Question about Reddy Heater-70,000 BTU Kerosene w/T'stat
Kerosene reddy heater flame is intermitent
Heater will run but flame is intermitent and for a second blows smoke and then relites itself almost like it has bad fuel or something, we have put in new clean fuel.
Heater had a cracked fuel line that was not visiable on original inspection.
Posted on Jan 26, 2009
R150B kerosene reddy heater, every 2 to 3 seconds It has spurts of flame, why?
generally water or air in the line will interrupt the flame momentarily.
Nov 25, 2014 | Reddy Heating & Cooling
Shuts down after about 30 seconds, blowing some smoke.
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Nov 27, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Starts runs for a minute two the shuts down and blowes smoke
jerome kr406,
This is a classic problem with the reddy heaters. They have a filter which over time plugs up. This causes the air/fuel mixture ratio to change because the pump pressure is determined by the air bleed. As the filter plugs the air pressure drops and the fuel also drops meaning the burner is running lean. This eventually causes the unit to shut down and as you said smoke comes out. It is a fairly easy fix and I have a tip which will walk you through it at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters . My tip will link you to the place to get the parts you need as well as how to perform the additional maintenance that these heaters require.
Thanks for using FixYa and for the excellent rating. Great ratings help to keep experts helping everyone solve their problems. Thank you.
hardrocko
Nov 13, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
My 110,000 reddy heater flames up then after a minute or two just blows cold smoke???
Time for a Full tune-up, plug--fuel filter- 2-air filters -vanes in the pump.
Dec 13, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Feb 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Igniter lites up fan kicks on and within 5 sec shuts off
Dustin, The ignitor only glows for 5 seconds, just long enough to ignite the fuel. The heater is shutting down because the photocell does not see the correct flame color.
Since you say "comes on for 5 seconds", I can only assume that there is a flame. You do not specify a lack of flame. I am also assuming that you have had the heater running this heater season and the problem just started.
YOU must find out if the problem is fuel delivery related or electronics related. Start by checking the pump pressure.
Follow these troubleshooting tips
Dec 21, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Reddy Heater-70,000 BTU Kerosene w/T'stat Logo
166 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Superior Maintenance
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
