Question about Sylvania DVR90DEA DVD Recorder/Player
Will not pickup recordable disk - Sylvania DVR90DEA DVD Recorder/Player
All the dvds I insert are reading disk error.
Sounds like it is time for a new unit. your problem is not worth fixing as it is either a failing laser pickup due to age, or the laser beam is caked with tar from smoking.
New blurays are quite inexpensive.
Please dispose of the unit responsibly.
May 09, 2014 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Panasonic DMR-EZ48V won't read disk
Either a dirty or a bad optical pickup in the DVD unit--one or the other.
May 25, 2012 | Panasonic DMR-EZ47V DVD Recorder/VCR
LG RH265 does not read DVDs
Purchase a DVD cleaning kit and follow the instructions, this will remove any dirt from the laser pickup lens, and hopefully get it up and running. If this fails, the only other option is have the whole laser assembly replaced, "expensive" or replace the entire unit.
Mar 06, 2012 | LG RH1999H DVD Recorder/HDD Recorder
My son's camera won't read any disk. It just says "no disk". What might be the cause?
The problem is the Laser lens. The lens is dirty or defectives, and cannot focus anymore on the laser beam reflected by the DVD, to read or record the disk.
You can try using a DVD cleaner disk to clean lens. If that does not work, then the lens pickup must be replaced by a technician.
Trying to clean the lens with a Qtip and isopropyl alcohol may also help, but it may also damage the lens furtherly. If cleaner disk does not work, better calling support.
Sep 17, 2009 | Canon DC220 DVD Camcorder
Dvd player wont read disk
If when you insert the disk you hear a whirring and clicking noise, CD spins, and does not read, then that is a problem with the DVD lens.
The DVD lens try to focus on the DVD track, by moving lens pickup and spinning the disk, but cannot read the tracks because the lens is dirty or defective.
Try first cleaning the lens with a DVD cleaner disk. And also if you can see the lens from the outside try blowing some canned air on it.
If this still does not help, then the lens pickup may be faulty, in this case you often replace the whole DVD drive unit inside the DVD player.
Apr 07, 2009 | Televison & Video
Liteon 5045 dvd recorder does not reconize disk and does not write
THE OPTICAL PICKUP (LASER() NEEDS CLEANING OR REPLACING.
SUPER8
Dec 01, 2008 | Lite On Televison & Video
RIPED OFF BY BROADWAY PHOTO
Unit may have dust or contaminates built up on optical pickup. If you can reach the lens, try to very gently clean the pickup lens with a Q-tip. It is possible the unit has a defective turntable motor in which case you will have to have it replaced
Jul 31, 2008 | Video Cameras
Appears not to recognize disks
Jun 28, 2008 | GoVideo R6530 DVD Recorder
Panasonic DMR-E55 DVD Recorder won't read most dvd-r brands
Hello jancinn,
This might be due to a dirty pickup or scan laser head, or the optics as a whole might be going bad (both are common problems). A qualified TV repair person should be able to determine if the scan laser or pickup head are bad by doing a laser power test. If the optical devices are dirty it is just a simple matter of cleaning them with a DVD cleaning disk, however if the optics are bad, then replacing them is actually cost inefficient, and you may want to think about getting a new DVD player/recorder.
I hope this helps,
Thank you,
Shuttle83
Jun 02, 2008 | Panasonic DMR-E55 DVD Recorder
Sound cuts out
This sounds like a lens pickup problem try using a lens cleaning disk. The recording beam is a higher intensity beam and it may funcion properly.
Sep 21, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Televison & Video Logo
18 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
