Question about Welding Tools
The instructions and the welder don't match for my MTN Gearsmith 520D I need instructions for the plasma cutter and tig setup
3 in 1 50 amp plasma 200 amp tig and mma
  • 2712 Answers
SOURCE: TIG welder help
Choose the electrode to use for the project you are starting as well as the variety of alloys you'll use such as the 6061 Aluminum alloy electrode. Grind the electrode to a point. Try to create a tip and sharpen it to help it become more rounded as you weld. Place the electrode into an electrode holder with the tip about 1/4-inch away from the sheath. Choose the settings on your tig welder. The three main ones are AC, DCEP and DCEN. Choose AC for aluminum. Slide the "cleaning/penetrating" slider more to the penetrating side. Set the "air on" to five seconds and the "max amps" to 250. Turn on the gas. For aluminum, use pure argon. For steel, an argon and carbon dioxide mix. Scrub your welding table or flat piece of sheet metal with a wire brush to make it clean and flat. Gear up in full welding safety gear including hood, goggles, apron and gloves. Hold the electrode in your dominant hand and start your welding project. Check your settings every so often to make sure they haven't changed and adjust as needed.
Posted on Aug 27, 2008
CarlGehrke
  • 169 Answers
SOURCE: Manual for a Cambell Husfeld welder Model WF2000
You can download PDF versions of the manuals for CH welders at the Campbell Hausfeld website.
Look on the left under the Service Center heading for a link to manuals.
Rank this answer if you found it useful,
Carl
Posted on Dec 03, 2008
  • 7 Answers
SOURCE: Miller TIG Welder Syncrowave 350XL has no digital read out...
it's free for you to download.
http://www.millerwelds.com/products/tig/syncrowave_350_lx/
Posted on Mar 21, 2009
GiantTechGuy
  • 25 Answers
SOURCE: my giant wse 200 tig inverter single phase AC/DC
Hi, remove the machines cover with the machine unplugged then look for disconencted plugs etc within the machine. careful where you place your bare hands.
Posted on Oct 18, 2009
  • 111 Answers
SOURCE: I'm trying to use my dads tig welder but there
go to millers web site you should be able to get one on it, make sure you have the model number and serial number they will ask for it.
Posted on Mar 14, 2010
Just purchased this and need to know what the blue wire is, the brown is and the green is. (from China of course). 'Thanks, RSTAR CT520 PLasma cutter/tig/arc welder 3 in one
If those are the power input, then the green is the grounding wire (safety ground).
If the unit is 220/240 volt, then the blue AND brown are the hot wires.
Neutral would not be used in this case.
If the unit is 120 volt, then the blue is the hot and the brown is the neutral, but your unit probably requires the 240 volt. Check the owners manual and label on the unit.
Nov 09, 2009 | Welding Tools
No full arc
the spark that you see when you touch work peice is high frequency,recheck connections like good ground (tight and clean)on the unit and work peice.no ground no fire.
Jun 03, 2009 | Welding Tools
Welding Tools Logo
196 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
