Question about Samsung SPN4235 42 in. Plasma HDTV
Blue flickering on plasma screen
My plasma tv will occasionall get blue flickering at the top and in the one of the corners. Always in the same locations.
  • Anonymous Jan 27, 2009
    same blue on the screen
  • 98 Answers
Need to adjust some voltage on the Power Board & Y- Main Board.
Posted on Feb 06, 2009
Flickers after 5min of use. Perfect sound, turns on fine and excellent picture quality when in blue screen menu mode. Why?
This intermittent problem is very difficult to rectify. Just contact the authorised service center for Hitachi at your town. The work is really a skilled one, that a user cannot do it with ease.
Jul 13, 2012 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Vizio start blue/yellow flickering screen
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 01, 2017 | Vizio VW42LF 42 in. LCD HDTV
My 50" plasma t.v. has a blue strip top to bottom that is always on the screen, what is the defect?
A solid blue line would imply that the lower buffer PCB has a loose connector or a bad buffer. Some plasma TV have these buffer ICs build right into the ribbon connector of the panel. At any rate, if you plan to have the TV repaired, STOP USING IT. Plasma panels are notorious for burn-in when viewing stationary images (station logos, video games, etc.). The blue line IS stationary and if you keep watching it, you will see the effects even after you correct the original problem.
Mar 15, 2010 | Samsung Televison & Video
Blue dots on my lcdtv
Sometimes the voltage can be set to high by the factory. Throughout time, blue dots will appear. You will have to remove the back cover off the tv, find the "voltage Screws (they are labeled) and turn down (left) JUST A Notch. Have seen this done many times.
Pray that the panel isn't blown out or bad projector tubes. They are expensive.
Blue dots and screen flicker are VERY common on the newer LCD and Plasmas
Also, if you have a pixel setting on your TV (not sure if that one has it) Try setting it to
480p.
Jan 17, 2009 | Hitachi 50HDX60 50 in. Plasma Television
Blue glow
Pls report it to Samsung for remedy in warranty. Try to contact here.
Aug 10, 2008 | Samsung PS42P2S 42 in. Plasma Television
Blue haze on my plasma screen
I had the same problem, I had to send it back to Philips to get a $900 part replaced. Thankfully I had the warranty with it.
Aug 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
Blue screen
Are you using component video cables? If so, check that these aren't loose on either end. Next I'd consider that whatever video cable/input might be bad, and switch cable or cable type... i.e. switch from component to HDMI or vice-versa. Then change up the source (cable box versus DVD player). If you're still seeing blue at this point, the TV internals are the bad.
Jul 23, 2008 | Panasonic TH-50PX75U Plasma HDTV
42" philips plasma flat panel television
same problem anyone know what his is please send me an email. real unhappy!!! this tv cost me $900!!!!! rami7344@bellsouth.net
Oct 22, 2007 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Samsung SPN4235 42 in. Plasma HDTV Logo
212 people viewed this question
Henry  Thomas
Henry Thomas
