Question about Epson Stylus Pro 10600 InkJet Printer
Service req 0001001C
I replace the C362DRV-B board, and restart the machine. got this message service req 0001001C.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
SERVICE REQ - 0001001C - FS origin (Suction fan shutter home position) error
Posted on Apr 12, 2014
3 Suggested Answers
  • 32 Answers
SOURCE: service require E008
E008. Is a Main Motor Problem.
Main Motor, Engine, power unit
E021. Transfer Belt Cleaner Contanct/ Rease Problem.
Cleaner pressure flapper solenoid, Belt cleaner detect sensor, engine PCB.
Make sure inside on unit, has no toner spilled in it.
Posted on Feb 15, 2008
hdsportyem
  • 11 Answers
SOURCE: Epson Acculaser CX11NF Error 'Service Req E527'
Hi.. To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed, the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall the toner cartridge if stuck.
Thanks
jim report_dis_text_13954 = 'We\'re sorry but you must be signed in to report inappropriate material. Click the button below to sign in or register.
  • Sign In / Register »
  • Cancel »
Posted on Feb 18, 2009
Service error code 00010018 epson
Epson Stylus Pro 10000CF Error Codes
Code
00,010,018
Display
SERVICE CALL 00,010,018: INK SURFACE SENSOR (LC) OVERFLOW
Description
Surface of a liquid sensor defective or I/C valve solenoid defective it is (on condition).
Remedy
• I/C valve solenoid exchange • C362DRV board exchange • Surface of a liquid sensor exchanger
Sep 04, 2013 | Epson Stylus Pro 7880 InkJet Printer
PRINTER SHOWING 'SERVICE REQ E300'
Sadly this is a serious error requiring a replacement Laser Unit - if you are lucky. It may also be a system board error that is falsely reporting the error.
This printer is likely to be beyond economical repair.
Aug 22, 2012 | Epson Aculaser C3800 Transfer Unit
When the message call for service is displayed, I pressed the C key and the 8 key at the same time an alpha numeric code C56 appeared. how do i go about from here?
Communication related service call C56-Communication error between PFC and M-CPU
(1) Check the signal patterns (REQ, ACK, RXD, TXD) between IC11 (G/A) and IC21 (PFC) on the
LGC board for open-or short-circuits.
(2) Replace the LGC board.
Jan 25, 2010 | Toshiba Office Equipment & Supplies
EPSON AcuLaser C1900 with Error "Service Req E020"
ERROR CODE: E020
“SECONDARY TRANSFER VOLTAGE CONTACT/RELEASE PROBLEM”
Solution
�� Electric parts which can cause the trouble:
• Transfer Roller Pressure Solenoid (SL2)
• Transfer Roller Pressure Position Detection Sensor (PC7)
• Engine Board (PWB-A)
May 18, 2009 | Epson AcuLaser C1900 Printer
I get a printer error 00010016 when I put in cleaning cartridges
SERVICE REQ. 00010016: LIQUID SENSOR OVERFLOW (C)
Problem
Solution
 Printhead exchange
Mar 24, 2009 | Epson Stylus Pro 10000 InkJet Printer
Epson stylus pro10000 problem service reg
SERVICE REQ. 00020000:NVRAM ERROR
SERVICE REQ. 00020001:NVRAM COMPARISON ERROR
SERVICE REQ. 00020002:SDRAM ERROR
SERVICE REQ. 00020003:FLASH MEMORY ERROR
Problem
Abnormal detection in a corresponding element
Solution
1. Once save parameter to Flash memory card and install it to the printer again.
2. C362DRV board. replacement
Feb 18, 2009 | Epson Stylus Pro 10000 InkJet Printer
I received an error message reading: SERVICE REQ. EROOO3. I can't print any more and need to finish a manuscript today.
The message indicates a controller or print engine error has been detected. It's the internal electronic/logic board failing.
If power cycling or turning it OFF/ON does notclear the error message, service is required as the logic board needsreplacement.
here's a link for certified service center for your product.
Nov 17, 2008 | Epson Action Laser 1500 Printer
"Service Req E095"
This is an HSYNC Error and probably means the Laser unit on your machine is faulty.
Possible causes of the error :
Laser Scanner
LSU Harness
C585 Main MCU Board
For more info get a service manual HERE
May 28, 2008 | Epson AcuLaser 2600N Printer
Service require E008
Feb 14, 2008 | Epson AcuLaser C1900 Printer
Epson Stylus Pro 10600 InkJet Printer Logo
156 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
