Question about Frigidaire FEF366DC Electric Kitchen Range
FEF366DC Electric Kitchen Range Problem
My Kitchen Range completely stopped working after I tried to lift the heating element on the bottom in order to insert aluminium foil under it.
Help !!
  • angeladerigg Jan 26, 2009
    Thanks for the help but I had already tried that. The first time I did it came back on and when I put the oven on again it died and refuses to work again. Every else electrical in the house works except this oven.
    Any other suggestions!
    Thanks again!
  • Frigidaire Master
  • 2,651 Answers
Osunds as if yo perhaps blown the circuit breaker, got to the fuse box and try resettting the breaker first , if not labeled its going to be a "double breaker" youll need to fully turn it off and then reset to on position
Posted on Jan 26, 2009
  • Ron Coons
    Ron Coons Jan 26, 2009
    inthat case if you pull the unit away from the wall andremove the back cover, then perhaps youll see where the elemnt wire has fallen off or perhaps burnt it sellf up
Bottom oven bottom element doesn't heat
Phil. If you do not have voltage at the element, then the Electronic Oven Control ( EOC ) has failed. Part number # 5701M403-60
In order to check for the correct voltage at the element you will need to remove power and pull the range out of its installed location and remove the back panel of the range to gain access to the wiring and element. CAUTION ! I cannot stress this enough ! There are dangerous voltages in this area!! After the panel has been removed, return power to the range,set the lower oven to bake, and check the voltage at the element. You should find 220-240 volts between the element terminals with them connected to the element. If you do not have the proper voltage then you will need to replaced the EOC.
Apr 18, 2014 | Maytag MER6772 Gemini Electric Kitchen...
Convection stopped working a couple of months ago, now regular oven does not come up to proper temperature, top element is red bottom element is not
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
Aug 12, 2010 | KitchenAid KESC307 Electric Kitchen Range
The bottom heating element in the oven has stopped working
It isvery easy to replace just unscrew the bottom heating element (unplug stove first ) take it to home depo or appliance store and get a replacement and screw it back on......then plug stove in ...
Jul 13, 2009 | GE Spectra JBP78 Electric Kitchen Range
Oven bottom wont heat
can you seee the lower bake element? usualy when bad it will be apparent with a visual inspection of the element.if there is damage to the element order a replacement . 2 screws and 2 wires . no problemTURN OFF POWER ITS A LIVE ELEMENT AT ALL TIMES!!!!!!!
Mar 16, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Problem with oven
In order for the element to stay on when the control is turned off either the control has shorted or the contact that the control switch controls has shorted, if the the light goes off as usual it is most likely the contacts in the elements relay that have welded themselves in the closed position but both the switch and relay will need to be tested.
Mar 03, 2008 | Frigidaire FEF366DC Electric Kitchen Range
Stove top and oven will not heat
first check your voltage, and the pigtail connections at the stove, then check your elements inside the oven something has shorted
Oct 27, 2007 | Frigidaire FEF366DC Electric Kitchen Range
Frigidaire FEF366DC Electric Kitchen Range Logo
170 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
