Question about Husky Heavy-duty Led Flashlight
Husky flashlight led bulb replacement - Husky Heavy-duty Led Flashlight
Dewalt LED light flickers
then you have done everything you could do,,,,,,,did you clean or replace the switch??
Jul 16, 2015 | Dewalt DCL040 20V Max Led Flashlight
Tip
Maglites
Id shelve a Maglite and get a Pelican, Xenon, or LED. They are much better lights. Husky makes a great LED light too and low-priced.
on Jan 12, 2009 | Pelikan Pelican 8040 M10 Flashlight
Snap On Flashlight Bulb Replacement
The Lens is adjustable, you unscrew the top, then pull the Cap, Insert the Bulb (make sure the 2 wires are not twisted) and go straight into the holes. The Replacement Bulb is located down at the Battery Access.
Mar 01, 2014 | Snap Appliances Snap-On 3 D-Cell LED...
Bulb replacement maglite mini
you have to take the top apart, bulb just pushes in once you get to it. make sure you clean it with rubbing alcohol after replacing
Dec 29, 2013 | Rayovac Highbeam Flashlight 1 Watt Luxeon...
Where can i find some good led bulbs? what about the web b2cled.com?
I didn't use the web b2cled.com previous. But I bought a led lamp from depotoffice.com and aurabuy.com. Both of them are good for us to choose a led flashlight. Especially the aurabuy, the price is affordable and the quality is warranty.
http://www.aurabuy.com/flashlights-lights-lasers/headlamps.html
Apr 06, 2013 | Led Lenser/Coast/Zweibruder Camping,...
Need a replacement bulb for a Redline Nebo flashlight
Hi, replacement bulbs can be found at amazon, click here and take a look: Amazon com flashlight replacement bulb. Cheers
Nov 02, 2012 | Nebo Redline Tactical Flashlight Strobe...
How do you replace the LED bulb in a AA cell maglight flashlight
question is in TV section--answer would be contact Maglight to see if the part is even available and if not buy another flashlight.
May 04, 2012 | Televison & Video
I have an Xacta Mirage light, I believe it is LED. The bulb seems to be brned out and I cannot find any information regarding replacement bulbs. Can you help?
I cannot find any info either, so lets "figure" it out. Does the "bulb" look like an interchangable (replace-able) bulb - LED's "almost" never need replacing (for the most part) and manufacturers always solder them in. I'll assume that you cannot twist (or un-screw) the bulb.
Now what to do...if you really like this flashlight - you could open it up, un-solder (or cut leads) the LED and put a new one in. The LED to use is:
- one that can handle the voltage - measure voltage (with volt meter) at the burned LED with flashlight on (keep track of polarity, which wire is negative/positive for the new LED),
- you will check for a flat (fish eye magnifier) top surface or round top,
- check for size (diameter) of the LED.
Now match that up to an LED at www.digikey.com They will have higher prices but, you are only buying 1 LED and they have the biggest selection to better match you old LED.
There are lots of new flashlights out there and getting a new one may be a good option.
Jul 12, 2011 | Camping, Backpacking & Hiking
Husky Heavy-duty Led Flashlight Logo
153 people viewed this question
Top Husky Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Husky Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
