that it is in the HDMI.
Once that we have established that the HDMI cable is correctly fitter both to the TV and the HD box. what I would like you to do is turn both box and Tv off. with them still connect to each other. Now what I would like you to do is turn your tv on first. Select the HDMI input you are going to be using. Then turn the power onto the box.
Hope this sort your problem out
Little Dish Fitter
Sep 06, 2009 | Toshiba 37WLT58 37 in. LCD TV
Can't get it to work with cable box.
You might try to make sure that your firend is using HDMI cable and his unit with his box and/or TV with an AUX setting.
Just thought this might be how his is operating. We hope the suggestion is helpful. Thanks for contacting FixYa.com
Sep 03, 2009 | Plantronics Clarity C120 Wirelesstv...
Cannot optimize picture width on new flat screen HD
On your cable box remote press the hd zoom button. I have comcast cable box and it worked for me.
Dec 25, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Connecting Cat5e cable to BT 78A junction box
You can get this device to help you.
http://www.run-it-direct.co.uk/run-IT-direct%20Price%20List.pdf
I believe it is on the 8th page.
Oct 08, 2008 | Computers & Internet
HD reception
To have HD on cable, you will need an HD cable box with the HD service activated by the cable company. Some cable carriers will provide some basic HD services included in the base cost with the box.
From the HD cable box to the TV, you will need an HDMI cable between the cable box and the TV set. This is an HDTV interconnect wire. You will have to refer to the instructions on the cable box and on the TV to get everything going properly.
Jerry G.
Apr 28, 2008 | Sanyo DP26746 26 in. LCD Television
Digital TV
It is HD ready, which means to get HD you will need to connect a HDMI cable to a HDMI source such as a SKY HD / VIRGIN HD SET TOP BOX or a HD DVD player to take advantage of HD.
Jan 22, 2008 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
AKAI 55" Rear Projection TV won't turn on.
the 3d effect tells me that your convergence ic's have blowned. standard for these sets.. not to much of a difficult repair. repair them all the time..
Dec 13, 2007 | Akai PT5598HD 55" Rear Projection...
The picture has a double image.
All conections to the set need to be check very carefully starting form the cable to comes into the cable box from the outside and the cable that goes from the box to the tv,eliminate the cable box and conect the wire from outside direct in the tv and and see how it looks bring a small portable and conect the cable to it to see how it looks,once all the possibilities have eliminated then consider a problem inside the tv in the tuner area starting at the very conector where the cable conects.All this can help if the double image is not related to misaligned convergence.
Oct 01, 2006 | Hitachi 50V500 50 in. HD-Ready LCD...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
62 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
