Question about Nikon Coolpix S30 Digital Camera White
How do I open the battery door? - Nikon Coolpix S30 Digital Camera White
  • 147 Answers
With the display screen facing you, look on the bottom right for the door for the batteries. There's a tiny grey slide switch on the right side of that door with polk-a-dots that you have to slide toward the screen side of the camera. Hold the camera upside down and while sliding this switch away from you, you can slide the door to the right, which opens the battery compartment.
Posted on Feb 28, 2013
  • feldman_jane
    feldman_jane Mar 01, 2013
    Thank you, thank you, thank you!!! Very clear and doable. This just stymied me - thank you for your help!
Dead battery cant open doors
Unlock the rear door and climb in that way or call a locksmith to open the door for you
Apr 13, 2014 | 2011 Toyota RAV4
Audi central locking
Lock ALL DOORS, Disconnect the Battery... Wait 2-3 minutes and connect the battery and it should reset itself. Make sure all doors are LOCKED...
AND that you have a KEY to open the door in case it does not work.
Feb 12, 2014 | Cars & Trucks
My keyless entry pad will let garage down when code is keyed in, but when code has been keyed up to let it up it will not do so.
I assume you mean that the entry keypad works when the door is open but not when the door is closed. This usually indicates that the signal strength on the entry pad is low. Try changing the battery.
Insert a small Philips screwdriver in the opening on the bottom of the battery compartment cover. Pull the cover slightly outwards then pull the cover down. The battery in the compartment is a 9V battery. Then replace the cover by inserting the lip in the top of the battery compartment and then snap it into place.
If you change the battery quickly, you shouldn't need to reprogram the opener. If a new battery doesn't solve the problem, check what may be causing signal interference when the door is down. (Consider moving the keypad to a spot closer to the door opening. I know that we have the keypads placed on the side of the door jamb on our garage doors. When the small handheld remote units start to loose their batteries, bringing the remotes to that area that often works.)
I hope this helps.
Oct 04, 2013 | Sears Craftsman LiftMaster Chamberlain...
Open the battery door of what make and model camera?
Jun 07, 2013 | Computers & Internet
Open battery compartment on outside battery base??? i want to change batteries on the unit but cant open door for battery??
I finally got mine open a few minutes ago by prying it with a knife. A thin screwdriver would have been safer.
Dec 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Chamberlain Liftmaster Professional 1/3 hp garage door opener. I'm unable to find the model number, but it was made in April 2004 and has an orange learn button. It has been working fine since...
Do you mean the numeric keypad is no longer controlling the garage door? If so, have you changed the battery for the keypad? Frequently, if the battery is low, the keypad will stop working when the door is closed but works to close an open door. On most Chamberlain garage door openers, this is a 9V battery. You may need a small Philips screw driver to open the battery compartment at the bottom of the keypad.
After changing the battery, try the learn code procedure again. I've found it easiest to have two people involved when programming the keypad to the garage door opener. One handles the Learn button and the other types in the desired code.
I hope this helps.
May 22, 2017 | Vacuums
Car door opener not working..where is the battery? Is there one?
The remote does have a battery. It either has a small door that slides open or you remove a screw to separate the two halves of the case. The battery is inside.
Sep 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Battery in M-RBB93
For some cordless mice or trackballs, there is a slot for the battery door on the bottom of the mouse. Between the slot and the outside edge of the door is a thin strip of plastic. If you compress this thin strip of plastic towards the slot, the catch on the door will release and the door should open.
On other mice, the battery door is on the top of the mouse. Simply slide the top of the mouse cover down and lift the door up. There should be an etched diagram on the door indicating which direction to slide the door.
Once you have opened the battery door, remove the old batteries and dispose of them according to your local waste disposal regulations. Then insert the new batteries into the battery compartment using the diagram in the compartment as a guide. When you have finished inserting the batteries, close the battery door.
regards
Feb 21, 2008 | Logitech Cordless Mouse
Nikon Coolpix S30 Digital Camera White Logo
120 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
