Can a coleman power mate forced air 5070-751 heater be used inside a 2 stall garage
  • 41 Answers
SOURCE: coleman 12 volt forced air heater model #4230A lighting instructions
Sounds like you have a blockage to the main jet. If you have a compressor just blow the jet out from the top and with a bit of luck it will clear it. If not you may need to remove the outer covering and find the pipe to the main jet and again using compressed air just blow it out. Usually not much goes wrong with these apart from blockages every now and then and most of the servicing places just blow them out with compressed air. Just make sure if you remove a pipe you tighten the pipe up properly when re-fitting it. Hope this helps.
Regards
Bryan
Posted on Jan 12, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: Coleman forced air furnace blower
Rmove the two screws holding the blower in place and slide it out. With the power off, rotate the wheel and inspect for debris or an impingement. If everything turns easy, you have a bad motor or start capacitor. If you have rubbing, adjust the wheel. If the motor will not turn, replace it.
Posted on May 30, 2008
  • 22 Answers
SOURCE: Coleman direct vent forced air gas furnace and asthma
maybe try a UV light on the duct work, my son has same problem and i installed a UV light and the house smelt better and my son could breath better.
Posted on Nov 03, 2008
jcpark50
  • 52 Answers
SOURCE: Manual for a Coleman Forced Air Furnace manual
If you haven't already tried Coleman customer support, try Google. You can find owner's manuals for all kinds of things. good luck, John
Posted on Nov 07, 2008
SOURCE: Kerosene forced-air heater won't start
Rick---A couple of things to check. With the unit off and unplugged, remove the spark plug-(Note-there may be a little setscrew which you have to remove first)----Put the plug wire back on the plug and ground it against the side of the heator and start it just briefly to see if the plug fires----If it does, then again with the unit shut off, remove the nozzle which has a set screw holding it in. The nozzle has 2 rubber lines running to it and leave them on and then start the unit (Note, be aware that in this test and the plug test that when its plugged in, the fan runs, so keep the plug wire and the rubber lines away from the fan) With the nozzle removed, watch very closely to see if a mist comes out of the nozzle after you plug it in. If no mist comes out, then you probably have either an air or fuel problem.---With the spark plug test, if there is no spark at the plug, the easiest way is to install a new plug and if there is still no spark, then the ignitor is probably bad----------On the nozzle test, try taking off the 2 lines on the nozzle, one line goes to the fuel tank and the other line is the air line (take note which line goes where) first blow thru each connection on the nozzle to see if its plugged and if its not then blow thru the hose going to the tank and you should hear a bubbling noise in the tank--if not then, its plugged or the hose is split----------The other line is the air line and if you can't get anything on it, the filter may be very dirty----behind the filter, there should be a port for checking the air pressure when the unit is running----The unit I have runs on 3 psi pressure, BUT yours may run on a different setting--That psi setting may be stamped on the unit behind the filter---Hope this helps
Posted on Dec 24, 2008
How do you remove the fan from a 1980 modle presidentil coleman furnace
These are not designed to operate without a fan and doing so will cause the unit to overheat... There are 5 screws and a cover plate inside the rear of the unit. The fan can be easily removed then
May 25, 2014 | Coleman Propane Forced Air Heater...
Fans working outside but no air is coming inside, on my 3 ton air conditioner
Check air handler up in attic follow stat to power box on handler look for blown fuse.pull power at unit first
May 22, 2014 | Coleman Propane Forced Air Heater...
Coleman evcon electrical furnace doesnt force air intermittently
It sounds like the fan is not functioning. With the breaker, SSU, and/or power off check the wiring, tighten any loose wiring, and make sure nothing is blocking the fan from spinning. Check to see if it will spin by hand, if there is access. If it does, and you have power, then the fan motor may need to be replaced.
Does this help? Let us know.
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Nov 30, 2013 | Coleman Propane Forced Air Heater...
Have a Evcon Coleman Furnace shows three green blinking lights but will not ignight what could be wrong
I have had the same problem with mine for the last 2 years. Remove the motor on the side of the furnace(usually held on by 3 screws) and turn the fan blades inside by hand. after sitting all summer it seems to get stuck. If it moves freely, replace the motor and try to start it again. This fixed mine the last 2 years! Hope this helped.
Sep 29, 2010 | Coleman Propane Forced Air Heater...
Terrible smell and burns my eyes from 5gallon tank. First 5gallon tank was find as is small Coleman bottle . Can propane be bad from Supplier. It gives off sour smell and irritates eyes when burning?
I would not use it any further, I cant say if anything is in the gas, I doubt it, However the propane at too low a pressure etc, can cause this, dont use it with eyes butrning ever!
May 28, 2010 | All-Pro Propane Garage Shop Heaters - All...
Read the instructions on how to light the pilot but where I need to put the match I am not sure where to direct the flame to. I see the housing for the pilot but not where inside
You noted above it is a Coleman forced air Heater with a electronic ignition? You don't need a match to light the pilot, it lights automatic on a call for heat at the thermostat.If it does not light, then you have other problems. Let me know.
Good Luck,
Shastalaker7
Nov 04, 2009 | Coleman Propane Forced Air Heater...
I HAVE A COLEMAN AC CANNOT FIND FILTERS TO FIT
yOU CAN PURCHASE FILTER MATTING AT ANY HARDWARE store and cut to size. Its cheaper anyway.. It comes in rolls.
Jun 05, 2009 | Coleman Propane Forced Air Heater...
Propane heater goes out after heat cycle
I've seen excessive draft draw the pilot flame away from the thermo couple when the burners light so when the burners shut down so does the pilot.
Feb 08, 2009 | Coleman Propane Forced Air Heater...
Coleman 12 volt forced air heater model #4230A lighting instructions
Regards
Bryan
Jan 02, 2008 | Coleman Propane Forced Air Heater...
Dec 11, 2007 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
