Question about SDAT SB-L1006S Subwoofer
Buzzing on MixSonic Subwoofer - SDAT SB-L1006S Subwoofer
    Scholar:
  • 45 Answers
Buzzing sounds in audio equipment can almost always be traced to substandard wiring, bad grounds, or wiring that is run to close to a power source like extension cords or power strips. Unshielded RCA's can do this and RCA's that have a broken lead can also do this. So first try moving it away from your other equipment. Then start checking RCA cables or any other input cables to make sure they are intact. You may have to replace the wires to see if there is a problem as a broken lead may not be noticeable from the outside. If you try all this and still no improvement, it would be likely that the source of the problem is in the MixSonic.
-Dynami
Posted on Apr 06, 2009
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
What is the buzzing in my subwoofer?
It has being a long, long time since I've work with a subwoofer.
Check to see if it's making ground inside the subwoofer. Not sure if this will fix it, but it works in mine.
Dec 19, 2015 | Audio Players & Recorders
Why is the subwoofer making a buzzing sound? Is there a solution?
I have had the same problem with my Sony sub. It sounds like it is picking up electrical noise and would not go into standby when the reciever was off. I rerouted my wires and changed to a much higher quality wire. I was using a very low quality stranded copper with thin insulation to start with.
Jun 14, 2010 | Sony SA-WM20 Subwoofer
Subwoofer stopped working
You have a bad connection to the subwoofer.
Mar 07, 2009 | Monitor Audio Radius R360 Subwoofer
No problem jusst wanted to know if the mixsonic
I'm taking a look at the Amazon page for the player: http://www.amazon.com/Aim-1g-mp3-black/dp/B001D0EJ80 and I see no mention of a timer record feature. Hope this helps.
Mar 04, 2009 | MixSonic Aim (1 GB) MP3 Player...
Subwoofer has a constant vibrating tone that will not go away
I suspect that what you are hearing is the 60 cps of the mains. If the humming sound is coming the subwoofer itself, then it is possible that you have a defective/leaky capacitor in the power supply section of the subwoofer. In the subwoofer, if the buzzing sound is coming from anywhere else other than the speaker itself, then it is possible that you have a loose transformer again in the power supply. Unless you are comfortable working with testers and soldering irons, I would suggest an electronics technician who should be able to diagnose and fix it for you.
Apr 02, 2007 | Dell Powered Subwoofer Set A425 Computer...
166 people viewed this question
Top SDAT Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a SDAT Audio Player and Recorder Expert? Answer questions, earn points and help others
